NCP1308设计的50W四输出STB电源技术
最新更新时间:2011-05-08来源: 互联网 手机看文章 扫描二维码
随时随地手机看文章
本文介绍了NCP1308主要特性, 内部电路架构图, 典型应用电路图以及50W四输出机顶盒(STB)电源电路图和材料清单(BOM).
NCP1308控制器把电流模式调制器和退磁检测器集成在一起,可以在任何的负载/线路条件下保证有更宽的导通模式,过流保护自动恢复,内部软起动时间1.0s,在AC/DC转换器和离线电池充电器等有广泛用途.
NCP1308主要特性:
Free-Running Borderline/Critical Mode Quasi-Resonant Operation
Current-Mode with Adjustable Skip Cycle Capability
Dynamic Self-Supply Type of VCC
Auto-Recovery Overcurrent Protection
Improved UVLO for VCC below 10 V
Latching Overvoltage Protection on VCC
500 mA Peak Current Source/Sink Capability
Internal 1.0 ms Soft-Start
Internal 10us Minimum TOFF
Adjustable Skip Level
Internal Temperature Shutdown
Internal Leading Edge Blanking
Direct Optocoupler Connection
SPICE Models Available for TRANsient Analysis
This is a Pb-Free Device
NCP1308典型应用:
AC-DC Adapters for Notebooks, etc.
Offline Battery Chargers
Consumer Electronics (DVD Players, Set-Top Boxes, TVs, etc.)
Auxiliary Power Supplies (USB, Appliances, TVs, etc.)
图1.NCP1308内部电路架构图
图2.NCP1308典型应用电路图
50W四输出机顶盒(STB)电源
This reference document describes a built--and--tested, GreenPoint® solution for a 40 W (40 W nominal power, 50 W peak power) set--top box (STB) power supply. This document presents the results of various secondary rectification and regulation techniques thatwere used to find the highest practical efficiency scheme for a four--output, 40 watt set top box power supply.
The power supply design is built around ON Semiconductor’s NCP1308 Current--Mode controller, on the primary side, using free running quasi—resonance operation. The secondary side offers four outputs (+5 V, --5 V, 3.3 V and 12 V). The +5 V output is the main channel with the closed PWMloop while the 3.3 Voutput is derived by using the NCP1587 in a buck (step--down) DC—DC topology with synchronous rectification. The 12Voutput is derived from+5 V by stacking the 12 V secondary winding onto the 5 V winding.
图3.参考设计电路简化框图
图4.50W四输出机顶盒(STB)电源外形图
图5.机顶盒(STB)电源电路图
50W四输出机顶盒(STB)电源材料清单(BOM):
编辑:神话 引用地址:NCP1308设计的50W四输出STB电源技术
上一篇:变频器容量的正确选择
下一篇:低消耗电流电压调整器XC6503
小广播
最新电源管理文章
换一换 更多 相关热搜器件
站点相关:
词云: 1 2 3 4 5 6 7 8 9 10
