The LTM.4607 is a high efficiency switching mode buckboost power supply. Included in the package are the switching controller, power FETs, and support components.
Operating over an input voltage range of 4.5V to 36V, the LTM4607 supports an output voltage range of 0.8V to 24V, set by a resistor. This high efficiency design delivers up to 5A continuous current in boost mode (10A in buck mode). Only the inductor, sense resistor, bulk input and output capacitors are needed to finish the design.
The low profile package enables utilization of unused space on the bottom of PC boards for high density point of load regulation. The high switching frequency and current mode architecture enable a very fast transient response to line and load changes without sacrificing stability. The LTM4607 can be frequency synchronized with an external clock to reduce undesirable frequency harmonics.
Fault protection features include overvoltage and foldback current protection. The DC/DC μModule. regulator is offered in a small thermally enhanced 15mmx15mmx2.8mm LGA package. The LTM4607 is Pb-free and RoHS compliant.
LTM4607主要特性:
Single Inductor Architecture Allows VIN Above, Below or Equal to VOUT
Wide VIN Range: 4.5V to 36V
Wide VOUT Range: 0.8V to 24V
5A DC (10A DC in Buck Mode)
High Efficiency Up to 98%
Current Mode Control
Power Good Output Signal
Phase-Lockable Fixed Frequency: 200kHz to 400kHz
Ultrafast Transient Response
Current Foldback Protection
Output Overvoltage Protection
Small, Low Profile Surface Mount LGA Package (15mm x15mmx2.8mm)
LTM4607应用:
Telecom, Servers and Networking Equipment
Industrial and Automotive Equipment
High Power Battery-Operated Devices
图1.LTM4607简化框图
图2.LTM4607输入12V-36V降压模式应用电路
图3.LTM4607输入5V-12V升压模式低开关噪音应用电路
图4.LTM4607输入5V-36V输出12V/5A宽输入模式应用电路
图5.LTM4607 5V/10A设计电路
图6.LTM4607两相并联12V/10A设计电路
图7.LTM4607降压模式正到负-12V输出设计电路
演示板DC1601B
Demonstration circuit DC1601B is a PolyPhase. power supply featuring the LTM.4607 power module, a complete high efficiency switching mode buck-boost power supply.
The DC1601B input voltage range is from 6V to 36V and is capable of delivering high power through paralleled LTM4607 modules. The demo circuit can deliver up to 10A of output current for two paralleled modules (DC1601B-A), 15A for three paralleled modules (DC1601B-B) and up to 20A for four paralleled modules (DC1601B-C). The DC1601B demonstrates that paralleling modules is easy and reliable.
The output voltage for the board is 12V. The rated load current per module is 5A in boost mode, however current derating may be necessary under certain VIN, VOUT, frequency, and thermal conditions. An onboard external clock is provided for synchronization and interleaving of L, LT, LTC, LTM, Linear Technology, PolyPhase and the Linear logo are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their respective owners.
phases to minimize input and output ripple. An internal phase-locked loop allows the LTM4607 to be synchronized to an external clock within the range of 200kHz to 400kHz. The LTM4607 default switching frequency on the DC1601B is set to 300kHz through the onboard LTC6902 clock generator which interleaves the paralleled phases.
The frequency and phase separation set by the LTC6902 are resistor programmable.
These features, including the availability of the LTM4607 in a compact thermally enhanced 15mmx15mmx2.8mm LGA package make the demonstration circuit ideal for use in high density point of load regulation applications.
图8. 演示板DC1601B外形图
演示板DC1601B性能指标(TA = 25℃):
图9. 演示板DC1601B电路图(1)
图10. 演示板DC1601B电路图(2)
图11. 演示板DC1601B电路图(3)
演示板DC1601B材料清单:
演示板1601B-A材料清单:
演示板1601B-B材料清单:
演示板1601B-C材料清单:
详情请见:
http://cds.linear.com/docs/Datasheet/4607fb.pdf
和
http://cds.linear.com/docs/Demo%20Board%20Manual/dc1601bf.pdf
上一篇:基于AT91SAM7L的极低功耗系统设计
下一篇:基于PLC的碟式太阳能跟踪控制系统设计
推荐阅读最新更新时间:2023-10-18 16:50
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- 非常见问题解答第223期:如何在没有软启动方程的情况下测量和确定软启动时序?
- Vicor高性能电源模块助力低空航空电子设备和 EVTOL的发展
- Bourns 推出两款厚膜电阻系列,具备高功率耗散能力, 采用紧凑型 TO-220 和 DPAK 封装设计
- Bourns 全新高脉冲制动电阻系列问世,展现卓越能量消散能力
- Nexperia推出新款120 V/4 A半桥栅极驱动器,进一步提高工业和汽车应用的鲁棒性和效率
- 英飞凌推出高效率、高功率密度的新一代氮化镓功率分立器件
- Vishay 新款150 V MOSFET具备业界领先的功率损耗性能
- 强茂SGT MOSFET第一代系列:创新槽沟技术 车规级60 V N通道 突破车用电子的高效表现
- 面向车载应用的 DC/DC 电源
