The TMC389 is an energy efficient three phase stepper motor driver for high resolution microstepping applications. It integrates a low resonance three phase chopper for quiet motor operation. Its step and direction interface allows simple use. An SPI™ management interface allows for parameterization and diagnostics. The TMC389 directly drives 3 external N/P channel dual MOSFETs for motor currents up to 8A and up to 60V. Protection and diagnostic features further reduce system cost and increase reliability.
TMC389产品亮点:
Up to 171 microsteps (256 sine wave steps) using step/direction interface or 20 Bit SPI™interface
High precision sensorless motor load measurement stallGuard2
Energy efficiency and coolness by automatic load dependant motor current regulation coolStep™s20 : Save up to 75% of energy!
Internal microstep extrapolation allows 256 wave step smoothness with low frequency step input
Dual edge step option allows half step frequency requirement, e.g. for opto-couplers
Up to 8A Motor current using external N&P channel MOSFET pairs
Synchronous rectification reduces transistor heating
9V to 60V operating voltage (peak)
3.3V or 5V interface
QFN32 package for extremely small solution with superior thermal performance
EMV optimized current controlled gate drivers – up to 45mA gate current
Overcurrent, short to GND and overtemperature protection and diagnostics integrated
TMC389应用:
Precision three phase stepper motor drives
Stage lighting
Medical applications
Optical applications
Robotics
Motor type
3 phase Stepper
图1.TMC389基本应用框图
图2.TMC389方框图和应用电路图
图2.TMC389采用外接栅极驱动器的高压大电流功率级电路图
图2.TMC429 StepDir控制器和SPI互连的示例图
TMC389评估板
The TMC389 evaluation board features a TMC389 with external power MOSFETs plus a microcontroller, which allows interfacing to a PC for visualization and control of all parameters. The motor can be operated via the step and direction interface, using either an external source, or using the integrated microcontroller as a step pulse generator.
The TMC389-EVAL allows you to explore all functions of the TMC389. The evaluation board comes with a PC software which gives you access to every function of the driver. It comes along with a Step&Direction interface, a RS232 and a USB port. The TMC389-Eval is a complete "plug and play" solution, additionally only a motor, a PC and a power supply are required!
TMC389评估板亮点:
Evaluate all features of the TMC389
Use stallGuard2™ with your motor
Use coolStep™ with your motor
Control all parameters from a PC
Motor current can be set to up 6A depending on sense resistor selection.
Supply voltage up to 40V (MOSFETs can be exchanged against 60V 2A types)
Access all pins of the TMC389
Motor type
3 phase Stepper
TMC389-EVAL contains
TMC389-Evaluation Board
USB cable for connection to PC
software for Windows (downloadable)
documentation, board and circuit description and all datasheets (downloadable)
图3.TMC389-EVAL评估板外形图
图4.TMC389-EVAL评估板应用框图
图5.TMC389-EVAL评估板元件布局图
图6.TMC389-EVAL评估板电路图(1)
图7.TMC389-EVAL评估板电路图(2)
图8.TMC389-EVAL评估板电路图(3)
图9.TMC389-EVAL评估板电路图(4)
详情请见:
http://www.trinamic.com/tmctechlibcd/integrated_circuits/TMC389/TMC389_datasheet.pdf
和
http://www.trinamic.com/tmctechlibcd/integrated_circuits/TMC389/TMC389-EVAL/TMC389-EVAL_manual.pdf
以及
http://www.trinamic.com/tmctechlibcd/integrated_circuits/TMC389/TMC389-EVAL/TMC389-EVAL_V10_schematic.pdf
上一篇:利用8位带2KB闪存MCU的设计离线锂电池充电器
下一篇:LCD和相机总线方案中的功率转折点
推荐阅读最新更新时间:2023-10-18 16:43
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- 非常见问题解答第223期:如何在没有软启动方程的情况下测量和确定软启动时序?
- Vicor高性能电源模块助力低空航空电子设备和 EVTOL的发展
- Bourns 推出两款厚膜电阻系列,具备高功率耗散能力, 采用紧凑型 TO-220 和 DPAK 封装设计
- Bourns 全新高脉冲制动电阻系列问世,展现卓越能量消散能力
- Nexperia推出新款120 V/4 A半桥栅极驱动器,进一步提高工业和汽车应用的鲁棒性和效率
- 英飞凌推出高效率、高功率密度的新一代氮化镓功率分立器件
- Vishay 新款150 V MOSFET具备业界领先的功率损耗性能
- 强茂SGT MOSFET第一代系列:创新槽沟技术 车规级60 V N通道 突破车用电子的高效表现
- 面向车载应用的 DC/DC 电源
