基于LTC2259-16的16位模-数转换方案
Linear 公司的LTC2259-16是 16位模-数转换器,适用于对高频宽动态范围的信号进行数字化.它的SNR为73.1dB,SFDR为88dB,单电源1.8V工作,功率89mW,具有CMOS, DDR CMOS 或DDR LVDS输出,可选择的输入范围从1VP-P 到 2VP-P,主要用于通信,蜂窝基站,SDR,手提医疗图像设备,多路数据采集和非破坏性测试.本文介绍了LTCR2259-16主要特性, 功能方框图, 采用变压器模拟输入(5MHz-70MHz)电路图,以及70MHz到170MHz, 170MHz到270MHz, 大于270MHz和采用高速差分放大器的前端输入电路图, LTC2259-16典型应用电路图.
The LTCR2259-16 is a sampling 16-bit A/D converter designed for digitizing high frequency, wide dynamic range signals. It is perfect for demanding communications applications with AC performance that includes 73.1dB SNR and 88dB spurious free dynamic range (SFDR). Ultralow jitter of 0.17psRMS allows undersampling of IF frequencies with excellent noise performance. DC specs include ±4LSB INL (typical) and ±0.5LSB DNL (typical).
The digital outputs can be either full-rate CMOS, doubledata rate CMOS, or double-data rate LVDS. A separate output power supply allows the CMOS output swing to range from 1.2V to 1.8V.
The ENC+ and ENC– inputs may be driven differentially or single ended with a sine wave, PECL, LVDS, TTL or CMOS inputs. An optional clock duty cycle stabilizer allows high performance at full speed for a wide range of clock duty cycles.
LTCR2259-16主要特性:
73.1dB SNR
88dB SFDR
Low Power: 89mW
Single 1.8V Supply
CMOS, DDR CMOS or DDR LVDS Outputs
Selectable Input Ranges: 1VP-P to 2VP-P
800MHz Full-Power Bandwidth S/H
Optional Data Output Randomizer
Optional Clock Duty Cycle Stabilizer
Shutdown and Nap Modes
Serial SPI Port for Configuration
40-Pin (6mm x 6mm) QFN Package
LTCR2259-16应用:
Communications
Cellular Base Stations
Software Defi ned Radios
Portable Medical Imaging
Multi-Channel Data Acquisition
Nondestructive Testing
图1.LTCR2259-16功能方框图
图2.LTCR2259-16采用变压器模拟输入(5MHz-70MHz)电路图
图3.LTCR2259-16 70MHz到170MHz前端输入电路图
图3.LTCR2259-16 170MHz到270MHz前端输入电路图
图4.LTCR2259-16 大于270MHz前端输入电路图
图5.LTCR2259-16 采用高速差分放大器的前端输入电路图
图6.LTC2259-16 应用电路
上一篇:AD转换器LTC1286围电路原理图
下一篇:增量累加ADC以高24位的精确度测量小模拟信号
- 热门资源推荐
- 热门放大器推荐
- Allegro MicroSystems 在 2024 年德国慕尼黑电子展上推出先进的磁性和电感式位置感测解决方案
- 左手车钥匙,右手活体检测雷达,UWB上车势在必行!
- 狂飙十年,国产CIS挤上牌桌
- 神盾短刀电池+雷神EM-i超级电混,吉利新能源甩出了两张“王炸”
- 浅谈功能安全之故障(fault),错误(error),失效(failure)
- 智能汽车2.0周期,这几大核心产业链迎来重大机会!
- 美日研发新型电池,宁德时代面临挑战?中国新能源电池产业如何应对?
- Rambus推出业界首款HBM 4控制器IP:背后有哪些技术细节?
- 村田推出高精度汽车用6轴惯性传感器
- 福特获得预充电报警专利 有助于节约成本和应对紧急情况
