Austriamicrosystems公司的AS3645是超小型高效单/双路LED闪光驱动器,它的DC/DC升压转换器工作频率高达2MHz,具有软起动功能,闪光停止,过压,超稳,欠压和LED短路保护功能.单路闪光LED电流高达700mA, 双路闪光LED电流高达1000mA,主要用于手机,数码相机和PDA的闪光/火炬.本文介绍AS3645主要特性, 内部方框图,以及典型工作电路图, 采用基带I2C模式, 照相机I2C模式和并行接口模式的应用电路图.
AS3645:1000/720mA Ultra Small High efficient single/dual LED Flash Driver with Safety Features
The AS3645 is an inductive high efficient DCDC step up converter with two current sources. The DCDC step up converter operates at a fixed frequency of 2MHz and includes soft startup to allow easy integration into noise sensitive RF systems. The two current sources (one for driving one or two flash LEDs and one for the indicator LED) can operate in flash / torch / assist (=video) light / indicator modes. If a two flash LEDs configuration is used, the LEDs are connected in series. Therefore identical current is guaranteed.
The AS3645 includes flash timeout, overvoltage, overtemperature, undervoltage and LED short circuit protection functions.
The AS3645 can be controlled either with parallel interface mode to allow simple integration. Alternatively it can be controlled by I2C mode to allow a more sophisticated
control of all settings like currents and timings.
The interface is selected by a dedicated pin (I2C/EN). The AS3645 is available in a space-saving WL-CSP package measuring only 2x1.6mm and operates over the -30℃ to +85℃ temperature range.
AS3645主要特性:
High efficiency 2MHz fixed frequency DCDC Boost converter with soft start allows small coils
- Stable even in coil current limit
High Flash LED(s) current (720mA for single flash LED, 1000mA (2x500mA) for dual flash LED)
Separate Indicator LED output
Flash LED(s) cathode connected to ground:
Improved thermal performance (ground = heat sink)
Simplified PCB layout
Flash, Torch, Assist and Indicator Mode
Protection functions:
Automatic Flash Timeout timer to protect the LED(s)
Overvoltage and undervoltage Protection
Overtemperature Protection
LED(s) short circuit protection
Dual Interface selectable by pin (parallel interface mode and I2C mode)
Available in tiny WL-CSP Packages
3x4 balls 0.5mm pitch, 2x1.6mm package size
AS3645应用:
Flash/Torch for mobile phones, digital cameras and PDA
图1.AS3645内部方框图
图2.AS3645典型工作电路图
图3.AS3645采用基带I2C模式的应用电路图
图4.AS3645采用照相机I2C模式的应用电路图
图5.AS3645采用并行接口模式的应用电路图
上一篇:高取光率低热阻功率型LED封装技术
下一篇:基于CY8CLEDAC02的17W LED驱动器设计方案
推荐阅读最新更新时间:2023-10-18 15:46
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- 易灵思® 宣布 AEC-Q100 资质认证和汽车系列产品计划
- 49-基于51单片机的PM2.5和温湿度检测报警
- STM8单片机 ADC模拟看门狗中文资料错误
- 三星Galaxy M52 5G完整规格解密:6.7英寸全高清屏
- 使用Code Composer Studio开发MSP430 - GPIO外部中断
- 汽修专用示波器检测汽车执行器可变气门正时信号
- 阀门气密性测试仪是如何进行,医疗卫生级阀门气密性测试要点
- NDI和RTSP、RTMP、HLS它们的协议区别是什么
- 福瑞泰克推出基于单颗地平线征程®3芯片的行泊一体方案
- 异构集成推动面板制程设备(驱动器)的改变 异构集成(HI)已成为封装技术最新的转折点
