本文将用前灯为例子。
1. 车灯通道
对于车灯,必须要创建两个通道,分别为主通道和共享通道。
小提示:通道开启数量是固定的,不是动态开启。修改位置如下:(全局搜索)
关键字:ANT_CONFIG_TOTAL_CHANNELS_ALLOCATED
检测是否已连接(Light_Index!=0),成功连接后,才允许开启共享通道。
函数名:ant_BikeLight_SHARED_MASTER_Init
功 能:共享通道初始化
形 参:ch--> 0--主灯共享通道(可发可接) 1--副灯共享通道(只接)
返回值:
备 注:
作 者:薛建强
时 间:2020/02/27
使 用:
void ant_BikeLight_SHARED_MASTER_Init(void)
uint32_t err_code = 0;
uint8_t pucStatus = 0;
/*共享通道*/
if (SystemInit_Type.ANT_SHARED_CHANNEL == 0)
pucStatus = ant_BikeLight_Shared_close(ant_channel_Shared.channel_number);//关闭共享通道
if (pucStatus == 100) //通道成功未关闭
return;
else if ((pucStatus == 17) || (pucStatus == STATUS_ASSIGNED_CHANNEL))
err_code = sd_ant_channel_unassign(BikeLight_Shared_CHANNEL_NUMBER);
SEGGER_RTT_printf(0, "ANT BikeLight Shared channel_unassign %u close %dnr", BikeLight_Shared_CHANNEL_NUMBER, err_code);
if (m_ant_BikeLight.page_33.Light_Index_Set == 1)//ID=1,主灯
ant_channel_Shared.channel_type = BikeLight_SENS_CHANNEL_TYPE_Shared;
//ant_channel_Shared.device_number = BikeLight_DEVICE_NUMBER; //将ANT设备号设置为MAC地址
ant_channel_Shared.device_number = NRF_FICR->DEVICEADDR[0]; //将ANT设备号设置为MAC地址
else if (m_ant_BikeLight.page_33.Light_Index_Set > 1)//ID>1,副灯
ant_channel_Shared.channel_type = BikeLight_DISP_CHANNEL_TYPE_Shared;
else
SEGGER_RTT_printf(0, "Shared_open_fail,not Light_Index!!! %drn", m_ant_BikeLight.page_33.Light_Index_Set);
return;
ant_channel_Shared.channel_number = BikeLight_Shared_CHANNEL_NUMBER; //通道号
ant_channel_Shared.ext_assign = BikeLight_EXT_ASSIGN; //ANT 外部分配.
ant_channel_Shared.rf_freq = BikeLight_ANTPLUS_RF_FREQ; //频率
ant_channel_Shared.transmission_type = m_ant_BikeLight.page_33.Transmission_Type; //主灯的传送类型
ant_channel_Shared.device_type = BikeLight_DEVICE_TYPE_Shared; //设备类型
ant_channel_Shared.device_number = m_ant_BikeLight.page_33.DeviceNumber_MSB << 8 | m_ant_BikeLight.page_33.DeviceNumber_LSB;
ant_channel_Shared.channel_period = BikeLight_MSG_PERIOD_8Hz;//消息周期
ant_channel_Shared.network_number = 0;
err_code = ant_channel_init(&ant_channel_Shared);
APP_ERROR_CHECK(err_code);
err_code = ant_BikeLight_Shared_open(&ant_channel_Shared);
SEGGER_RTT_printf(0, "Shared_open,err_code=%02X device_number:%d transmission_type:%drn", err_code, ant_channel_Shared.device_number, ant_channel_Shared.transmission_type);
if (SystemInit_Type.ANT_SHARED_CHANNEL == 1 && SystemReg.ANT_SHARED_CHANNEL == 2)
err_code = ANT_Send_Message(BikeLight_Shared_CHANNEL_NUMBER, ANT_message_payload_Shared_Wait);
ANT_Relay_New_Share_Page = 0; //发送指定页
2. 通道类型
/**@brief ANT channel configuration structure. */
typedef struct
uint8_t channel_number; ///< 分配的频道号。
uint8_t channel_type; ///< 通道类型 (see Assign Channel Parameters in ant_parameters.h: @ref ant_parameters).
uint8_t ext_assign; ///< 扩展分配 (see Ext. Assign Channel Parameters in ant_parameters.h: @ref ant_parameters).
uint8_t rf_freq; ///< 射频偏移 2400 MHz (for example, 2466 MHz, ucFreq = 66).
uint8_t transmission_type; ///< 传输类型.
uint8_t device_type; ///< 设备类型.
uint16_t device_number; ///< 设备编号.
uint16_t channel_period; ///< 32千赫的周期计数。
uint8_t network_number; ///< 表示网络密钥的网络号.
#if ANT_CONFIG_ENCRYPTED_CHANNELS > 0
ant_encrypt_channel_settings_t * p_crypto_settings; ///< 指向加密设置的指针,如果必须省略此配置,则为空。
#endif
} ant_channel_config_t;
主通道配置:
channel_number :0 //通道0
channel_type :0x10 ///< 主频道 (PARAMETER_TX_NOT_RX).
ext_assign :0x10 //通道快速启动模式。
rf_freq :57//频率,十进制 57 (2457 MHz).
transmission_type:5u //广播通道
device_type :0x23 //设备类型:车灯==35(广播通道类型)
device_number :NRF_FICR->DEVICEADDR[0]; //将ANT设备号设置为MAC地址
channel_period:4084///< 消息周期,十进制 4035 (8.12 Hz)
network_number:0
共享通道配置:
channel_number :1 //通道1
这里的通道类型需要根据实际控制:
当索引号为0时:
当索引号为>0时:
channel_type :0x00 ///< 从属信道 (PARAMETER_RX_NOT_TX).
transmission_type:6u //共享通道
device_type :0x24 ///< 设备类型:车灯==36(共享通道类型)
device_number :m_ant_BikeLight.page_33.DeviceNumber_MSB << 8 | m_ant_BikeLight.page_33.DeviceNumber_LSB;//设备号有P33连接命令决定。
channel_period:4084///< 消息周期,十进制 4035 (8.12 Hz).
network_number:0
3. 数据轮询
由于前面设置了8HZ(125ms)的消息周期,所以20*9=180ms。这样消息冲撞概率会小。
函数名:ant_message_send
功 能:用于设置ANT消息的有效负载并发送它的函数。(广播通道)
形 参:p_profile--指向配置文件实例的指针。
返回值:
备 注:
作 者:薛建强
时 间:2020/02/27
使 用:
void ant_message_send(ant_BikeLight_profile_t *p_profile)
uint32_t err_code;
if (ANT_PAGE_NEW < 127) //广播通道的内容
sens_message_encode(p_profile, ANT_message_payload);//对广播命令进行编码
err_code = sd_ant_broadcast_message_tx(p_profile->channel_number, 8, ANT_message_payload);//发送广播命令
// if (ANT_message_payload[0] == 18)
SEGGER_RTT_printf(0, "channel0---TX page_%02d: %02X %02X %02X %02X %02X %02X %02X %02X --err_code:%dnr",
ANT_message_payload[0], Replace_Buff(ANT_message_payload), err_code
);//打印发送共享命令
else//共享通道的内容
if (ANT_PAGE_NEW == 127 + 1)
err_code = sd_ant_broadcast_message_tx(p_profile->channel_number, 8, ANT_message_payload_Wait_2);//共享通道的内容转发广播通道
SEGGER_RTT_printf(0, "[channel3---TX page_%02d: %02X %02X %02X %02X %02X %02X %02X %02X --err:%d]nr",
ANT_PAGE_NEW - 127, Replace_Buff(ANT_message_payload_Wait_2), err_code
);//打印发送共享命令
else if (ANT_PAGE_NEW == 127 + 2)
err_code = sd_ant_broadcast_message_tx(p_profile->channel_number, 8, ANT_message_payload_Wait_3);//共享通道的内容转发广播通道
ANT_PAGE_NEW - 127, Replace_Buff(ANT_message_payload_Wait_3), err_code
);//打印发送共享命令
else if (ANT_PAGE_NEW == 127 + 3)
err_code = sd_ant_broadcast_message_tx(p_profile->channel_number, 8, ANT_message_payload_Wait_4);//共享通道的内容转发广播通道
上一篇:[ANT+][nrf51422][s210] 自行车车灯 最低数据页面要求
下一篇:[nrf52832] [s332] 搭建开发环境及注意事项
设计资源 培训 开发板 精华推荐
- 具有温度补偿阈值、Vin 阈值 = 1.24V 的 SPX432 单电源比较器的典型应用
- 使用 Microchip Technology 的 TS8308500 的参考设计
- 无电池NFC墨水屏
- 【训练营_进阶班】Internet of Things
- 基于GD32E231的贪吃蛇小游戏
- EVAL-ADXRS290Z,用于 ADXRS290 MEMS 陀螺仪的惯性传感器评估系统
- 【单片机最小系统】EP2C8Q208最小系统
- AD9627-150EBZ,用于评估 AD9627 12 位、150 MSPS、1.8V 双路模数转换器的评估板
- 使用 ON Semiconductor 的 CS4101 的参考设计
- 使用 Omron 的 S8VS-09024B 的参考设计
- CGD和Qorvo将共同革新电机控制解决方案
- 是德科技 FieldFox 手持式分析仪配合 VDI 扩频模块,实现毫米波分析功能
- 贸泽开售可精确测量CO2水平的 英飞凌PASCO2V15 XENSIV PAS CO2 5V传感器
- 玩法进阶,浩亭让您的PCB板端连接达到新高度!
- 长城汽车研发新篇章:固态电池技术引领未来
- 纳芯微提供全场景GaN驱动IC解决方案
- 解读华为固态电池新专利,2030 叫板宁德时代?
- 让纯电/插混车抓狂?中企推全球首款-40℃可放电增混电池,不怕冷
- 智驾域控知多少:中低端车型加速上车,行泊一体方案占主体
- Foresight推出六款先进立体传感器套件 彻底改变工业和汽车3D感知
