The NCL30105 is a peak current controlled fixed off time buck controller designed for LED driver applications. It is optimized to operate in deep continuous conduction mode ELiminating the need for output electrolytic capacitors. Featuring an adjustable off time generator, the controller can drive a MOSFET up to a switching frequency of 500 kHz. A dedicated dimming pin enables the use of a pulsewidth modulated logic signal to dim the LED directly. The soft-start pin creates a startup sequence that slowly ramps up the peak current and enables the adjustment of the peak current set point for analog dimming control. The device features robust protection features to detect switch overcurrent faults and to detect maximum on time events.
NCL30051主要特性:
• Constant Off Time Current−Mode Control Operation
• Adjustable Off Time (0.5 [1]s to 10 [1]s)
• Internal Leading Edge Blanking
• Source 250 mA / Sink 500 mA Peak Drive Capability
• ±3.2% Current Sense Accuracy at 25℃• Internal Startup Delay
• 3.3 V Logic Level Dimming Input
• This is a Pb−Free Device
NCL30051安全特性:
• Thermal Shutdown
• Maximum On Time Protection
• Overcurrent Protection
NCL30051典型应用:
• LED Backlight Drivers for LCD Panels
• LED Light Bars
• LED Street Lighting
• LED Bulbs
图1.NCL30051方框图
图2.NCL30051典型应用框图
图3.NCL30051典型应用电路图
图4. 评估板NCL30105GEVB外形图:输入高达80V,输出350mA
图5. 评估板NCL30105GEVB电路图(1)
图6. 评估板NCL30105GEVB电路图(2)
评估板NCL30105GEVB材料清单:
图7. 评估板NCL30105GEVB元件布局图:顶层
图8. 评估板NCL30105GEVB元件布局图:底层
上一篇:Infineon ICL8001G 9W离线LED照明解方案
下一篇:照明产品出口应注意符合目标市场标准
推荐阅读最新更新时间:2023-10-18 16:56
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- Vishay推出适用于恶劣环境的紧凑型密封式SMD微调电阻器
- MathWorks 和 NXP 合作推出用于电池管理系统的 Model-Based Design Toolbox
- 意法半导体先进的电隔离栅极驱动器 STGAP3S为 IGBT 和 SiC MOSFET 提供灵活的保护功能
- 全新无隔膜固态锂电池技术问世:正负极距离小于0.000001米
- 东芝推出具有低导通电阻和高可靠性的适用于车载牵引逆变器的最新款1200 V SiC MOSFET
- 【“源”察秋毫系列】 下一代半导体氧化镓器件光电探测器应用与测试
- 采用自主设计封装,绝缘电阻显著提高!ROHM开发出更高电压xEV系统的SiC肖特基势垒二极管
- 艾迈斯欧司朗发布OSCONIQ® C 3030 LED:打造未来户外及体育场照明新标杆
- 氮化镓取代碳化硅?PI颠覆式1700V InnoMux2先来打个样
- Allegro MicroSystems 在 2024 年德国慕尼黑电子展上推出先进的磁性和电感式位置感测解决方案
- 左手车钥匙,右手活体检测雷达,UWB上车势在必行!
- 狂飙十年,国产CIS挤上牌桌
- 神盾短刀电池+雷神EM-i超级电混,吉利新能源甩出了两张“王炸”
- 浅谈功能安全之故障(fault),错误(error),失效(failure)
- 智能汽车2.0周期,这几大核心产业链迎来重大机会!
- 美日研发新型电池,宁德时代面临挑战?中国新能源电池产业如何应对?
- Rambus推出业界首款HBM 4控制器IP:背后有哪些技术细节?
- 村田推出高精度汽车用6轴惯性传感器
- 福特获得预充电报警专利 有助于节约成本和应对紧急情况
