转两个stm32定时器的使用代码
发布者:国宝集团最新更新时间:2015-06-12 来源: 51hei关键字:stm32  定时器  使用代码 手机看文章 扫描二维码
随时随地手机看文章
具体没有测试,先收藏,以后去尝试一下
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
    TIM_OCInitStructure.TIM_Pulse = Pluse;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
    TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
    TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;
    TIM_OC1Init(BLDC_TIMER_NUM, &TIM_OCInitStructure);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
    Pluse = MotorA.TimerPeriod - Pluse;
    TIM_OC2Init(BLDC_TIMER_NUM, &TIM_OCInitStructure);
#define   Fsys           72000000ul   //  system freq 72MHz
#define   Fpwm           20000        //  PWM freq  20K
void  ConfigTimer(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  GPIO_InitTypeDef GPIO_InitStructure;
  RCC_APB1PeriphClockCmd(  RCC_APB1Periph_TIM4,ENABLE);
  RCC_APB2PeriphClockCmd(  RCC_APB2Periph_GPIOB,ENABLE);
  TIM_DeInit(TIM4);
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1;
  TIM_TimeBaseStructure.TIM_Period = (Fsys/2) / Fpwm;
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM4,&TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputState_Disable;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OCInitStructure.TIM_Pulse = (((Fsys/2) / Fpwm) * 20) / 100;
  TIM_OC3Init(TIM4,&TIM_OCInitStructure);
  TIM_OCInitStructure.TIM_Pulse = (((Fsys/2) / Fpwm) * (100-20)) / 100;
  TIM_OC4Init(TIM4,&TIM_OCInitStructure);
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_8 | GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  TIM_CtrlPWMOutputs(TIM4, ENABLE);
  TIM_Cmd(TIM4,ENABLE);
基本设置如下:
1)配置定时器的计数器为中间对齐计数,即先向上计数再向下计数。
2)在该定时器上选择2个通道,并分别配置为输出比较模式,并配置在比较成功时翻转对应的引脚输出。
3)配置自动重装载寄存器TIMx_ARR为要求输出频率的一半。
4)假定CC1为第一个输出信号的通道,再假定第一个信号的正脉冲宽度对应为W1,则配置TIMx_CCR1为TIMx_ARR-W1/2。
5) 同4),假定CC2为第二个输出信号的通道,正脉冲宽度对应为W2,配置TIMx_CCR2为W2/2。
下面以一个例子说明:
假设要求输出的信号频率为10kHz,占空比为1:3。
再假设定时器的输入时钟为72MHz。
输出信号的频率10kHz,换算为计数器的数值为7200。
按照上述3),设置TIMx_ARR=3600
输出信号1的高电平时间W1,换算为计数器的数值为W1=7200/4=1800
按照上述4),设置TIMx_CC1=3600 - W1/2=2700
输出信号2的高电平时间W2,换算为计数器的数值为W2=7200/4=1800
按照上述5),设置TIMx_CC2=2/2=450
参照下图,图中红线表示计数器的数值变化:
①当计数器的数值从0向上计数,达到TIMx_CC1时,CC1匹配成功,CC1的输出电平翻转;
②计数器继续向上计数,达到TIMx_ARR时开始调头向下计数;当计数器的数值下降到TIMx_CC1时,CC1再次匹配成功,CC1的输出电平再次翻转;
③计数器继续向下计数,达到到TIMx_CC2时,CC2匹配成功,CC2的输出电平翻转;
④计数器继续向下计数,减到0时开始调头向上计数;当计数器的数值上升到TIMx_CC2时,CC2再次匹配成功,CC2的输出电平再次翻转;
如此循环,得到连续的相位互为180度的两路输出波形。
注意:上述描述是一个原理性的说明,但能够输出要求的波形并且占空比可调,实际编程计算中需要可能需要对某些数值加1或者减1,以达到准确地输出。
关键字:stm32  定时器  使用代码 引用地址:转两个stm32定时器的使用代码
上一篇:STM32 PWM模式相位与设置
下一篇:STM32的IO的配置和模式
推荐阅读最新更新时间:2024-03-16 14:03
stm32 上电初始化串口输出一个字节FF问题
最近玩stm32,使用串口发送数据在PC端使用串口工具检测接收到的数据,发现每次上电串口工具都会蹦出一个FF,这让我郁闷好久。在网上查了好多解决问题的办法,有的说先初始化UART 在初始化UART对应的GPIO脚,有的说把中断关闭等等 。我试了都不行,串口还是会发送FF,简直郁闷。。。。 后来我单步调试,发现在初始化的时候函数GPIO_PinAFConfig();初始化导致串口上电在TX脚上输出一个高电平。所以我就尝试在函数GPIO_Iinit();初始化之前首先初始化GPIO_PinAFConfig();这样就不会出现FF了。。。 总之解决办法如下就不会出现问题: 1.开启IO和外设USART时钟
[单片机]
STM32学习第四课:STM32 c语言学习基础4
1.结构体的参数传递 在进行传值的时候,用结构体封装有利于函数的传递。 用指向结构体变量的指针作为函数参数。 结构体做函数参数有三种传递方式: 一:是传递结构体变量,这是值传递 二:是传递结构体指针,这是地址传递 三:是传递结构体成员,当然这也分为值传递和地址传递。 以传引用调用方式传递结构比用传值方式传递结构效率高。以传值方式传递结构需要对整个结构做一份拷贝。 下面看一个列子,student结构体中包含该学生的各种信息,我们在change函数中对其进行部分修改,再在主函数中输出其结果 1.下面传递结构体变量 #include stdio.h #include string.h #define format %dn
[单片机]
<font color='red'>STM32</font>学习第四课:<font color='red'>STM32</font> c语言学习基础4
毕业设计| STM32+TI BQ76940设计48V BMS方案
这是根据TI官方那个方案改:精确监测和 50μA 待机电流、13S、48V 锂离子电池组参考设计TIDA-010030,链接如下: https://www. ti.com.cn/tool/cn/TIDA- 010030#technicaldocuments 原方案里的MCU用的是TI自家的MSP430,由于没用过,我自己改成了STM32F103C8T6。 除了电量计这块没有进行充放电学习过程外,基本实现要求功能,自定义的过流,短路,过放,过温都行。可以自动识别充放电,充电过程进行电池均衡(这里设置了一节),防充电器倒冲(程序存在BUG我最后只做到了10V,如果一上来就低于10V就不管用了),CAN总线传输数据也整上了。BQ7
[单片机]
STM32看门狗与复位IC同时存在的注意事项
1写在前面 我们都知道在复杂环境,比如一些工厂,特别是在有大型机电设备的环境下,我们的电源信号、通信信号都有可能受到干扰。 那么,在这种情况下,我们软件和硬件都有必要做一定预防处理。 除了需要外接复位IC,同时,为了系统能稳定长期的工作,我们可能还有必要添加看门狗。 本文就围绕复位IC、看门狗展开相关内容的讲解。 2 MCU电路为什么要使用复位芯片? STM32都有一个最低工作电压(比如1.8V),当电源电压跌落到低于MCU所要求的最低值时,MCU工作可能发生混乱,造成程序跑飞,引起整机死机、误动作等现象。 使用复位IC的原理是通过确定的电压值(阈值)启动复位操作,同时排除瞬间干扰的影响,又有防止MCU在电源启动和关闭期间的误
[单片机]
<font color='red'>STM32</font>看门狗与复位IC同时存在的注意事项
STM32将JTAG口转换为普通IO方法介绍
在调试STM32单片机,端口不够用的时候可以将JTAG口关闭,只使用SW调试模式。这样就可以使用它的其他功能。。 具体方法:只要在初始化之前,将Debug设置为SW调试模式,然后在程序初始化的时候调用下面两句即可: RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//使能复用口时钟,这个必须要的。 AFIO- MAPR = 0x02000000; //释放出三个JTAG的口,做普通IO口线 ,具体可查阅STM32手册。 同样的道理,我们也可以选择将JTAG和SW模式全部关闭,这样下载程序貌似就得用串口了,也许也可以通过设置BOOT启动项来下载,但是这个方法没使用过,不敢
[单片机]
STM32 BH1750光线感应源程序
单片机源程序如下: #include bh1750.h #include delay.h #include timer.h u8 BUF ; u16 temp2=0; float lux=0; void bh1750_iic_init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE ); //使能GPIOB时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6;
[单片机]
STM32定时器中断关于何时清除中断的总结
问题:在调STM32的程序的时候,发现定时器(timer2)比自己设定的中断周期缩小了一倍。设定为10ms中断一次,但实测发现5ms便中断了一次。 初始化代码如下: void InitTimer2(void) { RCC- APB1ENR|=0x01; //enable clock,max clock=36M TIM2- PSC=71; // counter clock CK_CNT=72M/(71+1)=1M TIM2- ARR=10000; // 10000*1us=10ms TIM2- CR1 |=0x0080; //Auto-reload preload enable TIM2- EGR |=0x0001;
[单片机]
STMCU应用过程中与电源相关的案例分享
我们在从事STM32单片机的应用开发及调试过程中,往往会碰到各类异常。其中有不少比例的问题跟电源有关。对于一个电子产品而言,电源部分很关键、很重要,但在实际开发调试中,我们偶尔会有意无意的忽视它。这里分享几个实际案例,以加强刺激,加深印象。 毕竟因为电源问题可能导致的异常很多很多,这里分享几个案例算是抛砖引玉,希望大家在调试中对电源方面加以重视。个人认为,往往电源出问题时导致的异常时并不太好分析。多数时候异常表现得更为诡异或没章法。 注:下面提到的案例中异常原因都与电源有关,但并不是说出现类似异常时一定是电源的原因。 下面主要分享五个基于STM32应用的案例。 案例1:STM32芯片的PLL无法正常工作。 有人使用STM3
[单片机]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
