STM32ADC多通道转换描述:用ADC连续采集11路模拟信号,并由DMA传输到内存。ADC配置为扫描并且连续转换模式,ADC的时钟配置为12MHZ。在每次转换结束后,由DMA循环将转换的数据传输到内存中。ADC可以连续采集N次求平均值。最后通过串口传输出最后转换的结果。
程序如下:
#include“stm32f10x.h”//这个头文件包括STM32F10x所有外围寄存器、位、内存映射的定义
#include“eval.h”//头文件(包括串口、按键、LED的函数声明)
#include“SystickDelay.h”
#include“UART_INTERFACE.h”
#include
#defineN50//每通道采50次
#defineM12//为12个通道
vu16AD_Value[N][M];//用来存放ADC转换结果,也是DMA的目标地址
vu16After_filter[M];//用来存放求平均值之后的结果
inTI;
voidGPIO_ConfiguraTIon(void)
GPIO_InitTypeDefGPIO_InitStructure;
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;//因为USART1管脚是以复用的形式接到GPIO口上的,所以使用复用推挽式输出
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
//PA0/1/2作为模拟通道输入引脚
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN;//模拟输入引脚
//PB0/1作为模拟通道输入引脚
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1;
GPIO_Init(GPIOB,&GPIO_InitStructure);
//PC0/1/2/3/4/5作为模拟通道输入引脚
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
GPIO_Init(GPIOC,&GPIO_InitStructure);
voidRCC_Configuration(void)
ErrorStatusHSEStartUpStatus;
RCC_DeInit();//RCC系统复位
RCC_HSEConfig(RCC_HSE_ON);//开启HSE
HSEStartUpStatus=RCC_WaitForHSEStartUp();//等待HSE准备好
IF(HSEStartUpStatus==SUCCESS)
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//EnablePrefetchBuffer
FLASH_SetLatency(FLASH_Latency_2);//Set2Latencycycles
RCC_HCLKConfig(RCC_SYSCLK_Div1);//AHBclock=SYSCLK
RCC_PCLK2Config(RCC_HCLK_Div1);//APB2clock=HCLK
RCC_PCLK1Config(RCC_HCLK_Div2);//APB1clock=HCLK/2
RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_6);//PLLCLK=12MHz*6=72MHz
RCC_PLLCmd(ENABLE);//EnablePLL
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);//WaittillPLLisready
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//SelectPLLassystemclocksource
while(RCC_GetSYSCLKSource()!=0x08);//WaittillPLLisusedassystemclocksource
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB
|RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1|RCC_APB2Periph_AFIO|RCC_APB2Periph_USART1,ENABLE);//使能ADC1通道时钟,各个管脚时钟
RCC_ADCCLKConfig(RCC_PCLK2_Div6);//72M/6=12,ADC最大时间不能超过14M
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);//使能DMA传输
voidADC1_Configuration(void)
ADC_InitTypeDefADC_InitStructure;
ADC_DeInit(ADC1);//将外设ADC1的全部寄存器重设为缺省值
ADC_InitStructure.ADC_Mode=ADC_Mode_Independent;//ADC工作模式:ADC1和ADC2工作在独立模式
ADC_InitStructure.ADC_ScanConvMode=ENABLE;//模数转换工作在扫描模式
ADC_InitStructure.ADC_ContinuousConvMode=ENABLE;//模数转换工作在连续转换模式
ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;//外部触发转换关闭
ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right;//ADC数据右对齐
ADC_InitStructure.ADC_NbrOfChannel=M;//顺序进行规则转换的ADC通道的数目
ADC_Init(ADC1,&ADC_InitStructure);//根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
//设置指定ADC的规则组通道,设置它们的转化顺序和采样时间
//ADC1,ADC通道x,规则采样顺序值为y,采样时间为239.5周期
ADC_RegularChannelConfig(ADC1,ADC_Channel_0,1,ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_1,2,ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_2,3,ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_3,4,ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_8,5,ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_9,6,ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_10,7,ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_11,8,ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_12,9,ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_13,10,ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_14,11,ADC_SampleTime_239Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_15,12,ADC_SampleTime_239Cycles5);
//开启ADC的DMA支持(要实现DMA功能,还需独立配置DMA通道等参数)
ADC_DMACmd(ADC1,ENABLE);
ADC_Cmd(ADC1,ENABLE);//使能指定的ADC1
ADC_ResetCalibration(ADC1);//复位指定的ADC1的校准寄存器
while(ADC_GetResetCalibrationStatus(ADC1));//获取ADC1复位校准寄存器的状态,设置状态则等待
ADC_StartCalibration(ADC1);//开始指定ADC1的校准状态
while(ADC_GetCalibrationStatus(ADC1));//获取指定ADC1的校准程序,设置状态则等待
voidDMA_Configuration(void)
DMA_InitTypeDefDMA_InitStructure;
DMA_DeInit(DMA1_Channel1);//将DMA的通道1寄存器重设为缺省值
DMA_InitStructure.DMA_PeripheralBaseAddr=(u32)&ADC1-》DR;//DMA外设ADC基地址
DMA_InitStructure.DMA_MemoryBaseAddr=(u32)&AD_Value;//DMA内存基地址
DMA_InitStructure.DMA_DIR=DMA_DIR_PeripheralSRC;//内存作为数据传输的目的地
DMA_InitStructure.DMA_BufferSize=N*M;//DMA通道的DMA缓存的大小
DMA_InitStructure.DMA_PeripheralInc=DMA_PeripheralInc_Disable;//外设地址寄存器不变
DMA_InitStructure.DMA_MemoryInc=DMA_MemoryInc_Enable;//内存地址寄存器递增
DMA_InitStructure.DMA_PeripheralDataSize=DMA_PeripheralDataSize_HalfWord;//数据宽度为16位
DMA_InitStructure.DMA_MemoryDataSize=DMA_MemoryDataSize_HalfWord;//数据宽度为16位
DMA_InitStructure.DMA_Mode=DMA_Mode_Circular;//工作在循环缓存模式
DMA_InitStructure.DMA_Priority=DMA_Priority_High;//DMA通道x拥有高优先级
DMA_InitStructure.DMA_M2M=DMA_M2M_Disable;//DMA通道x没有设置为内存到内存传输
DMA_Init(DMA1_Channel1,&DMA_InitStructure);//根据DMA_InitStruct中指定的参数初始化DMA的通道
上一篇:零基础入门stm32知识学习的先后顺序
下一篇:stm32基础知识汇总有哪些是你不知道的呢
推荐阅读最新更新时间:2024-11-13 09:32
