IRIRPLHID270WHID灯镇流器参考设计
最新更新时间:2012-09-08来源: chinaaet关键字:电源管理  HID  灯镇流器 手机看文章 扫描二维码
随时随地手机看文章
镇流器参考设计IRPLHID2采用IRS2573D器件,输入电压185V-265V,可驱动1 x 70W HID灯,具有高功率因素/低总谐波失真,可控制起辉,低频方波工作,灯电流和功率可控制,开路和无灯保护.而IRS2573D是全集成全保护的600V HID控制器,能驱动所有类型的HID灯,内部电路提供了起辉,加热,运行和故障保护模式.本文介绍了IRS2573D主要特性,框图,应用框图以及采用IRS2573D的70W HID灯镇流器IRPLHID2参考设计主要指标,参考设计框图和电路图,以及材料清单和PCB布局图.
The IRS2573D is a fully-integrated, fully-protected 600V HID control IC designed to drive all types of HID lamps. Internal circuitry provides control for ignition, warm-up, running and fault operating modes. The IRS2573D features include ignition timing control, constant lamp power control, programmable full-bridge running frequency, programmable over and under-voltage protection and programmable over-current protection. Advanced protection features such as failure of a lamp to ignite, open load, short-circuit and a programmable fault counter
have also been included in the design.
IRS2573D主要特性:
• Buck, full-bridge and lamp control in one IC
• Continuous/critical-conduction mode buck control
• 600V high and low-side full-bridge driver
• 600V high-side buck Driver
• Low-side ignition FET gate driver
• Integrated bootstrap FETs for full-bridge high-side drivers
• Constant lamp power control
• Programmable buck cycle-by-cycle over-current protection
• Programmable buck output voltage limitation
• Programmable lamp current limitation
• Programmable full-bridge frequency
• Fault latch reset input
• Programmable ignition counter (21sec/64sec typical)
• Programmable lamp under-voltage fault counter (197sec typical) for short-circuit or lamp does not warm-up
• Fast transient lamp under-voltage event counter (16384 typical) for arc instability or end-of-life
• Programmable lamp over-voltage fault counter (787sec typical) for open-circuit or lamp extinguishes
• Programmable good fault reset counter (2730sec typical)
• Micro-controller compatible timing thresholds
• Internal 15.6V zener clamp diode on VCC
• Micropower startup (150μA)
• Latch immunity and ESD protection on all pins
图1.IRS2573D方框图
图2.IRS2573D应用框图
The IRPLHID2 reference design kit consists of a complete ballast solution for a 70W HID lamp. The design contains an EMI filter, low voltage power supply, active power factor correction and a ballast control circuit using the IRS2573D. This demo board is intended to help with the evaluation of the IRS2573D HID ballast control IC, demonstrate PCB layout techniques and serve as an aid in the development of production ballasts using the IRS2573D.
IRPLHID2参考设计主要特性:
 Drives 1 x 70W HID lamp
 Input voltage range: 185-265 VAC
 High Power Factor / Low Total Harmonic Distortion
 Controlled ignition
 Low frequency square wave operation
 Lamp power and current control
 Open circuit and no-lamp protection
 Short circuit and lamp failure to warm-up protection
 Lamp end-of-life shutdown
 IRS2573DSPbF HID Ballast Control IC
图3.IRPLHID2参考设计外形图
图4.IRPLHID2参考设计框图
IRPLHID2参考设计主要指标:
图5.IRPLHID2参考设计电路图(1)
图6.IRPLHID2参考设计电路图(2)
IRPLHID2参考设计材料清单(BOM):
图7.IRPLHID2参考设计PCB元件布局图(顶层)
图8.IRPLHID2参考设计PCB布局图(顶层)
图9.IRPLHID2参考设计PCB元件布局图(底层)
图10.IRPLHID2参考设计PCB布局图(底层)
详情请见:
http://www.irf.com/product-info/datasheets/data/irs2573dspbf.pdf
http://www.irf.com/technical-info/refdesigns/irplhid2.pdf
关键字:电源管理  HID  灯镇流器 编辑:探路者 引用地址:IRIRPLHID270WHID灯镇流器参考设计
上一篇:中性白光LED与冷白光LED在街道照明应用中的差异
下一篇:如何利用32个彩色LED实现光环
推荐阅读最新更新时间:2023-10-17 15:03
上网本电源管理系统的设计挑战及解决方案
上网本的 电源管理 系统可分为以下几部分:1. 电池充电和管理;2. CPU 处理器供电;3.系统5V/3.3V供电;4. I/O和显卡供电;5. 显示背光供电;6. DDR存储器供电。 我们如果把上网本对电源的要求与笔记本电脑和MID、智能手机等相比较:与主流笔记本电脑相比,上网本电池一般是2到3节,CPU及I/O功耗较低,输入适配器 电压 是19V或者12V、16V。而笔记本电脑适配器输入电压一般是19V,电池一般是3节以上。从供电方式看两者比较相似。MID与智能手机功耗较上网本低,一般采用PMU(集成电源管理器件)供电,电池一般是1到2节。 与常见笔记本电脑相比,上网本的一个主要特别点是其处理器的工作电压更低,同时又需要很大
[嵌入式]
便携及电池供电系统电源管理设计
当今的便携应用集成越来越多的功能。大趋势是手机不单是移动电话,还成为数码相机(DSC)、移动电视终端以及游戏机和多媒体终端。现今的数字技术让应用处理器足够为终端客户提供这些功能。 然而,这种功能剧增的代价是功率消耗越来越高。由于电池容量及技术方面的改进步伐非常缓慢, 工程师 面临两项主要挑战。首先,他们必须适应这种结合了许多功能的高集成度;其次,他们必须提供长的电池使用时间。 除了功能剧增,手机用户的另一项强烈要求在于外形尺寸。消费者既不希望牺牲电池使用时间,也不希望集成额外功能而影响手机尺寸和外形尺寸。 为了应对这些挑战,最佳的策略就是在主 芯片 组中集成越来越多的功能,从而产生双芯片或三芯片方案,并配有集成
[电源管理]
便携及电池供电系统<font color='red'>电源管理</font>设计
节能需求和下游应用扩容电源管理市场
中国是世界上的能源消耗大国,由于中国能源生产的短缺和不均衡,已连续几年出现“电荒”现象。为解决“电荒 ”问题,我国政府也颁布了一些法令以提高能效。目前我国已经开始针对某些产品提出能效要求,而且还对冰箱、空调、洗衣机之类的产品进行能效标志,此外,欧美发达国家对某些电子产品有直接的能效要求,如果国内想要出口,就必须满足其能效要求,所有这些提高能效的要求将会给功率器件市场带来更大的机会。 -->   ** 热门点击 ** 特别推荐 **
[电源管理]
一种采用全数字控制方式的汽车HID氙气解决方案
过去汽车车灯多采用普通卤素灯泡,这种车灯的瓦数和亮度不够、色温过低、灯色偏黄,而且寿命较短,故障率偏高。日前,HID(High Intensity DischargeLamp)氙气灯正在汽车车灯领域兴起,与传统卤素灯相比,HID氙气灯具有节能、亮度高、寿命长、安全可靠、色温与太阳光类似等优点。HID氙气灯由安定器和灯泡构成,安定器是氙气灯产品的核心部件,氙气灯的性能与安定器密切相关。随着HID安定器技术不断成熟,新的数字化控制方式也在冲击着这个行业。 世强电讯根据国内HID市场的特点需要推出了基于Silicon Labs MCU的单芯片氙气灯全数字智能安定器解决方案。该方案采用全数字控制,符合目前数字化的发展潮流。单芯片的控制
[嵌入式]
谈手机的电源管理设计要点及方法
随着手机的功能越来越多,用户对手机电池的能量需求也越来越高,现有的锂离子电池已经越来越难以满足消费者对正常使用时间的要求。对此,业界主要采取两种方法,一是开发具备更高能量密度的新型电池技术,如燃料电池;二是在电池的能量转换效率和节能方面下功夫。 为手机提供电能的技术在最近几年虽有不少创新和发展,但是还远远不能满足手机功能发展的需要,因此如何提高电源管理技术并延长电池使用寿命,已经成为手机开发设计中的主要挑战之一。 同时,设计者还必须明白消费者对手机的要求,这主要体现在以下几个方面:第一,体积小。这要求提高系统的集成度,缩小元器件的封装体积,减小 PCB板的面积,这可能会增加设计中解决电磁干扰(EMI)的难度。第二,重量轻。
[电源管理]
电源管理半导体上半年出现短缺
      据iSuppli公司,2010年上半年电源管理半导体销售收入强劲上升,出乎供应商意料,可能导致近期价格上涨。       2010年第一季度,电源管理半导体销售收入达到69亿美元,比2009年第四季度的67亿美元增长2.9%。该市场在2009年第三季度曾陷入停滞,第四季度开始扩张,第一季度数据显示该市场仍在扩张。       预计今年第二季度将保持增长趋势,销售收入有望再增长7.2%,达到74亿美元。尽管去年同期增幅较大——当时电源管理半导体劲增18.2%,从44亿上升到52亿美元——但2010年第二季度将取得该产业今年最强劲的增长。       图1所示为iSuppli公司对于2009年第四季度到今年第四
[电源管理]
<font color='red'>电源管理</font>半导体上半年出现短缺
电源管理子系统IC及其应用
当今,大多数消费类和移动应用的电池都是基于锂离子技术,如锂离子、锂离子聚合物电池等。这类电池都具有优异的容量性能,并具有3.3V~4.2V 电压 范围,这允许用3V额定 电源 的IC在系统中实现有效的 电源管理 。 随着IC电压需要继续降低以使工作时间延长,现在很多系统也需要多电源和更复杂的电源管理功能。为了满足这些要求,设计人员也习惯从多家供应商选用各种现成的低集成电源管理元件,以便迅速地开发产品。往往复杂 电路 的电源子系统仅包含一个或两个电源和一些分立元件(如低压稳压器LDO和 降压 变换器)。 某些系统设计(特别是便携 电子 设备)复杂性的增加,意味着需要更多控制,而设计人员应考虑如何使效率
[电源管理]
<font color='red'>电源管理</font>子系统IC及其应用
IM2605 type-c电源管理芯片设计原理图
IM2605集成了一个同步4开关Buck-Boost变换器,在输入电压小于或大于输出电压时保持输出电压调节。当输入电压足够大于输出电压时,它作为Buck变换器工作,并随着输入电压接近输出逐渐过渡到Buck-Boost模式。它还具有内部固定软启动功能,并提供保护功能包括输入UVLO、OCP、过载保护(OLP)、OVP和热关机。此外,它还具有可选择的FCCM或DCM操作,用于轻负载。IM2605还控制两个低N-MOSFET作为负载开关,有助于降低BOM成本。采用微处理器,可实现电源交换时的输入体电容放电。 IM2605应用 TYPEC拓展坞/扩展底座、USB电源传输、计算机 外围设备
[嵌入式]
IM2605 type-c<font color='red'>电源管理</font>芯片设计原理图
小广播
最新电源管理文章
