The FSL206MR integrated Pulse-Width Modulator (PWM) and SenseFET is specifically designed for high performance offline Switched-Mode Power Supplies (SMPS) with minimal external components. This device integrates high-voltage power regulators that combine an avalanche-rugged SenseFET with a Current-Mode PWM control block.
The integrated PWM controller includes: 7.8V regulator for no bias winding, Under-Voltage Lockout (UVLO) protection, Leading-Edge Blanking (LEB), an optimized gate turn-on/turn-off driver, EMI attenuator, Thermal Shutdown (TSD) protection, temperature-compensated precision current sources for loop compensation, and fault-protection circuitry such as; Overload Protection (OLP), Over-Voltage Protection (OVP), Abnormal Over-Current Protection (AOCP), and Line Under-Voltage Protection (LUVP). During startup, the FSL206MR offers good soft-start performance.
The internal high-voltage startup switch and the Burst-Mode operation with very low operating current reduce the power loss in Standby Mode. As a result, it is possible to reach power loss of 150mW with no-bias winding and 25mW (for FSL206MR) or 30mW (for FSL206MRBN) with bias winding at no-load condition when the input voltage is 265VAC.
FSL206MR主要特性:
Internal Avalanche-Rugged SenseFET: 650V
Precision Fixed Operating Frequency: 67kHz
No-Load <150mW at 265VAC without Bias Winding;<25mW with Bias Winding for FSL206MR, <30mW with Bias Winding for FSL206MRBN
No Need for Auxiliary Bias Winding
Frequency Modulation for Attenuating EMI
Pulse-by-Pulse Current Limiting
Low Under-Voltage Lockout (UVLO)
Ultra-Low Operating Current: 300A
Built-In Soft-Start and Startup Circuit
Various Protections: Overload Protection (OLP),Over-Voltage Protection (OVP), Thermal Shutdown (TSD), Abnormal Over-Current Protection (AOCP) Auto-Restart Mode for All Protections
FSL206MR应用:
SMPS for STB, DVD, and DVCD Player
SMPS for Auxiliary Power
图1.FSL206MR方框图
图2.FSL206MR典型应用电路图
FSL206MR 5W评估板
5W电源主要指标:
图3.FSL206MR 5W评估板外形图
图4.FSL206MR 5W评估板电路图
FSL206MR 5W评估板材料清单:
图5.FSL206MR 5W评估板PCB布局图(顶层)
图6.FSL206MR 5W评估板PCB布局图(底层)
详情请见:
http://www.fairchildsemi.com/ds/FS/FSL206MR.pdf
和
http://www.fairchildsemi.com/products/evaluationboards/FEBFSL206MRN_H428v1e.pdf?user-guide=
上一篇:ADIADP244136V1A效率94%降压DC电源稳压方案
下一篇:NXPTEA1721FT小型低成本5W电源解决方案
推荐阅读最新更新时间:2023-10-17 14:58
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- 英飞凌推出符合ASIL-D标准的新型汽车制动系统和电动助力转向系统三相栅极驱动器 IC
- 南芯科技推出80V升降压转换器,持续深耕工业储能市场
- 法雷奥与罗姆联合开发新一代功率电子领域
- 贸泽电子开售能为电动汽车牵引逆变器提供可扩展性能的 英飞凌HybridPACK Drive G2模块
- Vishay推出采用eSMP®系列SMF(DO-219AB)封装的全新1 A和2 A Gen 7 1200 V FRED Pt®超快恢复整流器
- Littelfuse推出高性能超级结X4-Class 200V功率MOSFET
- 恩智浦发布首个超宽带无线电池管理系统解决方案
- 非常见问题解答第223期:如何在没有软启动方程的情况下测量和确定软启动时序?
- Vicor高性能电源模块助力低空航空电子设备和 EVTOL的发展
