最近在Kickstarter网站上,Valent F(x)团队正在为LOGi FPGA开发板的生产筹备资金。
LOGi 是fpga开发与arm平台的结合。Valent F(x)团队开发了可以支持树莓派和Beaglebone上开发的FPGA开发板,LOGi系列。它让FPGA开发与入门变得简单,同时趋于统一现存硬件接口和开源开发平台,如树莓派和Beaglebone Black这两个流行的开源开发平台。
Valent F(x)团队分别针对树莓派和Beaglebone Black开发了两个版本的LOGi板,如下图的LOGi-Pi和LOGi-Bone。LOGi-Pi的FPGA板的底部连接器可与树莓派的GPIO头连接,LOGi-Bone的FPGA板有两行的连接器可与Beaglebone Black 2x46引脚头相连接。不需要JTAG或者繁杂的命令,只需要在树莓派或者Beaglebone Black平台的终端输入logi_loader.bit,就可以运行LOGi板。
LOGi-Pi for the Raspberry Pi
LOGi-Pi 的基本技术参数:
Xilinx Spartan 6 LX9 FPGA 9,152 Logic Cells, 16 DSP48A1 Slices, 576Kb RAM
Plug-and-Play Interfacing for the Raspberry Pi 4 Layer Optimized Design to Support Maximum Performance of High Bandwidth Applications Length-tuned GPMC, SDRAM, LVDS Signals
3.3V I/O Regulator and 1.2V Core Regulator
256 Mb SDRAM connected to the FPGA
2x LEDs 2x Push Buttons 2x DIP Switches
1x High Bandwidth SATA connector expansion, port Length tuned and impedance routed differential signals for maximum bandwidth (Designed for modular LVDS expansion, Not SATA devices - see FAQ on SATA connector)
2x Digilent Inc. PMOD ports supporting 59+ plug-and-play hardware modules
1x Arduino compatible headers connected to the FPGA pins (3.3V only) Supports over 200+ Arduino Shield Modules
10x Length-tuned LVDS Pairs 32 FPGA I/O available through PMOD and Arduino headers
Connection to the SPI Interface of the Raspberry Pi (3.8 MBps maximum Bandwidth)
Connection to 16 I/O of the Raspberry Pi expansion port (including SPI, UART, I2C and GCLK and GPIO).
Bit-Stream loading interface connected to the host processor, optional bitstream FPGA self-loading from onboard Flash.
LOGi-Bone for the Beaglebone
LOGi-Bone的基本技术参数:
- Xilinx Spartan 6 LX9 TQFP-144 FPGA 9,152 Logic Cells, 16 DSP48A1 Slices, 576Kb RAM
- Beaglebone Black Optimized 4 Layer Optimized Design to Support Maximum Performance of High Bandwidth Applications Length-tuned GPMC, SDRAM, LVDS Signals 3.3v I/O Regulator and 1.2v Core
- Regulator 256 Mb SDRAM connected to the FPGA
- 2x LEDs 2x Push Buttons 2x DIP Switches
- 1x High Bandwidth SATA connector expansion port, Length tuned and impedance routed differential signals for maximum bandwidth (Designed for modular LVDS expansion, Not SATA devices - see FAQ on SATA connector)
- 2x Digilent Inc. PMOD ports supporting 59+ plug-and-play hardware modules
- 1x Arduino compatible headers connected to the FPGA pins (3.3V only) Supports over 200+ Arduino Shield Modules
- Optional GPMC, SPI or I2C port access from the Beaglebone Black
- 10x Length-tuned LVDS Pairs
- Bit-Stream loading interface connected to the host processor, optional bitstream FPGA self-loading from onboard Flash.
更多内容请参见网站:https://www.kickstarter.com/projects/1575992013/logi-fpga-development-board-for-raspberry-pi-beagl
关键字:LOGi FPGA开发 树莓派 Beaglebone
引用地址:
LOGi FPGA 开发板:可在树莓派和Beaglebone上开发FPGA
推荐阅读最新更新时间:2024-05-02 22:57
改造树莓派Pico 让鼠标在初代PS上运行
开发者使用 Vojtěch Salajka 使用树莓派 Pico 创建了一个全新的适配器,可以让鼠标在初代 PlayStation 上运行。Salajka 是一位微型电路的资深玩家,在其 Franticware 网站上分享了他创作的大量作品。 这个项目并不需要对 PS1 进行内部改造,但需要一条兼容 PS1 主机端口的线缆。因此适合 PS1 的第三方游戏手柄是不错的选择,用户只需剪断手柄的线缆,然后将电线剥离出来。 然后 Salajka 提供了将线焊接到 Pico 的示意图,通过 Pico 上的迷你 PFM 控制 DC-DC USB 0.9V-5V to 5V DC 来提供电源。虽然目前并没有太多 PS1 游戏支持鼠标方
[手机便携]
Altera采用Intel的14 nm三栅极技术开发下一代高性能FPGA
2013年2月26号,北京——Altera公司和Intel公司今天宣布,双方已经达成协议,未来将采用Intel的14 nm三栅极晶体管技术制造Altera FPGA。这些下一代产品主要面向军事、固网通信、云网络以及计算和存储应用等超高性能系统,将突破目前其他技术无法解决的性能和功效瓶颈问题。 Altera总裁、主席兼CEO John Daane评论说:“Altera FPGA使用Intel 14 nm技术,帮助客户设计业界最先进、性能最好的FPGA。而且,Altera是唯一使用这一技术的主要FPGA公司,获得了极大的竞争优势。” Altera的下一代产品除了已经发布的20 nm技术产品,现在还将包括14 nm产品
[嵌入式]
终于有人讲清楚了树莓派是什么
树莓派是尺寸仅有信用卡大小的一个小型电脑,您可以将树莓派连接电视、显示器、键盘鼠标等设备使用。 树莓派能替代日常桌面计算机的多种用途,包括文字处理、电子表格、媒体中心甚至是游戏。并且树莓派还可以播放高至1080p的高清视频。 我们希望将树莓派推广给全世界的青少年电脑爱好者,用于培养计算机程序设计的兴趣和能力。 树莓派各版本发布时间和差异对照? 树莓派设计 RaspberryPi配备了一颗ARM11系列,主频为700M的CPU,以SD卡为内存硬盘,卡片主板周围有两个USB接口和一个网口,可连接键盘、鼠标和网线。同时拥有视频模拟信号的电视输出接口和HDMI高清视频输出接口,以上部件全部整合在一张仅比信用卡稍大
[嵌入式]
EnOcean推出适合树莓派的家庭智能网关附件
日前,EnOcean CEO Laurent Giai-Miniet撰文称赞,Raspberry Pi是低功耗智能家庭网关的完美解决平台。 Laurent称:Raspberry Pi,这个信用卡般大小的电路板,拥有者强大的功能,和其他简单的开发板并不相同。其问世第一年就售出了100万块,如果连起来的话,相当于一万辆双层巴士。 Pi是灵活与高性能的结合,拥有众多外设端口可以接驳,包括USB、HDMI、SD卡、以太网等。 爱好者们以Pi为基础,开发出众多垂直应用,其中之一就为家庭自动化。 EnOcean一直专注于无限能量采集技术,具体包括能量采集和转换、无线通信以及超低功耗芯片组。正因为Pi无论在产品性能、普及度以及适用人群等
[嵌入式]
e络盟为树莓派增加Hi-Fi功能
英国几家电子相关企业的联合愈发紧密了:这次是e络盟、欧胜和树莓派的合作。 日前,e络盟联合Wolfson宣布为树莓派开发了HiFi扩展板,基于Wolfson的WM5102音频扩展芯片,令树莓派可以支持多路音频输入输出。 该芯片内置D类放大器,信噪比达到了113dB,耳机参数为(32Ω时总谐波失真 0.1%,功率为29mW。 同时开发板板载了一MEMS麦克风,输入信噪比为96dB,还支持SPDIF输入输出插口。 目前,e络盟官方网站已开始提供相应的软件下载,同时e络盟表示,未来将提供对于Rasbian系统的支持。
[嵌入式]
米尔瑞米派Remi Pi Ubuntu系统移植指南
概述 Linux系统平台上有许多开源的系统构建框架,这些框架方便了开发者进行嵌入式系统的构建和定制化开发,目前比较常见的有Buildroot, Yocto, OpenEmbedded等等。 同时更多的传统的桌面系统也加入到嵌入式环境体系中,如Ubuntu,debian等,为嵌入式提供更方便实用的系统。本文主要介绍基于ubuntu22.04 core和米尔核心板定制一个完整的嵌入式ubuntu22.04系统的完整流程,其中包括开发环境的准备,ubuntu22.04系统的获取与移植, LXDE轻量级桌面管理等。 本文档并不包含Linux BSP系统相关基础知识的介绍,将直接使用米尔发布的myir-image-fu
[嵌入式]
ARM与FPGA沟通的桥梁—米尔PYNQ开发板
前言:PYNQ全称为Python Productivity for Zynq,即在Zynq全可编程ARM&FPGA融合处理架构的基础上,添加了对Python的支持。 PYNQ希望能够借助Python语言本身易用易学、扩展库多而全、社区活跃贡献度高等特性,有效降低Zynq嵌入式系统的开发门槛,并为人工智能,ADAS,机器视觉等高拓展性/高复杂度应用需求提供更好支撑。PYNQ将ARM处理器与FPGA器件的底层交互逻辑完全封装起来,顶层封装使用python,只需要import对应的模块名称即可导入对应的硬件模块,即可进行底层到上层数据的交互或者为系统提供硬件加速。 PYNQ突出优点在于:可直接调用Python库和FPGA硬
[嵌入式]
e络盟推出树莓派计算模块开发套件
e络盟日前宣布推出最新系列扩展开发工具套件树莓派计算模块开发套件,以帮助设计工程师充分利用树莓派(Raspberry Pi)在嵌入式应用中的强大功能。 原版树莓派全球销量已超过300万片且应用范围广泛,既适用于初学计算的儿童,也适用于外太空探索。用户可访问 e络盟 Pi开发项目获取大量优秀的应用开发案例。由于树莓派成本低、性能高且具备功能稳定的支持包,许多设计工程师开始在其终端系统设计中集成完整的树莓派装置。随着树莓派越来越被广泛应用于工业及嵌入式应用当中,其开发工程师开始构思如何以更加灵活的规格帮助工程师发挥传统开发板的优势, 于是树莓派计算模块便应运而生。 树莓派计算模块使设计工程师能够使用各自的接口板插装计
[嵌入式]
