基于MAX16834大功率高亮HB LED驱动方案
最新更新时间:2012-01-14来源: 电子发烧友关键字:MAX16834  LED  驱动方案 手机看文章 扫描二维码
随时随地手机看文章
    Maxim 公司的MAX16834是电流模式大功率高亮度LED(HB LED)驱动器,可组成升压,升-降压,SEPIC和高边降压拓扑.除了用开关PWM控制器驱动N沟功率MOSFET外,还能驱动N沟PWM调光开关. MAX16834输入电压从4.75V 到28V,3000:1 PWM调光/模拟调光,工作频率从100kHz 到1MHz可编程,主要用在单串LED LCD背光,汽车前后照明,精密系统RGB LED光源,DC/DC升压/升-降压转换器等.本文介绍MAX16834主要特性,方框图,多种应用电路以及MAX16834评估板主要特性,电路图,材料清单和PCB元件布局图.
    The MAX16834 is a current-mode high-brightness LED (HB LED) driver for boost, boost-buck, SEPIC, and highside buck topologies. In addition to driving an n-channel power MOSFET switch controlled by the switching controller, it also drives an n-channel PWM dimming switch to achieve LED PWM dimming. The MAX16834 integrates all the building blocks necessary to implement a fixed-frequency HB LED driver with wide-range dimming control.
    The MAX16834 features constant-frequency peak current-mode control with programmable slope compensation to control the duty cycle of the PWM controller.A dimming driver designed to drive an external n-channel MOSFET in series with the LED string provides wide-range dimming control up to 20kHz. In addition to PWM dimming, the MAX16834 provides analog dimming using a DC input at REFI. The programmable switching frequency (100kHz to 1MHz) allows design optimization for efficiency and board space reduction.
    A single resistor from RT/SYNC to ground sets the switching frequency from 100kHz to 1MHz while an external clock signal at RT/SYNC disables the internal oscillator and allows the MAX16834 to synchronize to an external clock. The MAX16834’s integrated highside current-sense amplifier eliminates the need for a separate high-side LED current-sense amplifier in boost-buck applications.
    The MAX16834 operates over a wide supply range of 4.75V to 28V and includes a 3A sink/source gate driver for driving a power MOSFET in high-power LED driver applications. It can also operate at input voltages greater than 28V in boost configuration with an external voltage clamp. The MAX16834 is also suitable for DCDC converter applications such as boost or boostbuck.
    Additional features include external enable/ disable input, an on-chip oscillator, fault indicator output (FLT) for LED open/short or overtemperature conditions, and an overvoltage protection sense input (OVP+) for true overvoltage protection.
    The MAX16834 is available in a thermally enhanced 4mm x 4mm, 20-pin TQFN-EP package and in a thermally enhanced 20-pin TSSOP-EP package and is specified over the automotive -40℃ to +125℃ temperature range.
    MAX16834主要特性:
    _ Wide Input Operating Voltage Range (4.75V to 28V)
    _ Works for Input Voltage > 28V with External Voltage Clamp on VIN for Boost Converter
    _ 3000:1 PWM Dimming/Analog Dimming
    _ Integrated PWM Dimming MOSFET Driver
    _ Integrated High-Side Current-Sense Amplifier for LED Current Sense in Boost-Buck Converter
    _ 100kHz to 1MHz Programmable High-Frequency Operation
    _ External Clock Synchronization Input
    _ Programmable UVLO
    _ Internal 7V Low-Dropout Regulator
    _ Fault Output (FLT) for Overvoltage, Overcurrent, and Thermal Warning Faults
    _ Programmable True Differential Overvoltage Protection
    _ 20-Pin TQFN-EP and TSSOP-EP Packages
    MAX16834应用:
    Single-String LED LCD Backlighting
    Automotive Rear and Front Lighting
    Projection System RGB LED Light Sources
    Architectural and Decorative Lighting (MR16, M111)
    Spot and Ambient Lights
    DC-DC Boost/Boost-Buck Converters
图1.MAX16834方框图
图2.MAX16834升压LED驱动器
图3.MAX16834升压-降压LED驱动器(VLED+ < 28V)
图4.MAX16834带汽车电子负载突变保护的升压LED驱动器
图5.MAX16834高边降压LED驱动器
图6.MAX16834升压DC/DC转换器
图7.MAX16834升压-降压DC/DC转换器
MAX16834评估板
The MAX16834 evaluation (EV kit) is a fully assembled and tested surface-mount PCB designed to evaluate the MAX16834 pulse-width modulated (PWM) HB LED driver controller in a step-up (boost) configuration and optional step-up/step-down (buck-boost) operation.
The MAX16834 EV kit operates from a DC supply voltage of 7V to 28V and requires up to 5A. The MAX16834 EV kit circuit is configured to deliver up to 1A of current into series LEDs with a maximum forward voltage of 28V.
The MAX16834 EV kit features two different types of dimming control using either an analog linear input voltage or digital PWM input signal to control the LED brightness. This EV kit has an undervoltage lockout (UVLO) feature that disables the EV kit and overvoltage protection that protects the circuit under no-load conditions. The EV kit also features a active-low FLT PCB pad to monitor for open or short-circuit LED conditions at the LED+ and LED- PCB pads. The MAX16834 EV kit is a fully assembled and tested surface-mount board.
MAX16834评估板主要特性:
♦ 7V to 28V Wide Supply Voltage Range
♦ Configured for Boost Operation
♦ Configurable for Buck-Boost Operation
♦ 1A Output Current
♦ Analog Linear Dimming Control
♦ PWM Dimming Control
♦ Open/Short-Circuit LED Fault Indicator (FLT)
♦ Demonstrates Output Overvoltage Protection
♦ Optional Load Dump Circuit
♦ Fully Assembled and Tested
图8.MAX16834评估板电路图
MAX16834评估板材料清单(BOM):
图9.MAX16834评估板元件布局图
关键字:MAX16834  LED  驱动方案 编辑:探路者 引用地址:基于MAX16834大功率高亮HB LED驱动方案
上一篇:Proteus的LED滚屏设计与仿真
下一篇:LED的参数与特性
推荐阅读最新更新时间:2023-10-18 16:21
BCD推出多款LED驱动电源解决方案
  近期,BCD半导体制造有限公司(BCD Semi)针对LED驱动电源的特殊要求,推出了一系列高性价比、覆盖中小功率应用的解决方案。    高功率因子、低谐波失真LED灯管解决方案—AP1682   传统40W的萤光灯管可以使用20W左右的LED灯管来替换。因此,与传统的萤光灯相比,LED灯管在节能上具有明显的优势。T8 LED的灯管已经渐渐被使用在办公室、超市、公共汽车、仓库、车库等场合。T8 LED可以作为通用照明、展示照明或者是其他的应用。   对于T-Light的应用,一些技术指标是非常重要的,如总谐波失真(THD)和功率因子(PF)。无论是采用主动式还是被动式的做法,T-Light的驱动必须要满足一定
[电源管理]
LED控制应用及其对驱动/控制方案要求
  安森美半导体身为应用于高能效电子产品的首要高性能硅方案供应商,针对各种LED应用提供宽范围的LED驱动器方案,其中就包括用于可寻址标志和建筑物装饰照明两类常见应用的系列线性驱动器(详见下表)。这些驱动器能够精确地稳定LED电流,并包含可编程接口,利于软件控制。本文将以CAT4008、CAT4103和CAT9552为例,分别阐述其主要功能和基本工作原理,便于工程师的选型设计。      表1:安森美半导体应用于标志及建筑物装饰照明的系列智能LED控制/驱动器。   针对LED广告牌等应用的恒流汲入型LED驱动器   诸如广告牌标志、滚动横幅、智能车辆标志和体育计分板等LED应用需要采用多颗LED,
[电源管理]
<font color='red'>LED</font>控制应用及其对驱动/控制方案要求
采用2mm x 3mm DFN 封装的双输出升压型转换器可驱动多达6 个白光LED 和一个OLED 的显示器
2007 年 6 月 13 日 - 北京 - 凌力尔特公司( Linear Technology Corporation )推出双输出升压型转换器 LT3498 ,该器件含有一个 2.3MHz PWM LED 驱动器和一个低噪声 OLED 驱动器。 LT3498 的每个通道都有内部电源开关和肖特基二极管,这些都包含在 2mm x 3mm 的 DFN 封装内。该器件的 2.5V 至 12V 宽输入电压范围使其能够用高达 12V 的固定输入轨单节锂离子电池工作,从而提供高达 32V 的输出。每个转换器都可以独立调光或停机。采用单
[新品]
字符设备驱动-LED实验
驱动源码: #include #include #include #include #include #include #include #include #include #include int major; static struct class *leddrv_class; static struct class_device *leddrv_class_dev; volatile unsigned long *gpfcon = NULL; volatile unsigned long *gpfdat = NULL;
[单片机]
利用电感型转换器设计提高LED转换效率
LED在手机的LCD背光中的广泛应用已经有若干年了。如今其应用正扩展到大面积的LCD应用,包括袖珍PC、汽车导航GPS、数字相框、可携式DVD乃至笔记型计算机。LED也正开始取代家用的、汽车和其它通用光源的传统白炽灯和卤素光源。这一趋势背后的驱动力是技术的快速进步,包括LED更亮,效率更高,价格更具竞争能力。实际上使用LED的理由很简单,就是它们具有高可靠性和更长的寿命,在不需要更换的地方为终端用户提供免维护的产品。 为了在LCD应用中提供均匀的背光,几个白色LED通常沿着LCD的一个边安装。LED的数量正比于LCD的尺寸。对于中等尺寸(7-10英吋),通常共使用20-40个LED。这些LED通常被连接成平行的3
[电源管理]
利用电感型转换器设计提高<font color='red'>LED</font>转换效率
LED路灯电源防雷击电路设计方案
LED路灯电源安装在室外,极易受雷击或浪涌电压而损坏,所以需要设计防雷单元。路灯的防雷分为两级,第一级是防护直击雷,利用金属灯杆接地进行处理。第二级是防护传导雷击和感应雷击,电网电压波动等,采用突波吸收器Varistor作为主要组件设计防雷单元。      LED驱动电源过流保护设计      赛尔特最新研发的热保护突波吸收器(TMOV),可简化LED路灯的防雷设计。这种新型TMOV集成温度保险丝和Varistor,能够在Varistor失效着火前安全隔离,具有UL1449 第三版认证。   传统LED驱动电源采用电流保险丝作为过流保护,这里介绍赛尔特新设计的热保护绕线
[电源管理]
<font color='red'>LED</font>路灯电源防雷击电路设计方案
解决LED灯具设计难题的五大建议
一、不要使用双极型 功率 器件 Doug Bailey指出由于双极型功率器件比MOSFET便宜,一般是2美分左右一个,所以一些设计师为了降低 LED驱动 成本而使用双极型功率器件,这样会严重影响电路的可靠性,因为随着 LED驱动电路 板温度的提升,双极型器件的有效工作范围会迅速缩小,这样会导致器件在温度上升时故障从而影响LED灯具的可靠性,正确的做法是要选用MOSFET器件,MOSFET器件的使用寿命要远远长于双极型器件。 二、不要选用耐压600V的MOSFET 耐压600V的MOSFET比较便宜,很多认为LED灯具的输入电压一般是220V,所以耐压600V足够了,但是很多时候电路电压会到340V,在有浪
[电源管理]
专家称LED核心技术匮乏亟待解决
  今年3月,深圳市宣布废止LED产业规划政策,外界一度将之解读为避免出现第二个“光伏产业”。   但业内专家认为,LED产业成长空间巨大,成为第二个光伏绝无可能。原因在于LED属于消费类电子,消费类电子最大的特点就是应用非常广泛,市场极其广阔。   据权威机构预测,到2020年全球照明市场规模将超过1500亿美元,较2010年的1340亿美元增长11.9%。虽然整体规模增长不大,但是照明产品结构会发生明显变化。其中,LED照明市场份额将由2010年的50亿美元左右增加到750亿美元。也就是说10年扩张15倍。   据记者了解,从一线的情况来看,今年以来,LED背光和照明市场需求旺盛,芯片、封装和应用厂商订单饱满
[电源管理]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
