用于下一代汽车无刷直流系统的汽车功率集成模块
发布者:zhihua最新更新时间:2018-04-22 来源: 社区化关键字:pim  MOSFET 手机看文章 扫描二维码
随时随地手机看文章
    On Semi公司的STK984-190-E是用于下一代汽车无刷直流系统的汽车功率集成模块(PIM),包含6个40 V/30 A MOSFET配置为一个三相桥,及一个额外的40 V/30 A高边反向电池保护MOSFET.模块适用于12 V汽车电机驱动应用,额定功率达300 W,如电动泵,风机和挡风玻璃雨刮.工作温度范围为-40°C至150°C.所有集成的MOSFET都通过AEC-Q101认证.本文介绍了STK984-190-E主要特性,框图,典型应用电路,以及40V 30A DIP MOSFET功率模块评估板STK984-190-EGEVB主要特性,电路图,材料清单和PCB设计图.
  The STK984-190-E is a MOSFET power module containing 6 MOSFETsin a three-phase bridge (B6) configuraTIon and a seventh MOSFET usedas a reverse battery protecTIon switch. The compact module is 29.6 mmx18.2 mm and is 4.3 mm high (see package drawing for specificaTIondetails)。 The MOSFET module uses a DBC substrate for excellentthermal performance. The module is suitable for 12 V automoTIve andindustrial applications with motors rated up to 300 W.
  STK984-190-E主要特性:
  Three-phase MOSFET bridge with reverse battery protection switch
  Device is PPAP capable.
  Compact 29.6 mmx18.2 mm dual in-line package
  Motor power up to 300 W for 12 V systems
  40 V MOSFETs with 30 A continuous and 85 A pulse current ratings
  RDS(ON) = 9.5 mohmmax
  QGD = 9.8 nC typical
  STK984-190-E应用:
  Automotive Pumps
  Automotive Fans
  12 V Industrial Motors
图1.STK984-190-E功能框图
图2.STK984-190-E应用案例电路图
评估板STK984-190-EGEVB:40V 30A DIP MOSFET功率模块评估板
The STK984-190-EGEVB is designed to evaluate the STK984-190E, a MOSFET power module containing 6 MOSFETs in a three-phase bridge (B6) configuration and a seventh MOSFET used as a reverse battery protection switch. The MOSFET module uses a DBC substrate for excellent thermal performance and is suitable for 12 V automotive and industrial applications with motors rated up to 300 W.
图3.评估板STK984-190-EGEVB外形图
图4.评估板STK984-190-EGEVB电路图
评估板STK984-190-EGEVB材料清单:
图5.评估板STK984-190-EGEVB PCB设计图
关键字:pim  MOSFET 引用地址:用于下一代汽车无刷直流系统的汽车功率集成模块
上一篇:FM4 S6E2C系列主要特性和框图
下一篇:ADI ADSP-SC57x/2157x系列处理器
推荐阅读最新更新时间:2024-07-25 20:04
东芝面向快速充电器推出100V N沟道功率MOSFET
东芝公司(TOKYO:6502)旗下存储与电子元器件解决方案公司今日宣布面向快速充电器推出支持4.5V逻辑电平驱动的100V N沟道功率MOSFET,以此扩大其低电压N沟道功率MOSFET的产品阵容。“U-MOS VIII-H系列”的两款新MOSFET分别是“TPH4R10ANL”和“TPH6R30ANL”,产品出货即日启动。 随着快速充电器的普及和发展,市场需要更高性能的用于次级侧整流器的功率MOSFET。这些新的MOSFET利用东芝低电压沟槽结构工艺,实现了业界领先的 低导通电阻和高速性能。该结构降低了“RDS(ON) * Qsw” 的性能指标,改善了开关应用。通过减小输出电荷,实现输出损耗改善,有助于提高装置效率。而且,
[手机便携]
东芝面向快速充电器推出100V N沟道功率<font color='red'>MOSFET</font>
TI 推出在高电流下实现高效率的同步 MOSFET 半桥
德州仪器 (TI) 宣布推出一款可在 25 A 电流下实现超过 90% 高效率的同步 MOSFET 半桥,其占位面积仅为同类竞争功率 MOSFET 器件的 50%。TI 全新 CSD86350Q5D 功率模块通过高级封装将 2 个非对称 NexFET 功率 MOSFET 进行完美整合,可为服务器、台式机与笔记本电脑、基站、交换机、路由器以及高电流负载点 (POL) 转换器等低电压同步降压半桥应用实现高性能。 NexFET 功率模块除提高效率与功率密度外,还能够以高达 1.5 MHz 的开关频率生成高达 40 A 的电流,可显著降低解决方案尺寸与成本。优化的引脚布局与接地引线框架可显著缩短开发时间,改善整体电路性能。此
[电源管理]
浅谈三极管和MOS管作开关用时的区别
  我们在做电路设计中三极管和MOS管做开关用时候有什么区别。    工作性质:   1.三极管用电流控制,MOS管属于电压控制。   2、成本问题:三极管便宜,MOS管贵。   3、功耗问题:三极管损耗大。   4、驱动能力:MOS管常用来电源开关,以及大电流地方开关电路。   实际上就是三极管比较便宜,用起来方便,常用在数字电路开关控制。   MOS管用于高频高速电路,大电流场合,以及对基极或漏极控制电流比较敏感的地方。   一般来说低成本场合,普通应用的先考虑用三极管,不行的话考虑MOS管   实际上说电流控制慢,电压控制快这种理解是不对的。要真正理解得了解双极晶体管和MOS晶体管的工作方式才能明白。三极管是
[电源管理]
智能MOSFET提高医疗设计的可靠性同时提升性能
    所有的医疗应用在要求高可靠性的同时仍然要为最终用户提供所需的技术进步。由于各医疗设备公司间竞争激烈,他们的最终应用、功能急剧增加,但是没有考虑到另外一个可能的失效点的影响。在所有这些点都需要电源,并且采用最新技术进展来使风险最小化是非常重要的。     智能MOSFET是促进医疗应用一直普遍增长的动因之一。由于标准P沟道(P-channel) FET的驱动要求简单,它常常被用于转换电源分配节点、连接充电路径、连接器热插拔、直流电流等等。因为这些器件处于关键线路中,其失效会导致下游传感器或处理器不工作,因而在稳固的功率开关方面进行投资是明智的。相比等效P沟道/N沟道组合方法,Intellimax FET集成了P沟道FET
[电源管理]
智能<font color='red'>MOSFET</font>提高医疗设计的可靠性同时提升性能
凌力尔特推出高速同步N型MOSFET 驱动器
凌力尔特公司推出LTC4444-5 的高可靠性 (MP) 级新版本,该器件是一个高速、高输入电源电压 (100V)、同步 MOSFET 驱动器,以在同步整流转换器拓扑中驱动高端和低端 N 沟道功率 MOSFET。该驱动器与功率 MOSFET 和凌力尔特诸多 DC/DC 控制器中的一款组合起来,形成了一个完整的高效率同步稳压器。LTC4444MP-5 可在 -55°C 至 125°C 的结温范围内运作并进行了全面的测试,而“ I ”等级器件版本的工作温度范围则为 -40°C 至 85°C。 利用一个 1.5Ω 上拉阻抗,这款强大的驱动器能够供应一个高达 1.4A 的电流 (用于驱动高端 MOSFET);而利用一个 0.
[电源管理]
美格纳推出第三代200V MV MOSFET
9月6日,美格纳半导体公司(Magnachip Semiconductor)宣布推出用于轻型电动汽车(LEV)电机控制器和工业电源的第三代200V中压(MV)金属氧化物半导体场效应晶体管(MOSFET)。 图片来源:美格纳
[汽车电子]
美格纳推出第三代200V MV <font color='red'>MOSFET</font>
罗姆第4代SiC MOSFET在电动汽车电控系统中的应用及其优势
引言 近年来,为了实现“碳中和”等减轻环境负荷的目标,需要进一步普及下一代电动汽车(xEV),从而推动了更高效、更小型、更轻量的电动系统的开发。尤其是在电动汽车(EV)领域,为了延长续航里程并减小车载电池的尺寸,提高发挥驱动核心作用的电控系统的效率已成为一个重要课题。SiC(碳化硅)作为新一代宽禁带半导体材料,具备高电压、大电流、高温、高频率和低损耗等独特优势。因此,业内对碳化硅功率元器件在电动汽车上的应用寄予厚望。 罗姆第4代SiC MOSFET应用于“三合一”电桥 近日,上汽大众与臻驱科技联合开发的首款基于SiC技术的 “三合一”电桥完成试制。据悉,对比现有电桥产品,这款SiC“三合一”电桥在能耗表现方面非常抢
[汽车电子]
罗姆第4代SiC <font color='red'>MOSFET</font>在电动汽车电控系统中的应用及其优势
低压MOSFET器件 | 云潼科技确认申报2024金辑奖
申请技术丨低压MOSFET器件 申报领域丨智能座舱 独特优势: 一方面,本系列产品按照车规标准进行设计和测评认证,率先在智能座舱热管理和舒适模块领域实现国产替代和批量应用。另一方面,本系列产品针对12V市场低电压平台的小功率电磁阀驱动市场,使用单管驱动两路电磁阀,控制气阀的开关,对此应用进行了充分的调研和研发,具有成本低、性能稳定、使用寿命长等优点,产生了良好的经济效益,弥补了国内新能源座椅关键零部件产业链空缺。 应用场景: 云潼该系列产品在国内知名智能座舱热管理龙头企业及舒适模块龙头企业大批量应用到汽车智能座舱热管理及舒适模块的驱动。终端搭载到大众、广汽、长安、理想、比亚迪、吉利、长城等车企。 未来前景:
[汽车电子]
低压<font color='red'>MOSFET</font>器件 | 云潼科技确认申报2024金辑奖
小广播
最新汽车电子文章
换一换 更多 相关热搜器件
