热电偶预放大器-Thermocouple Pre Amp
最新更新时间:2011-05-27来源: 互联网 手机看文章 扫描二维码
随时随地手机看文章
Abstract: Using a preamp to increase the output magnitude of a J-type thermocoupler. The simple circuit provides compensation over temperature as well as calibration capability.
The MAX430 is operated at a gain of 191 to convert the 52µV/°C output of the type J thermocouple to a 10mV/°C signal. The -2.2mV/°C tempco of the 2N3904 is added into the summing junction with a gain of 42.2 to provide cold junction compensation. The ICL8069 is used to remove the offset caused by the 600mV initial voltage of the 2N3904. Adjust the 10K trimpot for the proper reading with the 2N3904 and isothermal connection block at a temperature near the center of the circuit's operating range.
Use the component values shown in parentheses when using a type K thermocouple.
Figure 1
编辑:神话 引用地址:热电偶预放大器-Thermocouple Pre Amp
上一篇:采用DSP的电源控制系统的软硬件开发
下一篇:电流限制电路的降压稳压器-Current-Limit Cir
小广播
最新电源管理文章
换一换 更多 相关热搜器件
站点相关:
词云: 1 2 3 4 5 6 7 8 9 10
