The FL7701 LED lamp driver is a simple IC with PFC function. The special “adopted digital” technique of the IC can automatically detect input voltage condition and send an internal reference signal for achieving high power factor. When AC input is applied to the IC, PFC function is automatically enabled. Otherwise, when DC input is applied to the IC, PFC function is automatically disabled. The FL7701 does not need a bulk capacitor(electrolytic capacitor) for supply rail stability, which can significantly affect to LED lamp system.
FL7701主要特性:
Digitally Implemented Active PFC Function (No Additional Circuit Necessary for High PF)
Built-in HV Supplying Circuit: Self Biasing
Application Input Range :80VAC ~ 308VAC
AOCP Function with Auto-Restart Mode
Built-in Over-Temperature Protection Function
Cycle-by-Cycle Current Limit
Current-Sense Pin Open Protection
Low Operating Current: 0.85mA (Typical)
Under-Voltage Lockout with 5V Hysteresis
Programmable Oscillation Frequency
Programmable LED Current
Analog Dimming Function
Soft-Start Function
Precise Internal Reference: ±3%
FL7701应用:
LED Lamp for Decorative Lighting
LED Lamp for Low-Power Lighting
图1.FL7701方框图
图2.FL7701典型应用电路图
图3.FL7701高压应用电路图
图4.FL7701无电解电容的应用电路
图5.FL7701带电解电容的应用电路
采用FL7701的2.4W LED镇流器
This document describes the proposed solution for a universal-input 2.4W LED ballast using the FL7701. The input voltage range is 90VRMS – 265VRMS and there is one DC output with a constant current of 85mA at 28VMAX. This document contains general description of FL7701, the power supply specification, schematic, bill of materials, and the typical operating characteristics.
图6.2.4W LED镇流器外形图
图7.2.4W LED镇流器电路图
2.4W LED镇流器材料清单:
图8.2.4W LED镇流器PCB布局图
详情请见:
http://www.fairchildsemi.com/ds/FL/FL7701.pdf
和
http://www.fairchildsemi.com/products/evaluationboards/FEBFL7701_L30U003A.pdf?user-guide=
上一篇:【技术交流】LED芯片寿命试验过程全解析
下一篇:LED投影机功能介绍与分析
推荐阅读最新更新时间:2023-10-17 14:58
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- Bourns 推出两款厚膜电阻系列,具备高功率耗散能力, 采用紧凑型 TO-220 和 DPAK 封装设计
- Bourns 全新高脉冲制动电阻系列问世,展现卓越能量消散能力
- Nexperia推出新款120 V/4 A半桥栅极驱动器,进一步提高工业和汽车应用的鲁棒性和效率
- 英飞凌推出高效率、高功率密度的新一代氮化镓功率分立器件
- Vishay 新款150 V MOSFET具备业界领先的功率损耗性能
- 强茂SGT MOSFET第一代系列:创新槽沟技术 车规级60 V N通道 突破车用电子的高效表现
- 面向车载应用的 DC/DC 电源
- Vishay推出适用于恶劣环境的紧凑型密封式SMD微调电阻器
- MathWorks 和 NXP 合作推出用于电池管理系统的 Model-Based Design Toolbox
