1 /***************************************************
3 *u-boot版本 :u-boot-2014.10
5 *gcc版本 :/home/flinn/tools/4.4.3/bin/arm-none-linux-gnueabi-
7 *
9 *服务器 :ubuntu14.05
11 *
13 *编译命令 :make smdk2440_config;make
15 *Note(s) : 不要使用gcc-4.3.2(坑)
17 ***************************************************/
建立单板
tar xvf u-boot-2014.10.tar.bz2
cd u-boot-2014.10/
cp -r board/samsung/smdk2410/ board/samsung/smdk2440/
mv board/samsung/smdk2440/smdk2410.c board/samsung/smdk2440/smdk2440.c
vim board/samsung/smdk2440/Makefile
1 obj-y := smdk2440.o
cp include/configs/smdk2410.h include/configs/smdk2440.h
vim board/samsung/smdk2440/MAINTAINERS
1 SMDK2440 BOARD
3 M: David Müller 4 5 S: Maintained 6 7 F: board/samsung/smdk2440/ 8 9 F: include/configs/smdk2440.h 10 11 F: configs/smdk2440_defconfig vim board/samsung/smdk2440/Kconfig 1 if TARGET_SMDK2440 2 3 config SYS_CPU 4 5 default "arm920t" 6 7 config SYS_BOARD 8 9 default "smdk2440" 10 11 config SYS_VENDOR 12 13 default "samsung" 14 15 config SYS_SOC 16 17 default "s3c24x0" 18 19 config SYS_CONFIG_NAME 20 21 default "smdk2440" 22 23 endif vim arch/arm/Kconfig 1 config TARGET_SMDK2440 2 bool "Support smdk2440" 3 4 5 6 source "board/samsung/smdk2440/Kconfig" cp configs/smdk2410_defconfig configs/smdk2440_defconfig CONFIG_ARM=y CONFIG_TARGET_SMDK2440=y 修改顶层Makefile CROSS_COMPILE ?= /home/flinn/tools/4.4.3/bin/arm-none-linux-gnueabi- 修改配置文件include/configs/smdk2440.h -#define CONFIG_S3C2410 /* specifically a SAMSUNG S3C2410 SoC */ -#define CONFIG_SMDK2410 /* on a SAMSUNG SMDK2410 Board */ +#define CONFIG_S3C2440 +#define CONFIG_SMDK2440 编译 make smdk2440_defconfig make (如果要看到详细信息, 比如链接地址,-pie等, 执行make V=1) 如果修改smdk2440.h后编译报错 u-boot.lds:1: ignoring invalid character `#' in expression vim arch/arm/cpu/u-boot.lds -#include 以上单板建立完成, 初次编译会报错NAND和YAFFS相关的, 在smdk2440.h里面去掉相关宏 编译出来的u-boot.bin 约370K,前面的分区256K显然不够, 先作裁剪 去掉: USB相关的 //#define CONFIG_USB_OHCI //#define CONFIG_USB_OHCI_S3C24XX //#define CONFIG_USB_KEYBOARD //#define CONFIG_USB_STORAGE //#define CONFIG_DOS_PARTITION //#define CONFIG_CMD_USB 解压格式 //#define CONFIG_BZIP2 //#define CONFIG_LZO //#define CONFIG_LZMA 文件系统相关的 //#define CONFIG_CMD_FAT //#define CONFIG_CMD_EXT2 //#define CONFIG_CMD_UBI //#define CONFIG_CMD_UBIFS //#define CONFIG_CMD_MTDPARTS //#define CONFIG_MTD_DEVICE //#define CONFIG_MTD_PARTITIONS //#define CONFIG_YAFFS2 //#define CONFIG_RBTREE 再次编译后u-boot.bin文件才160K左右,满足我们的需求 执行: make smdk2440_defconfig make 即可编译
上一篇:u-boot-2014.10移植(2)设置时钟/SDRAM
下一篇:u-boot-2014.10移植(6)添加mtdparts命令和分区
推荐阅读最新更新时间:2024-11-11 11:02
设计资源 培训 开发板 精华推荐
- 400 kHz 和 2 MHz 下 A4450 5V 降压-升压控制器设计的典型应用电路
- 用于单个 MOSFET 应用的 LTC4367HDD-1 过压电源保护控制器的典型应用
- 使用 Analog Devices 的 LTC3803IS6-3 的参考设计
- MAX4090与重建滤波器的配合使用
- 显示 A8518 LED 驱动器灵活输入/输出电压比的 SEPIC 配置的典型应用
- AOZ1022DI-01 3A 同步降压稳压器典型应用
- ADK-1590、HI-1590 1553B 双路收发器,带 SPI 幅度控制评估板
- SSM2380 用于 SSM2380 2X2 W、无滤波器、立体声、D 类音频放大器的典型 ALC 模式原理图
- 具有电源排序功能的 LTC3589IUJ-1 8 输出稳压器的典型应用电路
- LTM8073IY 2.5Vout 4 至 15Vin 降压转换器的典型应用电路
