This highly integrated PWM controller, FL7730MY, provides several features to enhance the performance of single-stage flyback converters. The proprietary topology, TRUECURRENT™, enables the simplified circuit design for LED lighting applications.
The FL7730 is an active Power Factor Correction (PFC) controller using single-stage flyback topology. Dimming control with no flicker is implemented by an analog sensing method. Primary-side regulation and single-stage topology reduce external components such as input bulk capacitor and feedback circuitry and minimize cost. To improve good power factor and Total Harmonic Distortion (THD), constant on-time control is utilized with internal error amplifier and a low-bandwidth compensator. Precise constant-current control regulates accurate output current, independent of input voltage and output voltage. Operating frequency is proportionally changed by output voltage to guarantee DCM operation with higher efficiency. FL7730 provides protections such as open-LED,short-LED, and over-temperature protection.
TRIAC dimming is smoothly managed by dimming brightness control without flicker. By using single-stage topology with primary-side regulation, an LED lighting board can be implemented with few external components and minimized cost. It does not require an input bulk capacitor or feedback circuitry. To implement good power factor and low total harmonic distortion, constant on-time control is utilized with an external capacitor connected to the COMI pin.
Precise constant-current control regulates accurate output current versus changes in input voltage and output voltage. The operating frequency is proportionally changed by the output voltage to guarantee Discontinuous Conduction Mode (DCM) operation with higher efficiency and simpler design. The FL7730MY provides protections such as open-LED, short-LED, and over-temperature protections. Current-limit level is automatically reduced to minimize output current and protect external components in a short-LED condition.
The FL7730MY controller is available in an 8-pin SOP package.
FL7730主要特性:
■ Compatible with Traditional TRIAC Control (No need to change existing lamp infrastructure: wall switch & wire)
■ Compatible with Non-Dimming Lamp Designs
■ Cost-Effective Solution without Input Bulk Capacitor and Feedback Circuitry
■ Power Factor Correction (PFC)
■ Accurate Constant-Current (CC) Control, Independent Online Voltage, Output Voltage, Magnetizing Inductance Variation
■ Line Voltage Compensation for CC Control
■ Linear Frequency Control for Better Efficiency and Simple Design
■ Open-LED Protection
■ Short-LED Protection
■ Cycle-by-Cycle Current Limiting
■ Over-Temperature Protection with Auto Restart
■ Low Startup Current: 20µA
■ Low Operating Current: 5mA
■ SOP-8 Package Available
■ Application Voltage Range: 80VAC ~ 308VAC
FL7730应用:
Lighting
图1.FL7730方框图
LED照明灯主要性能指标:
图2.8.4W LED灯 PCB外形图:顶视图
图3.8.4W LED灯 PCB外形图:底视图
图4.8.4W LED灯外形图
图5.8.4W LED灯电路图
图6.8.4W LED灯变压器电路图
8.4W LED灯材料清单(BOM):
图7.8.4W LED灯PCB元件布局图:顶层
图8.8.4W LED灯PCB元件布局图:底层
详情请见:
http://www.fairchildsemi.com/an/AN/AN-FEB020H.pdf
和
http://www.fairchildsemi.com/support/referencedesign/docs/RD-L020-2.pdf
上一篇:典型白光LED驱动案例
下一篇:LED显示屏高灰度扫描控制的FPGA实现
推荐阅读最新更新时间:2023-10-18 16:45
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- MathWorks 和 NXP 合作推出用于电池管理系统的 Model-Based Design Toolbox
- 意法半导体先进的电隔离栅极驱动器 STGAP3S为 IGBT 和 SiC MOSFET 提供灵活的保护功能
- 全新无隔膜固态锂电池技术问世:正负极距离小于0.000001米
- 东芝推出具有低导通电阻和高可靠性的适用于车载牵引逆变器的最新款1200 V SiC MOSFET
- 【“源”察秋毫系列】 下一代半导体氧化镓器件光电探测器应用与测试
- 采用自主设计封装,绝缘电阻显著提高!ROHM开发出更高电压xEV系统的SiC肖特基势垒二极管
- 艾迈斯欧司朗发布OSCONIQ® C 3030 LED:打造未来户外及体育场照明新标杆
- 氮化镓取代碳化硅?PI颠覆式1700V InnoMux2先来打个样
- 从隔离到三代半:一文看懂纳芯微的栅极驱动IC
- TI E2E™ 中文社区8周年,8本技术合集送给热爱技术的你!
- 力源带你了解安森美半导体开发神器——高度灵活的物联网开发套件( IDK )!看视频轻松答题享好礼!
- 如何读懂牛掰的USB Tybe-C新闻稿!
- 泰克移动多媒体总线系列专题来袭~《HDMI2.0规范测试方案》下载有礼!
- 辛苦一个月,EEWORLD社区3月明星人物出台喽!
- 逆袭新机会!来EEWorld 下载中心,做任务赚200积分,轻松实现积分自由
- 调查:全新 TI E2E中文社区等你体验,等你抽奖!还可邀请好友助你一臂之力!
- 泰克 4200A-SCS 带您走进半导体材料测试世界 下载赢好礼!
- 系列二:TI模拟芯片选型指南(参与过系列一活动的也可以参加这期哟)
