0 实验预期效果
完成串口数据的接收和发送
1 相关原理图
2 软件配置
STM32CubeMX配置USART1:
在NVIC中配置USART中断优先级:
3 代码编写
3.1 函数认识
见博客【STM32】HAL库学习 2—hal_uart_kokoのadventure的博客-CSDN博客
3.1.1 串口发送
* @brief Sends an amount of data in non blocking mode.
* @note When UART parity is not enabled (PCE = 0), and Word Length is configured to 9 bits (M1-M0 = 01),
* the sent data is handled as a set of u16. In this case, Size must indicate the number
* of u16 provided through pData.
* @param huart Pointer to a UART_HandleTypeDef structure that contains
* the configuration information for the specified UART module.
* @param pData Pointer to data buffer (u8 or u16 data elements).
* @param Size Amount of data elements (u8 or u16) to be sent
* @retval HAL status
HAL_StatusTypeDef HAL_UART_Transmit_IT(UART_HandleTypeDef *huart, const uint8_t *pData, uint16_t Size)
3.1.2 串口接收
* @brief Receives an amount of data in non blocking mode.
* the received data is handled as a set of u16. In this case, Size must indicate the number
* of u16 available through pData.
* @param Size Amount of data elements (u8 or u16) to be received.
HAL_StatusTypeDef HAL_UART_Receive_IT(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size)
3.1.3 中断回调函数
* @brief Rx Transfer completed callbacks.
* @retval None
__weak void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
/* Prevent unused argument(s) compilation warning */
UNUSED(huart);
/* NOTE: This function should not be modified, when the callback is needed,
the HAL_UART_RxCpltCallback could be implemented in the user file
3.2 代码编写
3.2.1 定义发送和接收缓冲区
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
uint8_t hello[] = "USART1 is ready...n";
uint8_t recv_buf[13] = {0};
/* USER CODE END 0 */
3.2.2 重新实现中断回调函数
HAL中弱定义了一个中断回调函数 HAL_UART_RxCpltCallback, 我们需要在用户文件中重新定义该函数,放在哪都可以,这里我放在 main.c 中:
/* USER CODE BEGIN 4 */
/* 中断回调函数 */
/* 判断是哪个串口触发的中断 */
if(huart ->Instance == USART1)
//将接收到的数据发送
HAL_UART_Transmit_IT(huart, (uint8_t*)recv_buf, 13);
//重新使能串口接收中断
HAL_UART_Receive_IT(huart, (uint8_t*)recv_buf, 13);
/* USER CODE END 4 */
3.2.3 修改main函数
int main(void)
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_USART1_UART_Init();
/* USER CODE BEGIN 2 */
//使能串口中断接收
HAL_UART_Receive_IT(&huart1, (uint8_t*)recv_buf, 13);
//发送提示信息
HAL_UART_Transmit_IT(&huart1, (uint8_t*)hello, sizeof(hello));
/* USER CODE END 2 */
while (1)
4 实验结果
上一篇:【STM32】实战1—用STM32与ULN2003驱动步进电机28BYJ-48(一)
下一篇:【STM32】4—UART串口(查询模式)
推荐阅读最新更新时间:2024-11-04 14:48
