Powerint LNK458KG 4.3W PFC LED驱动参考设计
最新更新时间:2012-01-16来源: 中电网关键字:Powerint  LED  驱动参考设计 手机看文章 扫描二维码
随时随地手机看文章
    Powerint公司的4.3W PFC LED驱动器采用LinkSwitchTM-PL系列LNK458KG,主要用于B10替代灯. 115 VAC输入48V输出时的效率大于86%,115 VAC输入96V输出时的效率大于87%,功率因素大于0.95,THD小于15%,起动时间小于300ms.本文介绍了LED驱动参考设计主要优势以及输出48 V/90 mA, 48 V/ 60 mA和96 V/ 45 mA参考设计主要指标,电路图和相应的材料清单.
    4.3 W Power Factor Corrected LED Driver (Non-Isolated Buck Boost) Using LinkSwitchTM-PL LNK458KG
    This document is an engineering report describing a non-isolated LED driver (power supply) utilizing a LNK458KG from the LinkSwitch-PL family of devices.
    The DER-297 provides a single constant current output with an output power of 4.5 W.
    The board can be easily configured for output voltages from 35 V to 100 V as shown in the example table bELow.
    The key design goals were high efficiency and small size, enabling the driver to fit into candelabra and B10 sized lamps and maximize efficacy.
    The board was optimized to operate over the low AC input voltage range (85 VAC to 132 VAC, 47 Hz to 63 Hz). LinkSwitch-PL based designs provide a high power factor (>0.95) meeting current international requirements.
    The form factor of the board was chosen to meet the requirements for standard B10 LED replacement lamps. The output is non-isolated and requires the mechanical design of the enclosure to isolate the output of the supply and the LED load from the user.
    The design was not optimized for operation with phase controlled (TRIAC) dimmers but this is possible with some modification will reduce efficiency.
    The document contains the power supply specification, schematic, bill of materials, transformer documentation, printed circuit layout, design spreadsheet and performance data.
    LED驱动参考设计主要特性:
 Single-stage power factor corrected and accurate constant current (CC) output
 Low cost, low component count and small PCB footprint solution
 Highly energy efficient, >86 % at 115 VAC input for 48 V and >87 % for 96 V output
 Superior performance and end user experience
 Fast start-up time (<300 ms) – no perceptible delay
 Integrated protection and reliability features
 Single shot no-load protection / output short-circuit protected with auto-recovery
 Auto-recovering thermal shutdown with large hysteresis protects both components and PCB
 No damage during brown-out conditions
 PF >0.95 at 115 VAC
 %A THD <15% at 115 VAC
 Meets IEC ring wave, differential line surge and EN55015 conducted E
图1. LED驱动参考设计外形图
48 V, 90 mA参考设计指标:
48 V, 60 mA参考设计指标:
96 V, 45 mA参考设计指标:
图2.48 V, 90 mA参考设计电路图
图3.48 V, 60 mA参考设计电路图
图4.96 V, 45mA参考设计电路图
48 V, 90 mA参考设计材料清单:
48 V, 60 mA参考设计材料清单:
Make the following changes to modify the design from 48 V, 90 mA to 48 V, 60 mA.
96 V, 45 mA参考设计材料清单:
Make the following changes to modify design from 48 V, 90 mA to 96 V, 45 mA.
关键字:Powerint  LED  驱动参考设计 编辑:探路者 引用地址:Powerint LNK458KG 4.3W PFC LED驱动参考设计
上一篇:首尔半导体新春致辞:2012将是重要的一年
下一篇:白光LED的PWM驱动方式分析
推荐阅读最新更新时间:2023-10-18 16:22
LED应用于低温照明的几大优势
1、什么是低温照明?   低温照明是指运用人造光源来照明,环境温度在摄氏5度C以下场所,例如冷藏柜、冷冻柜、冰箱、低温工厂、室外照明等。过去低温照明光源以萤光灯为主,如今led光源在低温照明上也佔有一席之地。   2、萤光灯应用在低温照明时存在的问题   虽然萤光灯在常规室温下,发光效率可达90lm/W算得上高效率光源,但是当进入低照环境后,无论是发光效率、照度还是美学设计方面都显示出较多的不利之处。即使有厂商推出专用的低温萤光灯,解决了发光效率问题,但是仍无法顾及到照度及美学方面的要求。并且价格也是十分昂贵。在低温环境下,普通萤光灯的发光效率甚到可以减半,并且使用寿命也会减短。即使不考虑萤光灯在低
[电源管理]
<font color='red'>LED</font>应用于低温照明的几大优势
LED显示屏IP等级的划分
防护等级系统是由IEC(International ELectro Technical Commission)所起草。 将LED显示屏依其防尘、防止外物侵入、防水、防湿气之特性加以分级。这里所指的外 物包含工具、人的手指等均不可接触到灯具内之带电部分,以免触电。 IP防护等级是由两个数字所组成,第一个数字表示led显示屏防尘、防止外物侵入的等 级;第二个数字表示LED显示屏防湿气、防水侵入的密闭程度。数字越大,表示其防护 等级越高。防尘等级 (用第一个X表示), 防水等级 (用第二个X表示) 第一X表示数字代码的意义 0 :没有保护 1 :防止大的固体侵入 2 :防止中等大小的固体侵入
[电源管理]
MAX16831 高压、大功率LED驱动器,提供模拟及PWM
MAX16831 高压、大功率LED驱动器,提供模拟及PWM调光控制 MAX16831 pdf,MAX16831 datasheet MAX16831是一款电流型、高亮LED (HB LED)驱动器,设计为通过控制2个外部n沟道MOSFET来调节单串LED的电流。MAX16831集成了宽范围亮度控制、固定频率HB LED驱动器所需的全部组件。MAX16831可配置为降压型(buck)、升压型(boost)或升/降压型(buck-boost)电流调节器。 带有前沿消隐的电流模式简化了控制回路的设计。内部斜率补偿可在占空比超过50%时保持电流环路的稳定。MAX16831工作于较宽的输入电压范围,并可承受汽车抛负载事件。多个
[电源管理]
MAX16831 高压、大功率<font color='red'>LED</font><font color='red'>驱动</font>器,提供模拟及PWM
电源标准介绍 LED电源可以参照执行
国际电工委员会(IEC)已经制定了一些有关 电源 的标准,如直流稳定电源标准:IEC478.1-1974《直流输出稳定电源术语》;IEC478.2-1986《直流输出稳定电源额定值和性能》;IEC478.3-1989《直流输出稳定电源传导电磁干扰的基准电平和 测量 》;IEC478.4-1976《直流输出稳定电源除 射频 干扰外的试验方法》;IEC478.5-1993《直流输出稳定电源电抗性近场磁场分量的测量》。这一套标准颁布实施的时间较早,我国相应的国家标准尚未颁布。而有关直流稳定电源的电子行业标准SJ2811.1-87《通用直流稳定电源术语及定义、性能与额定值》、SJ2811.2-87《通用直流稳定电源 测试 方法》已发布实
[电源管理]
LED芯片基础知识普及
一、LED历史 50年前人们已经了解半导体材料可产生光线的基本知识,1962年,通用电气公司的尼克•何伦亚克(Nick HolonyakJr.)开发出第一种实际应用的可见光发光二极管。LED是英文light emitting diode(发光二极管)的缩写,它的基本结构是一块电致发光的半导体材料,置于一个有引线的架子上,然后四周用环氧树脂密封,即固体封装,所以能起到保护内部芯线的作用,所以LED的抗震性能好。 最初LED用作仪器仪表的指示光源,后来各种光色的LED在交通信号灯和大面积显示屏中得到了广泛应用,产生了很好的经济效益和社会效益。以12英寸的红色交通信号灯为例,在美国本来是采用长寿命、低光效的140瓦白
[电源管理]
教你LED智能灯泡出故障如何进行复位
如果你正在检修智能 照明 系统,建议你给每个灯泡进行手动复位,这样系统就能恢复正常工作 所有的操作就是切换几下开关,非常简单。   把家里的电灯换成联网 LED 灯泡是实现智能家居最简单的方法。很多时候,让家里的智能照明系统启动和运作起来很简单,一旦你把家里经常用到的设备都实现自动化,你就基本上不需要用手机来操控了。   有时候智能家居系统难免还是会出现故障的,那么你就需要重新打开app进行检修。如果你嫌这个麻烦,可以尝试把你的灯泡恢复默认设置。听起来有点复杂吧,其实做起来很简单 下面给大家介绍一下不同品牌的智能灯泡如何恢复默认设置:    Belkin WeMo LED灯泡   先打开WeMo
[电源管理]
教你<font color='red'>LED</font>智能灯泡出故障如何进行复位
谁是LED接班人 OLED面板呈爆炸性增长
谁是LED接班人 OLED面板呈爆炸性增长 根据DisplaySearch最新发表季度OLED(有机发光二极管显示面板)最近出货调查指出,全球OLED出货金额在2009年第三季破纪录高达2亿5千2百万美元,较上一季成长31%;另外,出货量达到2千170万片,较上一季成长19% (如下图)。     Q1'08~Q4'09 OLED面板出货金额及成长率   尽管经济不佳对产业产生一定的影响,然由于高阶手机需求增加且智能手机(Smart Phones)出货增长,使得对AMOLED面板需求提高;同时三星电信持续积极地推广采用AMOLED面板手机的好处,也推进了消费者的接受度。   以AMOLED供货商中,
[模拟电子]
谁是<font color='red'>LED</font>接班人 OLED面板呈爆炸性增长
艾迈斯欧司朗的ALIYOS™ LED-on-foil技术将为汽车照明带来前所未有的变革
“ 大放异彩 ” —— 艾迈斯欧司朗的 ALIYOS ™ LED-on-foil 技术 将为 汽车照明带来前所未有的变革 ALIYOS™技术突破了多区块发光的界限,同时又能实现个性化的发光面造型; 透明、纤薄、2.5D弯曲的产品特性可使客户创造出全新的照明效果,实现个性化的照明解决方案; ALIYOS™技术能够灵活的实现后组合灯法规所规定的亮度要求; ALIYOS™ LED-on-foil技术能够在不同灯具造型中实现区块化、个性化设计,例如3D发光效果、自由曲面上的隐藏式光源等效果; ALIYOS™照明技术再次印证了艾迈斯欧司朗在汽车照明创新方面的领先优势。 中国 上海, 2023 年 10 月
[汽车电子]
艾迈斯欧司朗的ALIYOS™ <font color='red'>LED</font>-on-foil技术将为汽车照明带来前所未有的变革
小广播
最新电源管理文章
