ADIADP1853输出20ADC-DC转换解决方案
最新更新时间:2012-07-03来源: chinaaet关键字:电源管理  DC/DC转换器  开关电源 手机看文章 扫描二维码
随时随地手机看文章
ADI 公司的ADP1853是宽输入电压DC/DC同步降压控制器,输入电压从3.3V到12V(高达20V),电压跟踪输入,输出电压0.6V到90%VIN,通常工作在电流模式以得到更快的响应速度.最大输出电流大于25A,输出电压对温度的精度±1%,可编频率200 kHz到1.5 MHz,主要用于中间总线和POL系统,通信基站和网络,工业和仪表,医疗和保健设备.本文介绍了ADP1853主要特性,方框图,典型应用电路图,15A电流模式和25A电压模式应用电路图,以及ADP1853评估板主要特性,电路图,材料清单和PCB元件布局图.
 The ADP1853 is a wide range input, dc-to-dc, synchronous buck controller capable of running from commonly used 3.3 V to 12 V (up to 20 V) voltage inputs. The device nominally operates in current mode with valley current sensing providing the fastest step response for digital loads. It can also be configured as a voltage mode controller with low noise and crosstalk for sensitive loads.
The ADP1853 can be used as a master synchronization clock for the power system and for convenient synchronization between controllers. The CLKOUT signal can synchronize other devices in the ADP185x family such that slave devices are phase-shifted from the master to reduce the input ripple current, improve EMI, and reduce the size of the input bulk capacitance. The ADP1853 can also be configured as a slave device for current sharing. Additionally, the ADP1853 includes accurate tracking, precision enable, and power good functions for sequencing. The ADP1853 provides a high speed, high peak current gate driving capability to enable energy efficient power conversion. The device can be configured to operate in power saving mode by skipping pulses, reducing switching losses and improving efficiency at light load and standby conditions.
The accurate current limit allows design within a narrower range of tolerances and can reduce overall converter size and cost. The ADP1853 can regulate down to 0.6 V output using a high accuracy reference with ±1% tolerance over the temperature range from −0℃ to 125℃.
With a wide range input voltage, the ADP1853 is designed to provide the designer with maximum flexibility for use in a variety of system configurations; loop compensation, soft start, frequency setting, power saving mode, current limit, and current sense gain can all be programmed using external components. In addition, the external RAMP resistor allows choosing optimal slope and VIN feedforward in both current and voltage mode for excellent line rejection. The linear regulator and the boot strap diode for the high-side driver are internal.
Protection features include undervoltage lock out, overvoltage, overcurrent/short circuit, and overtemperature.
ADP1853主要特性:
Input voltage range: 2.75 V to 20 V
Output voltage range: 0.6 V to 90% VIN
Maximum output current of more than 25 A
Current mode architecture with current sense input
Configurable to voltage mode
±1% output voltage accuracy over temperature
Voltage tracking input
Programmable frequency: 200 kHz to 1.5 MHz
Synchronization input
Internal clock output
Power saving mode at light load
Precision enable input
Power good with internal pull-up resistor
Adjustable soft start
Programmable current sense gain
Integrated bootstrap diode
Starts into a precharged load
Externally adjustable slope compensation
Suitable for any output capacitor
Overvoltage and overcurrent-limit protection
Thermal overload protection
Input undervoltage lockout (UVLO)
Available in 20-lead, 4 mm × 4 mm LFCSP
Supported by ADIsimPower™design tool
ADP1853应用:
Intermediate bus and POL systems requiring sequencing and tracking, including
Telecom base station and networking
Industrial and Instrumentation
Medical and healthcare
图1.ADP1853方框图
图2.ADP1853典型应用电路图
图3.ADP1853两相应用电路图
图4.ADP1853 15A电流模式应用电路图
图5.ADP1853 25A电压模式应用电路图
ADP1853降压DC/DC控制器评估板
This document describes the design, operation, and test results of the ADP1853-EVALZ. The input voltage range for this evaluation board is 9 V to 15 V, and the regulated output voltage VOUT is set to 3.3 V with the maximum output current up to 20 A. The switching frequency (fSW) of 300 kHz is set to achieve high efficiency.
ADP1853评估板主要特性:
Input voltage range: 9 V to 15 V
Output voltage: 3.3 V
Output current: up to 20 A
Switching frequency: 300 kHz
Operates in PWM or PSM
Designed for evaluation of the ADP1853 functionality
Flexible and easy to re-configure and modify
图6.ADP1853评估板外形图
图7.ADP1853评估板电路图
ADP1853评估板材料清单:
图8.ADP1853评估板元件布局图(顶层)
详情请见:
http://www.analog.com/static/imported-files/data_sheets/ADP1853.pdf
http://www.analog.com/static/imported-files/user_guides/UG-431.pdf
关键字:电源管理  DC/DC转换器  开关电源 编辑:探路者 引用地址:ADIADP1853输出20ADC-DC转换解决方案
上一篇:为轻载工作而设计的非同步降压稳压器
下一篇:IRIR389516ASupIRBuck同步降压稳压器解决方案
推荐阅读最新更新时间:2023-10-18 16:55
开关电源开机时刻的过渡过程
前面我们分析过的所有 图1-19中,当工作开关由接通转为关断时,开关电源变压器次级线圈产生的反电动势为: 式中,q为电容存储的电荷量,C1和C2为待定系数,ω = ,为角频率,即电容器充放电的速率。这里为了简化在不容易混淆的情况下我们经常把电感L和电容C的下标省去。 当t = 0 时,q = 0,由此求得C1 = 0,当t = Toff时,由于电容容量很大,电容器一般在一个工作周期内是不可能充满电的,大约需要十几个周期以上才能充满。当电容充满电时,电容两端的电压就可以达到电源电压的峰值,即:q = UpC,由此,求得C2 = UpC,所以(1-112)式可以写为: 这里特别
[电源管理]
嵌入式便携设备中电源管理的分析与研究
引言   现今对电子系统设备性能的要求越来越高,在权衡电子系统的性能和功耗时,电子系统的性能往往得到更多的重视。容量有限的电池是便携设备的惟一能量来源,而电池容量的提高速度明显赶不上中央处理器性能的提高速度,因此,如何利用有限的电能为便携设备提供最高性能,是便携设备中电源管理的主要目标。除此之外,电源管理还要兼顾稳定性和散热性。电源管理模块是在可编程电源管理的设备上,为电源管理提供实现各种功耗模式的应用编程接口的软件模块。   功率消耗有两种方式: 静态功耗和动态功耗。静态功耗主要为晶体管泄漏(leakage)功率;动态功耗则来源于电路有效性激活,例如地址线或者数据线输入时引起的寄存器线路的有效性激活。开关电容所消耗的
[嵌入式]
适用于5V和12V电压轨的备份解决方案
在嵌入式系统需要可靠供电的电信、工业和汽车应用中,数据丢失是一个关切的问题。供电的突然中断会在硬盘和闪存器执行读写操作时损坏数据。我们常常使用电池、电容器和超级电容器来存储足够的能量,以在供电中断期间为关键的负载提供短期电源支持。 那么,有没有一种更简单的方法让我们来完成这些事儿呢? 于是,就有了 LTC3643,它能使我们采用一种相对便宜的储能元件——低成本电解电容器。本文将介绍的是一款电路,它使 LTC3643 用作针对 3.3V 电压轨的备份电源解决方案。 在这里提及的备份电源或保持电源中,当电源存在时,LTC3643 把存储电容器充电至 40V,而当电源中断时,LTC3643 则把该存储电容器的电能释放给关键的
[电源管理]
电源管理芯片厂商赛微微拟A股IPO,已经开启上市辅导
12月24日,据广东监管局披露,广东赛微微电子股份有限公司拟首次公开发行股票并上市,现已接受国泰君安证券的辅导,已于2020年12月21日在广东证监局办理了辅导备案登记。 资料显示,广东赛微微电子有限公司是一家电源和电池管理芯片无晶圆厂半导体公司。通过为业界提供先进的半导体产品及相关服务,成就安全环保、高效低成本的电池电源管理解决方案。产品线包括电池电量计芯片、电池管理芯片、电池保护芯片、BMS前端采集芯片以及USB充电控制芯片。涵盖移动通信、平板计算机、笔记本计算机、电动工具、电动交通工具、电池储能设备等诸多市场领域。
[手机便携]
<font color='red'>电源管理</font>芯片厂商赛微微拟A股IPO,已经开启上市辅导
简述LED灯条开关电源的基本构成与检测要点
关于LED灯条开关电源的基本构成 LED灯条 开关电源 的构成一般有LED二极管、IGBT和MOSFET这几部分。它由电路来控制开关管而进行高速的道通和截止,将直流电转化成高频交流电来给变换器进行变压,使其产生所需要的一组或多组电压,开关电源大体可以分为隔离和不隔离这两种,是隔离型的一定有开关电源变换器,而不隔离的未必一定有开关电源变换器。开关电源与传统直流电源相比具有体积小、重量轻、和效率高等优点。 关于LED灯条开关电源的检测要点 LED灯条 开关电源 是有电路来控制开关管而进行高速的道通和截止,是将直流电转化成高频交流电来给变换器进行变压,使其产生所需要的一组或多组电压,转化为高频交流电的道理是高频交流在变压器电路中的效率要
[电源管理]
用于 48V 电源的完整单 IC 电源管理电池维护 / 后备系统
提高便携性是电子设备一个共同的发展趋势;就是因为有人 拔掉了 电源插头 设备就被关断了,这种说法不再会被普遍接受。为了实现便携式功能,设备必须内置高级电源管理系统,其可控制从可用能量源至合适系统的电源通路、 保持后备元件处于满充电和就绪状态、并确保系统始终拥有足够的功率。 对于许多便携式设备 (例如:工作在低电压和低功率级别的智能手机或平板电脑),我们拥有现成的精致、单 IC 电源管理解决方案。面向高功率和高电压系统 (比如:许多工业或医疗设备所需的此类系统) 的电源管理解决方案通常需要使用笨重和复杂的专用分立式组件解决方案。LTC4020 把先进的电源管理功能整合到一款高电压和高功率单 IC 解决方案中,从而简化了这些环境
[电源管理]
用于 48V 电源的完整单 IC <font color='red'>电源管理</font>电池维护 / 后备系统
开关电源设计中如何区别及选用三极管和MOS管
三极管 的工作原理:三极管是电流放大器件,有三个极,分别叫做集电极C,基极B,发射极E。分成NPN和PNP两种。我们仅以NPN三极管的共发射极放大电路为例来说明一下三极管放大电路的基本原理。 我们把从基极B流至发射极E的电流叫做基极电流Ib;把从集电极C流至发射极E的电流叫做集电极电流 Ic。这两个电流的方向都是流出发射极的,所以发射极E上就用了一个箭头来表示电流的方向。三极管的放大作用就是:集电极电流受基极电流的控制(假设电源 能够提供给集电极足够大的电流的话),并且基极电流很小的变化,会引起集电极电流很大的变化,且变化满足一定的比例关系:集电极电流的变化量是基极电流变 化量的β倍,即电流变化被放大了β倍,所以我们把β叫做三极管
[电源管理]
AVR单片机控制的开关电源
单片机 控制开关电源,单从对电源输出的控制来说,可以有几种控制方式。 其一是 单片机 输出一个电压(经DA芯片或PWM方式),用作电源的基准电压。这种方式仅仅是用单片机代替了原来的基准电压,可以用按键输入电源的输出电压值,单片机并没有加入电源的反馈环,电源电路并没有什么改动。这种方式最简单。 其二是 单片机 扩展AD,不断检测电源的输出电压,根据电源输出电压与设定值之差,调整DA的输出,控制PWM芯片,间接控制电源的工作。这种方式单片机已加入到电源的反馈环中,代替原来的比较放大环节,单片机的程序要采用比较复杂的PID算法。 其三是 单片机 扩展AD,不断检测电源的输出电压,根据电源输出电压与设定值之差,输
[单片机]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
