TI(NS)LM3549高效大功率RGBLED驱动方案
最新更新时间:2011-11-26来源: chinaaet关键字:电源管理  LED驱动器  DC/DC转换器 手机看文章 扫描二维码
随时随地手机看文章
TI(NS )公司的LM3549是输出电流高达700mA的高效大功率RGB LED驱动器,它有三个恒流LED驱动器和一个降压升压开关电源(SMPS),用来高效地驱动RGB LED.LM3459具有过流和超温保护,I2C兼容接口以及欠压锁住, 降压升压转换器的峰值效率95%,主要用在手持视频投映仪和大功率LED驱动.本文介绍了LM3549主要特性和指标,方块图,典型应用电路以及评估板电路图和材料清单.
The LM3549 is a high power LED driver with up to 700mA output current. It has three constant current LED drivers and a buck boost SMPS for driving RGB LEDs with high efficiency.
LED drivers are designed for sequential drive so only one driver can be enabled at a time.
LED driver output current settings can be stored to integrated non-volatile memory which allows stand-alone operation without I2C interface. Non-volatile memory is rewritable so current setting can be changed if needed.
LM3549 has a fault detection feature that can detect several different fault conditions. In case of a fault error flags are set and FAULT output sends interrupt to control logic. Error flags can be read through I2C interface.
Total brightness can be controlled with PWM input or with master fader register if I2C interface is used.
LM3549主要指标:
■ Integrated buck-boost converter
■ Programmable LED drivers
■ 700 mA maximum drive current
■ ±6% Current accuracy over temperature
■ 24-pin LLP package
LM3549主要特性:
■ Over-current protection
■ Over-temperature protection
■ I2C compatible interface
■ Under-voltage lockout
■ LED open and short protection and detection
■ 95% peak efficiency buck-boost converter
■ NVM memory for calibration data and standalone usage without I2C control
■ Soft start
LM3549应用:
■ Portable video projectors
■ High power LED driving
图1. LM3549方框图
图2. LM3549典型应用电路图
LM3549评估板
LED drivers are designed for sequential drive so only one driver can be enabled at a time.LED driver output current settings can be stored to integrated non-volatile memory which allows stand-alone operation without I2C interface. Non-volatile memory is rewritable so current setting can be changed if needed.
LM3549 Evaluation board is designed to help getting familiarized with the LM3549. It can be used to measure key parameters of the LM3549 and to speed up design in of the device. The evaluation board has a microcontroller that acts as an USB to I2C interface. Microcontroller is also used to manipulate the digital control signals of the LM3549. LM3549 evaluation board can be powered from the USB interface or from external power supply. If evaluation board is used to measure the electrical parameters of the LM3549 or used with high output currents external power supply needs to be used.
If evalution board is used to check the functionality of the LM3549 with small output currents or to support software development it can be powered directly from USB interface. This document describes how to get the LM3549 evaluation board up and running and how to use evaluation software.
图3. LM3549评估板外形图
图4. LM3549评估板电路图
LM3549评估板材料清单:
详情请见:
http://www.national.com/ds/LM/LM3549.pdf
http://www.national.com/an/AN/AN-2062.pdf
关键字:电源管理  LED驱动器  DC/DC转换器 编辑:探路者 引用地址:TI(NS)LM3549高效大功率RGBLED驱动方案
上一篇:LED驱动电源方案全攻略
下一篇:如何设计更高能效的OLED电源
推荐阅读最新更新时间:2023-10-18 16:09
替代MR16 LED应用的 LED驱动器GreenPoint参考设计
近年来,高亮度发光二极管(HB-LED)市场快速发展,LED效能(efficacy,单位为流明/瓦或lm/W)增加了一倍以上,使用更加适用于众多新应用,如我们在手持电筒、建筑照明及街道照明等应用中可以发现诸多革命性的新产品。但LED要成为比白炽灯和紧凑型荧乐灯性价比更高的照明系统,仍然面临着挑战。实际上,就许多应用而言,都涉及到基于宽输入电压范围的电源来为HB-LED供电的挑战。其中,轨道照明等通用照明应用尤为如此,这些应用采用可能很松散稳压的12 Vac或12 Vdc电源。然而,LED需要以电流源而非电压源驱动,因为根据工艺容限及温度的不同,HB-LED的正向电压(额定值3.4 V)变化幅度可能超过±20%。 此外,就当前的1
[电源管理]
替代MR16 LED应用的 <font color='red'>LED驱动器</font>GreenPoint参考设计
基于dsPIC33FJ设计的PSFB砖形DC-DC转换器技术
本文介绍了dsPIC33FJ系列主要特性,方框图和CPU 核方框图,DSP 引擎方框图,数字PFC框图以及多种应用框图。此外还介绍了相移全桥(PSFB) 1/4砖形DC-DC转换器参考设计主要特性和指标,详细电路图与材料清单(BOM)。 Microchip 公司的dsPIC33FJ06GS101/X02和dsPIC33FJ16GSX02/X04包括有广泛的DSP功能和高性能16位MCU架构。3.0-3.6V的性能达到40MIPS,具有16位宽的数据通路,24位宽指令,广泛应用在AC/DC转换器,汽车HID,电池充电器,DC/DC转换器,数字照明,电磁炉,可再生能源/纯正弦波逆变器和UPS。 dsPIC33FJ系列主要特性:
[电源管理]
基于dsPIC33FJ设计的PSFB砖形<font color='red'>DC</font>-<font color='red'>DC转换器</font>技术
如何使用RGB LED驱动器实现人机交互界的设计
中介绍如何使用 RGB 提升人机交互体验,详细剖析全新一代RGB 驱动器LP50系列的设计亮点,并指导用户使用LP50实现人机交互界面的快速开发。
[机器人]
内窥镜图像处理要求及解决方案
  我们通常需要检查限定领域内部的区域。在医疗领域中,内窥镜用于透视体内以检查器官。内窥镜可以通过一个细小的切口检查胃肠道、呼吸道和泌尿管道以及内部器官。内窥镜通过其或坚或韧的长管来采集图像。用于切、抓和其它功能的附加仪器通常连接在内窥镜上,进行能够改善医疗并缩短康复时间的微创手术。被用于技术应用以检查限定区域的物品通常被称为管道镜。管道镜用于检查机械内部、建筑墙体以及搜索倒塌建筑中的伤员。   内窥镜或管道镜具有以下4个基本要求:   照亮主体的光源;   引导光照的管道;   能采集从主体反射的光的镜头或光纤系统;   能采集、处理和存储或显示图像的图像采集系统。   TI广泛的产品系列支持
[医疗电子]
内窥镜图像处理要求及解决方案
便携产品用新型电源DC-DC转换器
    为了减小体积和重量,低功耗便携产品如PDA、掌上电脑、寻呼机和便携式测量仪表等大多采用数量有限的电池供电。这就存在两个重要问题:首先是随着电池放电,其端电压会明显降低;其次是电池具有一定内阻,而且随着放电内阻逐渐增大,在负载发生变化时造成输出电压的变化。为保证系统稳定、可靠地工作,需要一个稳定的电源电压。     由于大多数情况需要提升电池电压,简单的三端线性稳压器无法满足要求,只能采用升压型开关稳压器。但是传统的开关电源设计电路复杂、体积庞大、自身功耗较大,无法在体积和功耗要求严格的便携式产品中使用。针对这个问题,Maxim公司研制了一系列高集成度电源管理方案。其中,新近推出的MAX1678、
[应用]
电流模式控制DC/DC转换器中的电流检测电路设计
电流检测电路是电流模式控制所必需的, 通过检测功率开关管上的电流,然后输出一个电流感应信号与斜坡补偿信号进行叠加并转换成一个电压信号, 再与误差放大器的输出进行比较,从而实现电流模式开关转换器电流内环的控制。其实现方法有很多种, 常见的有两种,一种是与功率管串联一个电阻Rsen,另一种是与功率管并联一个并联检测管复制比例电流, 并联检测管复制比例电流的检测方法,又有两种主要的实现结构, 一种是采用运放的结构, 另一种是利用反馈的方式。如果采用运放, 显然会增加电路的复杂性,而且也会增加功耗。本文根据具有反馈控制电流源的原理来设计电流检测电路中的反馈网络。 1 反馈控制电流源的原理 电路原理图及电流源动态特性曲线如
[测试测量]
电流模式控制<font color='red'>DC</font>/<font color='red'>DC转换器</font>中的电流检测电路设计
泰科的DC/DC转换器适用于IBA应用
泰科电子(Tyco Electronics)公司近日推出EUK240系列DC/DC转换器EUK240,输出功率达240W,采用1/8砖封装。该产品支持5:1固定比例输出的中间总线架构应用。 EUK240电源模块是隔离的DC/DC转换器,输入电压范围在36Vdc至60Vdc之间,提供单一固定比例的输出电压。最大输出电流达34A,在全部输入范围内均可输出240W的功率。该模块的输入与输出间完全隔离,允许多极性配置和接地连接,其内置的滤波器可减少外围元件数量。 EUK240可在55℃、1m/s的输入电压范围内输出240W功率,9.6V时效率高达96%,是采用负载点转换器IBA应用的理想解决方案。此外该模块还具有远程开/关逻辑
[新品]
具APD电流监视器的90V 升压型DC/DC转换器
2007 年 2 月 8 日 - 北京 - 凌力尔特公司( Linear Technology Corporation )推出固定频率、电流模式升压型 DC/DC 转换器 LT3482 ,该器件具有内置倍压器,用于偏置光接收器中的雪崩光电二极管( APD )。 LT3482 可以用 2.5V 至 16V 的输入提供高达 90V 的输出。该器件具有高压侧 APD 电流监视功能,在 - 40 o C 至 85 o C 的温度范围内实现优于 10% 的相对准确度。集成的电源开关、肖特基二极管和 APD 电流监视器全部在采
[新品]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
