ADIAD578018位精度低噪音±10VDC电压源解决方案
最新更新时间:2012-03-13来源: 21IC关键字:工业控制  测试测量  数据采集 手机看文章 扫描二维码
随时随地手机看文章
    ADI公司的AD5780是真正18位线性低噪音精密的±10 V DC电压源,工作电压双极电压高达33V,采用正基准输入电压从5V到VDD-2.5V,而负基准输入电压从VSS+2.5V到0V,输出噪音8 nV/√Hz,长期稳定性为0.025 LSB,增益误差±0.018 ppm/℃,输出电压设定时间2.5 μs, 施密特触发器数字接口35MHz,1.8V兼容数字接口,主要用在医疗仪器,测试测量,工业控制,数据采集系统,数字增益和失调调整,电源控制等.本文介绍了AD57801产品亮点和主要特性, 功能框图和典型工作电路图以及评估板EVAL-AD5780主要特性,电路图,材料清单和PCB布局图.
    The AD57801 is a true 18-bit, unbuffered voltage output DAC that operates from a bipolar supply of up to 33 V. The AD5780 accepts a positive reference input range of 5 V to VDD − 2.5 V and a negative reference input range of VSS + 2.5 V to 0 V. Both reference inputs are buffered on chip and external buffers are not required. The AD5780 offers a relative accuracy specifica-tion of ±1 LSB maximum range, and operation is guaranteed monotonic with a ±1 LSB DNL maximum range specification.
    The part uses a versatile 3-wire serial interface that operates at clock rates of up to 35 MHz and is compatible with standard SPI, QSPI™, MICROWIRE™, and DSP interface standards. The part incorporates a power-on reset circuit that ensures that the DAC output powers up to 0 V in a known output impedance state and remains in this state until a valid write to the device takes place. The part provides an output clamp feature that places the output in a defined load state.
    AD57801产品亮点:
True 18-bit accuracy.
Wide power supply range of up to ±16.5 V.
−40℃ to +125℃ operating temperature range.
Low 8 nV/√Hz noise.
Low ±0.018 ppm/℃ gain error temperature coefficient
AD57801主要特性:
True 18-bit voltage output DAC, ±1 LSB INL
8 nV/√Hz output noise spectral density
0.025 LSB long-term linearity error stability
±0.018 ppm/°C gain error temperature coefficient
2.5 μs output voltage settling time
3.5 nV-sec midscale glitch impulse
Integrated precision reference buffers
Operating temperature range: −40℃ to +125℃
4 mm × 5 mm LFCSP package
35 MHz Schmitt triggered digital interface
1.8 V-compatible digital interface
AD57801应用:
Medical instrumentation
Test and measurement
Industrial control
Scientific and aerospace instrumentation
Data acquisition systems
Digital gain and offset adjustment
Power supply control
图1.AD57801功能框图
图2.AD57801典型工作电路图
AD57801评估板EVAL-AD5780
Evaluation Board for a 18-Bit Serial Input, Voltage Output DAC with Integrated Precision Reference Buffer Amplifiers
The EVAL-AD5780 is a full-featured evaluation board, designed to allow the user to easily evaluate all features of the AD5780 voltage output, 18-bit digital-to-analog converter (DAC). The AD5780 pins are accessible at on-board connectors for external connection. The board can be controlled by two means: via the on-board connector (J3), or via the system development platform connector (J4). The SDP board allows the evaluation board to be controlled through the USB port of a Windows® XP- (SP2 or later) or Vista-based (32-bit) PC using the AD5780 evaluation software.
评估板EVAL-AD5780主要特性:
Full-featured evaluation board for the AD5780
Link options
PC control in conjunction with Analog Devices, Inc., system development platform
PC software for control
图3.评估板EVAL-AD5780框图
图4.评估板EVAL-AD5780电路图:AD5780
图5.评估板EVAL-AD5780电路图:电压参考电路
图6.评估板EVAL-AD5780电路图:SDP板连接器
图7. 18位精度±10V电压源简化电路图
评估板EVAL-AD5780材料清单:
图8.评估板EVAL-AD5780 PCB布局图
详情请见:
http://www.analog.com/static/imported-files/data_sheets/AD5780.pdf
http://www.analog.com/static/imported-files/user_guides/UG-256.pdf
关键字:工业控制  测试测量  数据采集 编辑:探路者 引用地址:ADIAD578018位精度低噪音±10VDC电压源解决方案
上一篇:基于ARM的定时继电器驱动模板的设计
下一篇:FPGA设计中常用的低功耗技术
推荐阅读最新更新时间:2023-10-18 16:29
基于USB-Host的大容量数据采集系统的设计
摘要 利用USB主控制器控制U盘作为数据采集系统的移动存储器。该设计基于USB主/从控制芯片CH375S,遵守大容量存储设备类规范中的BulkOnly和UFI子规范,支持FAT16文件系统,实现了数据采集系统中可用U盘进行数据存储,方便与计算机交互;配合液晶和外扩键盘,可以完全抛开PC,实现采集数据的实时显示和指定存储区域内数据的查看。 关键词 CH375S USB-Host 数据采集系统 Mass-Storage类 FAT16 文件系统 引言   随着移动数据存储领域的日益扩大,在嵌入式系统中实现USB主机功能,以实现利用USB存储设备进行数据存储的需求变得日益迫切。U盘作为新型移动存储设备,以体积小、速度高、抗震动、通用性强
[应用]
是德科技2016测试测量大会完美亮相深圳
2016年6月2日是德科技年度盛会 是德科技测试测量大会(Keysight Measurement Forum, KMF)在深圳威斯汀酒店惊艳亮相。为期一天的大会吸引了近300位与会者参会。 是德科技KMF会议现场 随着大数据时代的来临,无数的热议、想象和憧憬不断涌现。此次是德科技测试测量大会议题紧贴大数据时代热点,涵盖了智能硬件、网络设备、云计算、器件和半导体等领域。其中具体如智能手机中采用的载波聚合、VoLTE 和 Type-C 等最新的技术;VR/AR、智能家居在内的新型硬件中的关键测试项目;第五代移动通信 5G 在挖掘频谱效率、提高吞吐量和提高流量密度等方面的研发和测试以及应对数据中心和网络
[测试测量]
是德科技2016<font color='red'>测试测量</font>大会完美亮相深圳
国产核心零部件步入爆发前夜 将打破国外品牌关键领域垄断
在政策助推,需求拉动、市场验证等一系列因素的影响下,国产核心零部件正步入爆发的前夜! 无论是减速机的信任破冰,还是伺服电机的稳步发展,亦或者是控制器进入高端市场,都表明中国在减速器、伺服电机、控制器等关键零部件上长期受制于外资企业的情形正在慢慢发生改变。 国内厂商相继攻克了核心零部件领域的部分难题,正在稳步推进零部件的国产化,这将降低国产机器人的成本,提升国产机器人在新增装机中的占比,更重要的是,这将打破国外品牌在关键领域的垄断。 减速机:信任破冰 国产化替代加速 今年以来,得益于减速机市场的全球缺货情况,国产减速器企业迎来难得的发展机遇,不断爆出订单消息。 3月13日,上海欢颜自动化向南通振康采购1.5万台减速机并举行了隆
[嵌入式]
基于ARM的多传感器信息融合在工业控制中的应用
0 引言 现代工业生产以综合、复杂、大型、连续为特点,采用大量传感器来监测和控制生产过程。多传感器系统的出现导致信息量剧增,采用信息融合技术可更有效地利用信息资源。在复杂的工业控制系统中,控制过程需同时涉及多个信息,特别是各信息间的联系,信息的有机组合蕴涵的信息特征以及信息的整体状况,并需要根据综合状况所描述的过程运行特点进行控制。故将嵌入式系统与信息融合技术相结合,以解决用传统控制难于解决的问题。 1 多传感器信息融合 1.1 多传感器信息融合的概念 多传感器信息融合是指协调使用多个传感器,把分布在不同位置的多个传感器所提供的局部不完整观测量及相关联数据库中的相关信息加以综合,消除多传感器信息之间可能存在的冗
[单片机]
基于ARM的多传感器信息融合在<font color='red'>工业控制</font>中的应用
基于AT89C51的数据采集系统设计新方法
0 引言 近年来,随着制造技术的发展,单片机的价格越来越低,性能却不断提升,因而其应用范围也越来越广。然而在开发基于单片机的应用系统时,传统方法一般都需要大量的硬件设备,这些设备极易损坏而且携带不方便。为此,本文基于AT89C51数据采集系统详细说明了如何利用Pro-teus和两款串口仿真软件来进行单片机程序及外围电路的仿真设计。采用该方法可以大大简化硬件电路测试和系统调试过程,对单片机系统开发具有指导意义。本文介绍的基于AT89C5l单片机的数据采集系统能实现16路信号输入,每一路都是0~10 mV的信号,每秒钟采集一遍,从而将数据传给上位PC计算机。 1 硬件设计 1.1 主控芯片 AT89C51是一种
[单片机]
基于FPGA设计EnDat编码器数据采集后续电路
  摘要:随着集成电路技术的发展,FPGA以其体积小、速度快、功耗低、设计灵活、利于系统集成、扩展升级等优点,被广泛地应用于高速数字信号传输及数据处理。EnDat数据接口是适用于编码器的双向数字接口。EnDat可传输编码器的位置值,也能传输或更新保存在编码器中的信息或保存新信息。在此介绍了EnDat接口的特点、功能、时序和数据传输、OEM数据存储,以及编码器数据采集后续电路设计方案,基于FPGA编码器接口的设计,用以进行编码器和DSP处理器之间的通讯。    0 引言   EnDat接口是HEIDENHAIN专为编码器设计的数字式、全双工同步串行的数据传输协议,具有传输速度快、功能强大、连线简单、抗干扰能力强等优点,是
[测试测量]
基于FPGA设计EnDat编码器<font color='red'>数据采集</font>后续电路
基于LPC2210和μC/OS—II的触摸屏触摸点数据采集系统
  本文提出了基于ARM7系列LPC2210微控制器和嵌入式操作系统μC/OS—II来实现触摸屏触摸点数据采集系统的设计,并完成了微控制器与上位机之间的物理层 电路 转换,实现了基于LIN总线的数据通信,能够在上位机得到触摸点的精确坐标以及控制菜单信息,并且准确可靠、传输速率高。   嵌入式系统实际上是“嵌入式计算机系统”的简称,是相对于通用计算机系统而言的,根据应用的要求,将操作系统和功能软件集成于计算机硬件系统中,以应用为中心,计算机技术为基础,实现软件与硬件的一体化。其适用于对功能、可靠性、成本、体积和功耗等有严格要求的专用计算机系统。   触摸屏又称为“触控屏”、“触控面板”,是一种附加在显示器表面的透明介质。触摸屏作
[单片机]
基于LPC2210和μC/OS—II的触摸屏触摸点<font color='red'>数据采集</font>系统
利用DSP和CPLD增强数据采集的可扩展性
  在IC卡公用电话系统中,在线式公用电话由于其具有保密性高、可扩展性强等特点,已逐渐获得人们的青睐。这种公用电话系统被置于终端和交换机之间,对两者的信号进行调制、解调以及其它的运算,来完成诸如卡验证、终端维护、多媒体信号传输等工作。与软件无线电相类似,这种系统的硬件平台通用性很强,数字信号处理的算法将由专门的芯片来承担,所以这种系统可以兼容目前在电话线上应用的各种调制解调方法,也可以适应未来出现的其它调制解调标准。   由此可以看出,要实现这样一个系统,数据采集是一个非常重要的方面。为了节约成本和提高DSP芯片的利用率,在这个系统中,一片DSP要承担16个通道的运算。从数据采集的角度来说,由于通道同时对应着终端和交换机两端
[嵌入式]
小广播
最新电源管理文章
