本文介绍了PCF8811主要特性和优势,方框图,以及几种典型应用框图。
PCF8811是NXP公司的低功耗80x126象素CMOS LCD控制器,具有80行和128列输出,显示器数据RAM 80x128位,具有8位并行接口,3/4路SPI和高速I2C总线,适合于以电池为能源的系统,主要用于汽车显示器,通信设备,手提仪表和POS终端。
PCF8811:80 x 128 pixels matrix LCD driver
The PCF8811 is a low-power CMOS1 LCD controller and driver, designed to drive a graphic display of 80 rows and 128 columns or a graphic display of 79 rows and 128 columns and an icon row of 128 symbols. All necessary functions for the display are provided in a single chip, including on-chip generation of the LCD supply and bias voltages, resulting in a minimum of external components and low power consumption. The PCF8811 can interface microcontrollers via a parallel bus, serial bus or I2C-bus interface.
PCF8811主要特性和优势:
Single-chip LCD controller and driver
80 row and 128 column outputs
Display data RAM 80 × 128 bit
128 icons (row 80 can be used for icons in extended command set and when icon rows are enabled)
Low power consumption; suitable for battery operated systems
Interfaces: an 8-bit parallel interface, 3 or 4-line Serial Peripheral Interface (SPI) and High-speed I2C-bus
On-chip:
Configurable voltage multiplier generating LCD supply voltage VLCD; an external VLCD is also possible
Linear temperature compensation of VLCD; 8 programmable temperature coefficients (extended command set); one fixed temperature coefficient which can be set as default by OTP programming (basic command set)
Generation of intermediate LCD bias voltage
Oscillator requires no external components
OTP calibration for VLCD and accurate frame frequency
External reset input pad
External clock input possible
Multiplex rate: 1:16 to 1:80 in steps of 8 when no icon row is used; with the icon row, steps of 16 can be used
Logic supply voltage range VDD1 to VSS:
1.7 V to 3.3 V
High-voltage multiplier supply voltage range VDD2, VDD3 to VSS:
1.8 V to 3.3 V
Display supply voltage range VLCD to VSS:
3 V to 9 V
Programmable bottom row pads mirroring; for compatibility with both Tape Carrier Packages (TCP) and Chip-On-Glass (COG) applications (extended command set)
Status read, which allows for chip recognition and content checking of some registers
Start address line which allows, for instance, the scrolling of the displayed image
Programmable display RAM pointers for variable display sizes
Slim chip layout, suited for COG applications
Temperature range: Tamb = −40℃ to +85℃
CMOS compatible inputs
PCF8811应用:
Automotive displays
Telecom equipment
Portable instruments
Point-of-sale terminals
图1。PCF8811方框图
图2。PCF8811应用框图:内部电荷泵和单电源
图3。PCF8811应用框图:内部电荷泵和两个分立电源(VDD1和VDD2)
图4。PCF8811应用框图:外接高压
上一篇:基于AD2S82A的天线方位角的数字变换的设计
下一篇:单片机应用编程技巧
设计资源 培训 开发板 精华推荐
- Allegro MicroSystems 在 2024 年德国慕尼黑电子展上推出先进的磁性和电感式位置感测解决方案
- 左手车钥匙,右手活体检测雷达,UWB上车势在必行!
- 狂飙十年,国产CIS挤上牌桌
- 神盾短刀电池+雷神EM-i超级电混,吉利新能源甩出了两张“王炸”
- 浅谈功能安全之故障(fault),错误(error),失效(failure)
- 智能汽车2.0周期,这几大核心产业链迎来重大机会!
- 美日研发新型电池,宁德时代面临挑战?中国新能源电池产业如何应对?
- Rambus推出业界首款HBM 4控制器IP:背后有哪些技术细节?
- 村田推出高精度汽车用6轴惯性传感器
- 福特获得预充电报警专利 有助于节约成本和应对紧急情况
