代码
//HCSR04.h配置
#ifndef _HCSR04_H
#define _HCSR04_H
#include "main.h"
void HCSR04Init(void);
float Distance(void);
#endif
//HCSR04.c配置
#include "HCSR04.h"
#include "main.h"
const Timer_A_UpModeConfig upConfig =
TIMER_A_CLOCKSOURCE_SMCLK, // SMCLK Clock Source
TIMER_A_CLOCKSOURCE_DIVIDER_3, // SMCLK/1 = 3MHz
50000, // 5000 tick period
TIMER_A_TAIE_INTERRUPT_DISABLE, // Disable Timer interrupt
TIMER_A_CCIE_CCR0_INTERRUPT_ENABLE, // Enable CCR0 interrupt
TIMER_A_DO_CLEAR // Clear value
MAP_GPIO_setAsOutputPin(GPIO_PORT_P9, GPIO_PIN2);//tring
MAP_GPIO_setAsInputPin(GPIO_PORT_P5, GPIO_PIN3);
MAP_GPIO_setAsInputPinWithPullDownResistor(GPIO_PORT_P5, GPIO_PIN3);
MAP_GPIO_disableInterrupt(GPIO_PORT_P9, GPIO_PIN2);
MAP_GPIO_disableInterrupt(GPIO_PORT_P5, GPIO_PIN3);
MAP_Timer_A_configureUpMode(TIMER_A2_BASE, &upConfig);
MAP_Interrupt_enableSleepOnIsrExit();
MAP_Interrupt_enableInterrupt(INT_TA1_0);
MAP_Timer_A_startCounter(TIMER_A2_BASE, TIMER_A_UP_MODE);
MAP_Interrupt_enableMaster();
void TA1_0_IRQHandler(void)
MAP_Timer_A_clearCaptureCompareInterrupt(TIMER_A2_BASE,TIMER_A_CAPTURECOMPARE_REGISTER_0);
// Timer_A_getCounterValue(uint32_t timer);
int count=0,i=0,sum=0;
float distance=0;
while(i!=5)
GPIO_setOutputLowOnPin(GPIO_PORT_P9, GPIO_PIN2);//上拉
GPIO_setOutputHighOnPin(GPIO_PORT_P9, GPIO_PIN2);//上拉
delay_us(10);
TIMER_A_CMSIS(TIMER_A2_BASE)->R = 0;
while(GPIO_getInputPinValue(GPIO_PORT_P5,GPIO_PIN3) == 0); //
while(GPIO_getInputPinValue(GPIO_PORT_P5,GPIO_PIN3) == 1); //
MAP_Interrupt_disableInterrupt(INT_TA1_0);
count=TIMER_A_CMSIS(TIMER_A2_BASE)->R;
//v = 340m/s = 34000cm/s = 34000cm/10^6us = 0.034cm/us
//s = vt/2 = t*0.034/2 = t*0.017 ?t/58
distance=((float)count / 58);
i++;
sum=sum+distance;
return sum/5;
//main.c配置
#include "main.h"
#include "HCSR04.h"
#include "string.h"
#include "stdio.h"
/* 全局变量申明区 */
// u8 a=0;
// u16 len ;
/* 函数调用申明区 */
int main(void)
int Distance1;
WDT_A_holdTimer();
GPIO_setAsOutputPin(GPIO_PORT_P1, GPIO_PIN0);//led灯
SystemClockInit(HFXT);//系统时钟初始化(系统主时钟)
SystemClockInit(DCO);//系统时钟初始化(子系统时钟)
Usart1tInit(); //串口1 初始化
HCSR04Init();
LedInit();
while(1)
Distance1= Distance();
GPIO_toggleOutputOnPin(GPIO_PORT_P2,GPIO_PIN1);
printf("Distance = %dmmrn",Distance1);
delay_ms(50);
总结
HC-SR04超声波的配置程序还是很简单的,但是相比STM32,MSP432使用HC-SR04测量出来的距离超过20CM之后就不准确了,原因暂时未知,可能是定时器频率的问题,还有待研究。
上一篇:基于MSP432P401R的OLED I2C程序
下一篇:MSP432P401R时钟系统
推荐阅读最新更新时间:2024-11-17 05:46
设计资源 培训 开发板 精华推荐
- PAM8610TR-双声道功放板
- 使用 Diodes Incorporated 的 DLD101 的参考设计
- 能够通过MC33775A进行CAN FD通信的HVBMS集中式单体监测单元(CMU)
- LT3091IFE 产生极低输出电压的典型应用
- 用于手电筒的 5-LED 白光 LED 驱动器
- 使用 Diodes Incorporated 的 ZR78L12 的参考设计
- LDK120C30R 3V低压降稳压器典型应用固定电路
- 使用 Analog Devices 的 LTM8003-3.3HY 的参考设计
- SPX431L 精密可调并联稳压器典型应用电路
- 使用 Analog Devices 的 LTC3130IUDC-1 的参考设计
