采用NXP公司 SSL2101 的7.5W 120V可调光的LED驱动器的参考设计采用反激式转换器,提供隔离的解决方案。参考设计支持5个LED(输出电流470mA)和7个LED(输出电流340mA)负载,输出功率大约为7.5W,效率大约为72%,适合于GU10灯。本文介绍了7.5W反激LED驱动参考设计主要指标,驱动5个和7个LED的演示板电路图以及相应的材料清单和PCB布局图。
SSL2101 120 V 7.5 W GU10 flyback reference board
This document explains the operation and application of a 7.5 W 120 V dimmable LED driver featuring the SSL2101. The demo board has a form factor that is compatible with the base of a GU10 LED lamp. The board employs a flyback converter to provide an isolated solution for mains-dimmable LED recessed-light applications.
The board is available in two different versions, designed to support both a 5-LED and 7-LEDs load with an output power of approximately 7.5 W. The board operates at approximately 45 kHz and produces a regulated output current of 470 mA for the 5-LED load or 340 mA for the 7-LED load, with an efficiency of around 72 %. Both versions are fully compliant with EMC regulations. Key features of the board include:
• Deep dimming capability
• Wide dimming compatibility
• Small form factor tailored to fit a GU10 lamp
• Cost effectiveness
图1。SSL2101演示板外形图(顶视图)
7.5W反激LED驱动参考设计主要指标:
图2。驱动5个LED的演示板电路图
图3。驱动7个LED的演示板电路图
5个LED负载的SSL2101 120 V 演示板材料清单:
7个LED负载的SSL2101 120 V 演示板材料清单:
图4。演示板元件布局图
图5。演示板变压器主要指标
详情请见:
http://www.nxp.com/documents/user_manual/UM10479.pdf
上一篇:线性和开关型两种LED驱动方案的优缺点
下一篇:详解LED背光液晶电视区域调光技术的机遇与难题
推荐阅读最新更新时间:2023-10-18 16:04
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
