https://www.linmingjie.cn/index.php/archives/253/
DDI0413C_cortexm1_r0p1_trm.pdf // https://developer.arm.com/documentation/ddi0413/c/Babeagge
stm32f407zg 开发板 // 随意一个 这样的卡发版即可
dsview 套装(逻辑分析仪)
jlink for windows 软件
jlink (usb转jtag)
因为 没有合适的资料,所以选取了 m1 的 trm
DDI0413C_cortexm1_r0p1_trm 中 有详细的 DAP 描述
读者可以 以 cortex-M1 开发板 为基准做资料
实验重点
在 Jlink.exe 命令行中 运行 https://www.linmingjie.cn/index.php/archives/253/ 中的 三条命令
writedp 2 0
writeap 1 20000000
readap 3
并 抓 jtag 时序(非swd),并加以解析
# 写DP,选AP[0] Bank[0]
J-Link>writedp 2 0
Writing DP register 2 = 0x00000000 (0 write repetitions needed)
# 写AP[0] BANK[0] Address寄存器
J-Link>writeap 1 20000000
Writing AP register 1 = 0x20000000 (0 write repetitions needed)
# 读操作代表读memory, 可以看到结果已经变化
J-Link>readap 3
Reading AP register 3 = 0x12345678 (0 read repetitions needed)
1. 准备工作 环境搭建 和 建立软件链接
安装 jlink for windows
连接物理设备
建立软件链接
SEGGER J-Link Commander V7.22b (Compiled Jun 17 2021 17:23:58)
DLL version V7.22b, compiled Jun 17 2021 17:22:49
Connecting to J-Link via USB...O.K.
Firmware: J-Link V9 compiled May 7 2021 16:26:12
Hardware version: V9.20
S/N: -1
VTref=3.285V
Type "connect" to establish a target connection, '?' for help
J-Link>connect
Please specify device / core. Type '?' for selection dialog Device> Please specify target interface: J) JTAG (Default) S) SWD T) cJTAG TIF> Device position in JTAG chain (IRPre,DRPre) JTAGConf> Specify target interface speed [kHz]. Speed> Device "STM32F407VG" selected. Connecting to target via JTAG InitTarget() start Can not attach to CPU. Trying connect under reset. InitTarget() end TotalIRLen = 9, IRPrint = 0x0011 JTAG chain detection found 2 devices: #0 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP #1 Id: 0x06413041, IRLen: 05, STM32 Boundary Scan DPv0 detected Scanning AP map to find all available APs AP[1]: Stopped AP scan as end of AP map has been reached AP[0]: AHB-AP (IDR: 0x24770011) Iterating through AP map to find AHB-AP to use AP[0]: Core found AP[0]: AHB-AP ROM base: 0xE00FF000 CPUID register: 0x410FC241. Implementer code: 0x41 (ARM) Found Cortex-M4 r0p1, Little endian. FPUnit: 6 code (BP) slots and 2 literal slots CoreSight components: ROMTbl[0] @ E00FF000 ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7 ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM Cortex-M4 identified. J-Link> 写地址 20000000 为 12345678 读地址 20000000 , 以验证写入正确 实验开始 第1步 J-Link>writedp 2 0 Writing DP register 2 = 0x00000000 (0 write repetitions needed) // 作用 : 选中 第0个AP中的第0个bank// 从0开始计数 // 参数分析 // writedp : 会产生 IR ,0b1010 , 选中 DPACC // 2 : 选中 Select Register // P151 In the case of a DPACC access, to read a debug port register, by the value shifted into A[3:2]. // 0 : 写入 Select Register 中的值(包括选择哪个AP和选择哪个bank) jtag 时序 以 DDI0413C_cortexm1_r0p1_trm.pdf 分析 , 之后的 Pxx ,都是该书中的页码 分析 1. IR TDI 传入 0x1FA P145 : On debug logic reset, IDCODE becomes the current instruction 所以,此时 必须 走 IR 链 选中 DPACC 传入 0b1010 (同时TDO 0b0001) 选中 DPACC // 但是 写入的是 9bit(0x1FA),高5位无效 2. DR TDI 传入 0x04 P149 : DPACC P151 : RnW为0 ,表示写DATAIN[31:0]到某个寄存器 //If RnW is shifted in as 0, the request is to write the value in DATAIN[31:0] to the addressed register. P151 : A[3:2]即TDI[2:1](值为0b10)选中寄存器P185 "AP Select Register", In the case of a DPACC access, to read a debug port register, by the value shifted into A[3:2].See JTAG-DP register map on page 9-53 for the addressing details // 注意 : DP 只有一个,AP可以有多个 P185 : AP Select Register 的 Address[3:2] 为0b10 此时标志要 写 DATAIN[31:0]即 TDI[34:3]进入 AP Select Register. // 注意 : 此次TDI传输了36bit, 高1位无效 根据 P195 "AP Select Register" 的定义 , APSEL 为0 ,APBANKSEL为0 , 即第0个AP,第0个bank 注意 : M0 中只有一个 AP(即AHB-AP) , M4 也只有一个 AP(即AHB-AP) , APSEL 域 只能填入0 第2步 J-Link>writeap 1 20000000 Writing AP register 1 = 0x20000000 (0 write repetitions needed) // 作用 : 之前已经选中"某AP的某bank",此时写入 20000000 到该bank 中的 第1(从0开始计数)个寄存器 // 参数分析 // writeap : 会产生 IR ,0b1011 , 选中 APACC // 1 : 选中 Transfer Address Register // P151 In the case of a APACC access, to read an access port register, by the combination of: the value shifted into A[3:2] // 0 : 写入 Transfer Address Register 中的值(要读的地址) jtag 时序 以 DDI0413C_cortexm1_r0p1_trm.pdf 分析 , 之后的 Pxx ,都是该书中的页码 分析 1. IR TDI 传入 0x1FB 之前已经选中APACC,而现在要操作 APACC 组的寄存器 所以,此时 必须 走 IR 链 选中 APACC 传入 0b1011 (同时TDO 0b0001) 选中 APACC // 但是 写入的是 9bit(0x1FB),高5位无效 2. DR TDI 传入 0x1 0000 0002 // LSB P149 : APACC P151 : RnW为0 ,表示写DATAIN[31:0]到某个寄存器 //If RnW is shifted in as 0, the request is to write the value in DATAIN[31:0] to the addressed register. P151 : 1. P151 : In the case of a APACC access, to read an access port register, by the combination of:the current value of the SELECT register in the DP, see AP Select Register,SELECT on page 9-63. 知道了当前选中的 AP 那哪个(上一条命令决定了是 AHB-AP) 2. 根据 AP是哪个 A[3:2]即TDI[2:1](值为0b01) 选中寄存器P201 "Transfer Address, TAR",In the case of a APACC access, to read an access port register, by the combination of: the value shifted into A[3:2] P201 : Transfer Address, TAR 的 offset[3:2] 为 0b01 此时标志要 写 DATAIN[31:0]即 TDI[34:3]进入 "Transfer Address, TAR" // 注意 : 此次TDI传输了36bit, 高1位无效 根据 P203 "Transfer Address, TAR" 的定义 ,Address of the current transfer 为填充为 0x2000 0000 // 注意 (0x1 0000 0002 是 LSB) 写入后,会产生一次transter , 以 "Transfer Address, TAR" 中的值为地址, 读该地址中的内容到 该AP的 "Data Read/Write, DRW"寄存器 第3步 J-Link>readap 3 Reading AP register 3 = 0x12345678 (0 read repetitions needed) // 作用 : 之前已经选中"某AP的某bank",此时读 该bank 中的 第3(从0开始计数)个寄存器 // 参数分析 // writeap : 会产生 IR ,0b1011 , 选中 APACC // 3 : 选中 "Data Read/Write, DRW" jtag 时序 以 DDI0413C_cortexm1_r0p1_trm.pdf 分析 , 之后的 Pxx ,都是该书中的页码 分析 1. IR TDI 传入 0x1FB 之前已经选中APACC,而现在要操作 APACC 组的寄存器 所以,此时 必须 走 IR 链 选中 APACC 传入 0b1011 (同时TDO 0b0001) 选中 APACC // 但是 写入的是 9bit(0x1FB),高5位无效 2. DR TDI 传入 0x7 // LSB P149 : APACC P151 : RnW为1 ,表示读某个寄存器 //If RnW is shifted in as 1, the request is to read the value of the addressed register. // The value in DATAIN[31:0] is ignored. // You must read the scan chain again to obtain the value read from the register. P151 : 1. P151 : In the case of a APACC access, to read an access port register, by the combination of:the current value of the SELECT register in the DP, see AP Select Register,SELECT on page 9-63. 知道了当前选中的 AP 那哪个(上一条命令决定了是 AHB-AP) 2. 根据 AP是哪个 A[3:2]即TDI[2:1](值为0b11) 选中寄存器P201 "Data Read/Write, DRW",In the case of a APACC access, to read an access port register, by the combination of: the value shifted into A[3:2] P201 : Data Read/Write, DRW 的 offset[3:2] 为 0b11 此时标志要 读 P204 "Data Read/Write, DRW" 注意 : 之前讲述的 1. The value in DATAIN[31:0] is ignored. 2. You must read the scan chain again to obtain the value read from the register. TODO : 要读哪个寄存器? 猜测是 DPACC 中的 "Read Buffer" 3. DR TDI 传入 0x1FA // LSB 选中 DPACC 4. DR TDI 传入 0x7 , TDO 传出 0x91A2B3C2 // 实际传送了 36bit , 最高为无效 RnW 为1 ,表示读 TDI[2:1] 为 0b11 , 对应 P185 中的 "Read Buffer" TDI[34:3] 被忽略 TDO的[34:3] 是 value TDO[3] 是 第1个字节的最低位 0x91A2B3C2:000010010001101000101011001111000010 :{0} 0001 0010 0011 0100 0101 0110 0111 100[0] 010 // [0] 为 TDO[3] , {0} 为无效位 : 1 2 3 4 5 6 7 8
上一篇:ARM cortex-M4 DAP 访问 方法总结
下一篇:TQ2440 AD中断方式采集数据
推荐阅读最新更新时间:2024-11-13 23:46
设计资源 培训 开发板 精华推荐
- 单路数字量光电灰度传感器/巡线/物体感应
- 具有 10 位 ADC 和 I2C 监控功能的负电压热插拔控制器
- 具有四个输出的宽输入范围 3W 电源参考设计
- LT2940CMS 120W 电源监视器的典型应用电路包括 ICC
- Z8F04A28100KITG、Z8 Encore XP F042A 开发套件
- ZXLD1360EV13,基于ZXLD1360 LED驱动器的评估板
- LF90CPT-TR 9V 极低压降稳压器的典型应用
- SY88147DL 3.3V、1.25Gbps PECL限幅后置放大器的典型应用,具有高增益TTL信号丢失
- 具有突发模式操作的 LTC3130EUDC-1 宽输入电压范围 15V 转换器的典型应用
- AD8659ARZ-R7同相运算放大器配置的典型应用电路
