TRINAMICTMC262两相步进马达驱动方案
最新更新时间:2012-08-16来源: chinaaet关键字:工业控制  马达驱动  步进马达 手机看文章 扫描二维码
随时随地手机看文章
马达驱动器,具有业界一流的特性,包括高分辨率的微步距,无传感器机械负载测量,负载自适应的功率优化,低谐振斩波工作,标准的 PI和STEP/DIR接口简化了通信.TMC262能驱动四个外接N沟和P沟双MOSFET,马达电流高达8A和60V,主要用在缝纫机,工厂自动化,打印机与扫描仪,办公自动化,医疗设备,液体处理,ATM和POS等.本文介绍了TMC262主要特性和优势,方框图,应用方框图和高压大电流功率级电路图以及评估板TMC262–EVAL主要特性,应用框图,电路图和PCB元件布局图.
The TMC262 driver for two-phase stepper motors offers an industry-leading feature set, including high-resolution microstepping, sensorless mechanical load measurement, load-adaptive power optimization, and low-resonance chopper operation. Standard SPI™ and STEP/DIR interfaces simplify communication. The TMC262 drives four external N- and Pchannel dual MOSFETs for motor currents up to 8A and up to 60V. Integrated protection and diagnostic features support robust and reliable operation.
High integration, high energy efficiency and small form factor enable miniaturized designs with low external component count for cost-effective and highly competitive solutions.
TMC262主要特性和优势:
High Current up to 8A Motor current using external (N&P) MOSFETs.
Highest Voltage up to 60V DC operating voltage
Highest Resolution up to 256 microsteps per full step
Smallest Size 5x5mm QFN32 package
Low Power Dissipation synchronous rectification
EMI-optimized slope & current controlled gate drivers
Protection & Diagnostics overcurrent, short to GND, overtemperature & undervoltage
stallGuard2™ high precision sensorless motor load detection
coolStep™ load dependent current control for energy savings up to 75%
microPlyer™ microstep interpolation for increased smoothness with coarse step inputs.
spreadCycle™ high-precision chopper for best current sine wave form and zero crossing
TMC262应用:
Textile, Sewing Machines
Factory Automation
Printing
Lab Automation
Liquid Handling
Medical
Office Automation
Printer and Scanner
CCTV, Security
ATM, Cash recycler
POS
Pumps and Valves
Heliostat Controller
CNC Machines
图1.TMC262方框图
图2.TMC262功能方框图
图3.TMC262应用方框图
图4.TMC262采用外接栅极驱动器的高压大电流功率级电路图
图5.TMC262采用外接栅极驱动器和短路接地保护的大电流功率级电路图
评估板TMC262–EVAL
Evaluation board for the TMC262 stepper motor driver IC with coolStep
评估板TMC262–EVAL主要特性:
The TMC262 evaluation board features a TMC262 with external power MOSFETs plus a microcontroller, which allows interfacing to a PC for visualization and control of all parameters. The motor can be operated via the step and direction interface both, using an external source, and using the integrated microcontroller as a step generator.
The TMC262-EVAL allows you to explore all functions of the TMC262. The evaluation board comes with a PC software which gives you access to every function of the driver. It comes along with a Step&Direction interface, a RS232 and a USB port. The TMC262-Eval is a complete "plug and play" solution, additionally only a motor, a PC and a power supply are required!
评估板TMC262–EVAL亮点:
 Evaluate all features of the TMC262
 Use stallGuard2™ with your motor
 Use coolStep™ with your motor
 Control all parameters from a PC using special software or TMCL-PC
 Motor current can be set to up to 1A, 2A or up to 4A (soldering jumper) via on-board sense resistors
 Supply voltage up to 40V (MOSFETs can be exchanged against 60V 2A types)
 Access all pins of the TMC262
Motor type
 2 phase Stepper
TMC262-EVAL contains
TMC262-Evaluation Board
USB cable for connection to PC
software for Windows (downloadable)
documentation, board and circuit description and all datasheets (downloadable)
图6.评估板TMC262–EVAL外形图
图7.评估板TMC262–EVAL应用框图
图8.评估板TMC262–EVAL电路图(1)
图9.评估板TMC262–EVAL电路图(2)
图10.评估板TMC262–EVAL电路图(3)
图11.评估板TMC262–EVAL电路图(4)
图12.评估板TMC262–EVAL PCB元件布局图
详情请见:
http://www.trinamic.com/tmctechlibcd/integrated_circuits/TMC262/TMC262_datasheet.pdf
http://www.trinamic.com/tmctechlibcd/integrated_circuits/TMC260_261_262/TMC262-EVAL/TMC262_EVAL_V10_schematic.pdf
关键字:工业控制  马达驱动  步进马达 编辑:探路者 引用地址:TRINAMICTMC262两相步进马达驱动方案
上一篇:PLC及变频调速技术在泵站恒压供水中的应用
下一篇:预计第二季度电源管理芯片营业收入恢复增长
推荐阅读最新更新时间:2023-10-17 15:01
基于Agent的智能控制系统的设计
  智能控制系统是一个能以人类专家水平完成专门任务的智能计算机控制系统,是伴随计算机研究、应用日益发展的,通过模仿人类专家应用其知识与经验的方法解决控制问题。在运用智能控制系统时,一般有多个控制参数,因此在做出控制决策时需要进行决策分析,从而确定控制方法。所以有必要在智能控制系统中融入决策分析的相关技术和方法,使控制决策更科学、合理。   Agent技术是分布式人工智能的一个概念。Agent是在一定环境下能独立自主运行的实体,它具有智能,有自己的知识;它具有学习功能,能够感知环境,并对环境的变化做出反应;多Agent实现了知识的分布,能够相互合作,共同完成任务。随着人工智能的发展,Agent技术得到广泛应用,把Agent技术
[工业控制]
NI 推出配备Intel酷睿双核处理器的工业控制
美国国家仪器有限公司(National Instruments,简称NI)近日发布了最新NI 31xx系列工业控制器,该系列控制器可以与NI测试测量平台相连接,并为长期的发布应用提供无风扇的设计。NI 3110工业控制器配备主频1.66GHz的双核处理器Intel SL9JT L2400,而NI 3100工业控制器则配有Intel 1.06GHz 赛扬M423处理器,两款控制器均装有Windows XP操作系统。这些新控制器对于在严酷环境下需要具有有无风扇散热功能,并可以通过USB、MXI Express、以太网和PCI或PCI Express连接到外部设备的工程应用来说,无疑是个理想的选择! 通过NI 3110工
[工业控制]
西班牙SEAT应对工业4.0培训未来人才
西班牙SEAT汽车积极备战,针对工业4.0时代将面临的挑战引进培训课程,以强调互动和生动有趣的教学方式,让旗下1.4万名员工了解工业4.0真正的意义,以及第四波工业革命的重点。  SEAT对每位员工的投资额是平均值的4倍,每年达到1,600万美元。 据Automotive World报导,员工将实际操作未来几年会广泛使用的工具和技术,例如虚拟现实(VR)、协作型机器人、3D打印、增强现实(AR)。SEAT已经采用部分新技术,例如智慧眼镜、自主合作型机器人,让位于巴塞罗那近郊的Martorell工厂成为智能工厂的标竿。 学员也了解第四波工业革命完成前,必须先历经哪些制造转型阶段。该课程以实验和博物馆模式出发,邀请学员跟课程内容进行
[嵌入式]
中颖单片机双核(DSP和MCU)SH99F100基于工业控制中的应用
双核(DSP和MCU)-工业控制中的应用 SH99F100是一款双核(DSP和MCU)芯片,适用于工业控制场合,如电机调速、变频电源等。MCU可以用来处理开关量、输入输出以及通讯,而DSP只需专注于控制算法的运算。 DSP的架构由三个并行的计算单元(ALU,MAC,SHIFTER)、两个独立的地址发生器(DAG)和一个强大的程序序列发生器(PSQ)组成。计算单元提供了所有处理器能够提供的计算功能,包括单周期乘/累加,位操作,移位操作等。双数据地址发生器使得处理器能够在一个周期内从两个数据存储区(Data Memory和Program Memory)同时取出两个数据。程序序列发生器实现了所有指令的单周期操作,快速的中断响应以及嵌套的
[单片机]
工业控制中混合有源电力滤波器的仿真研究
  1 引言   电力电子产品广泛应用于工业控制领域,并且用户对电能质量要求越来越高,其中最为突出的是电压质量和谐波问题。因此,如何提高电压质量、治理谐波就成为输配电技术中最为迫切的问题之一。低成本的无源滤波器PF(Passive Filter)是目前普遍采用的补偿方法,但其滤波效果与系统运行参数密切相关,在特定情况下无源滤波器还可能与系统发生谐振。80年代以来,利用功率开关的有源电力滤波器APF(Active Power Filter)的研究越来越引起人们关注。APF是一种用于动态谐波抑制、无功补偿的新型电力电子装置,但是由于电源电压直接加在逆变桥上,其对开关器件电压等级要求较高;当负载谐波电流大时,有源滤波装置的容量也相
[工业控制]
制造业不只是卖产品,更要卖成果
假设你拥有一家航空公司,向劳斯莱斯或通用公司订购了一具引擎。你真正寻求的是什么?是一具符合产品需求的机器,还是一件性能好、安全可靠的工具,把乘客安全地送达目的地?下面就随工业控制小编一起来了解一下相关内容吧。 以上是近来力求有获利的成长的制造业业者正在思考的问题,这类的思考引发了企业在营运上的一项重大的转变,变得愈来愈重视成果。技术进步和物联网(Internet of Things),让这种成果导向变得愈来愈可行。例如,劳斯莱斯或通用公司提出按飞行时数收费的引擎解决方案时,提供给顾客的就是成果,以及更多的潜在价值。 制造业不只是卖产品,更要卖成果 然而,成为成果导向的组织,并不像表面看来那么简单。要进行这种转型,制造业者必
[工业控制]
工业控制系统的信息安全问题探讨
随着计算机和网络技术的发展,信息化与工业化深度融合以及物联网的快速发展,工业控制系统产品越来越多地采用通用协议、通用硬件和通用软件。网络化浪潮又将诸如嵌入式技术、多标准工业控制网络互联、无线技术等新兴技术融合进来,从而拓展了工业控制的发展空间,带来新的发展机遇。同时还带来了工业控制系统的信息安全等问题。 2010年,一种强大的旨在攻击西门子制造的工业控制系统的计算机病毒“Stuxnet”出现,该病毒会传播到插入电脑USB接口的设备中,并从中窃取数据。这是骇客首次尝试入侵大型工业电脑系统病毒。此次事件敲响了“防范病毒攻击”的警钟。 2010年“震网”病毒事件破坏了伊朗核设施,震惊全球。这标志着网络攻击从传统“软攻击”阶段升级
[嵌入式]
详解工业控制系统SCADA/DCS/PLC
工业控制系统(ICS)是一个通用术语,涵盖多种类型的控制系统,包括监控和数据采集(SCADA)系统,分布式控制系统(DCS),和其他较小的控制系统配置,如经常在工业部门和关键基础设施中用到的防滑安装的可编程逻辑控制器(PLC)。ICS通常使用于电力,水利,石油和天然气,化学,运输,制药,纸浆,食品和饮料以及离散制造(例如,汽车,航空和耐用品)和造纸等行业。 控制系统对于经常高度重视的美国关键基础设施的运行至关重要互连和相互依赖的系统。重要的是要注意,大约90%的国家的关键基础设施是私人拥有和经营。联邦机构也经营许多的上述工业流程;其他例子包括空中交通管制和材料处理(例如,邮政服务邮件处理)本节提供了SCADA,DCS和PLC系统,
[嵌入式]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
