程序功能是把ADC1模块里通道14的输入电压转换后通过USART2发送到PC,在PC机上用串口调试助手观察接收数据:
STM32是12位ADC,测量结果基本还可以!程序用了DMA来传输ADC转换值,调高了读取速度。串口部分用是上一篇串口调试笔记里的代码。
#include
#include
#define ADC1_DR_Address ((u32)0x4001244C)
#ifdef __GNUC__
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif
vu16 ADC_ConvertedValue;
void RCC_Config(void);
void GPIO_Config(void);
void USART_Config(void);
void DMA_Config(void);
void ADC_Config(void);
void Put_String(u8 *p);
void Delay(vu32 nCount);
int main(void)
RCC_Config();
GPIO_Config();
USART_Config();
DMA_Config();
ADC_Config();
while(1)
Delay(0x8FFFF);
printf("ADC = %X Volt = %d mvrn", ADC_ConvertedValue, ADC_ConvertedValue*3300/4096);
ErrorStatus HSEStartUpStatus;//定义外部高速晶体启动状态枚举变量
RCC_DeInit();//复位RCC外部设备寄存器到默认值
RCC_HSEConfig(RCC_HSE_ON); //打开外部高速晶振
HSEStartUpStatus = RCC_WaitForHSEStartUp();//等待外部高速时钟准备好
if(HSEStartUpStatus == SUCCESS)//外部高速时钟已经准别好
RCC_HCLKConfig(RCC_SYSCLK_Div1);//配置AHB(HCLK)时钟=SYSCLK
RCC_PCLK2Config(RCC_HCLK_Div1); //配置APB2(PCLK2)钟=AHB时钟
RCC_PCLK1Config(RCC_HCLK_Div2);//配置APB1(PCLK1)钟=AHB 1/2时钟
RCC_ADCCLKConfig(RCC_PCLK2_Div4);//配置ADC时钟=PCLK2 1/4
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
//配置PLL时钟 == 外部高速晶体时钟*9
RCC_ADCCLKConfig(RCC_PCLK2_Div4);//配置ADC时钟= PCLK2/4
RCC_PLLCmd(ENABLE);//使能PLL时钟
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) //等待PLL时钟就绪
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//配置系统时钟 = PLL时钟
while(RCC_GetSYSCLKSource() != 0x08) //检查PLL时钟是否作为系统时钟
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA, ENABLE);//使能DMA时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC, ENABLE);
//使能ADC1,GPIOC时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_AFIO, ENABLE);
//打开GPIOD和AFIO时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);//使能串口2时钟
//设置RTS(PD.04),Tx(PD.05)为推拉输出模式
GPIO_InitTypeDef GPIO_InitStructure; //定义GPIO初始化结构体
GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE);//使能GPIO端口映射USART2
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;//选择PIN4 PIN5
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //引脚频率50M
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//引脚设置推拉输出
GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化GPIOD
//配置CTS (PD.03),USART2 Rx (PD.06)为浮点输入模式
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
//配置PC4为模拟输入
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_Init(GPIOC, &GPIO_InitStructure);
}[page]
DMA_InitTypeDef DMA_InitStructure;//定义DMA初始化结构体
DMA_DeInit(DMA_Channel1);//复位DMA通道1
DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; //定义 DMA通道外设基地址=ADC1_DR_Address
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue; //定义DMA通道存储器地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;//指定外设为源地址
DMA_InitStructure.DMA_BufferSize = 1;//定义DMA缓冲区大小1
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//当前外设寄存器地址不变
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;//当前存储器地址不变
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//定义外设数据宽度16位
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //定义存储器数据宽度16位
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//DMA通道操作模式位环形缓冲模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High;//DMA通道优先级高
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;//禁止DMA通道存储器到存储器传输
DMA_Init(DMA_Channel1, &DMA_InitStructure);//初始化DMA通道1
DMA_Cmd(DMA_Channel1, ENABLE); //使能DMA通道1
ADC_InitTypeDef ADC_InitStructure;//定义ADC初始化结构体变量
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//ADC1和ADC2工作在独立模式
ADC_InitStructure.ADC_ScanConvMode = ENABLE; //使能扫描
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//ADC转换工作在连续模式
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//有软件控制转换
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//转换数据右对齐
ADC_InitStructure.ADC_NbrOfChannel = 1;//转换通道为通道1
ADC_Init(ADC1, &ADC_InitStructure); //初始化ADC
ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1, ADC_SampleTime_28Cycles5);
//ADC1选择信道14,音序器等级1,采样时间239.5个周期
ADC_DMACmd(ADC1, ENABLE);//使能ADC1模块DMA
ADC_Cmd(ADC1, ENABLE);//使能ADC1
ADC_ResetCalibration(ADC1); //重置ADC1校准寄存器
while(ADC_GetResetCalibrationStatus(ADC1));//等待ADC1校准重置完成
ADC_StartCalibration(ADC1);//开始ADC1校准
while(ADC_GetCalibrationStatus(ADC1));//等待ADC1校准完成
ADC_SoftwareStartConvCmd(ADC1, ENABLE); //使能ADC1软件开始转换
USART_InitTypeDef USART_InitStructure; //定义串口初始化结构体
USART_InitStructure.USART_BaudRate = 115200;//波特率9600
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//8位数据
USART_InitStructure.USART_StopBits = USART_StopBits_1;//1个停止位
USART_InitStructure.USART_Parity = USART_Parity_No ; //无校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
//禁用RTSCTS硬件流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//使能发送接收
USART_InitStructure.USART_Clock = USART_Clock_Disable; //串口时钟禁止
USART_InitStructure.USART_CPOL = USART_CPOL_Low; //时钟下降沿有效
USART_InitStructure.USART_CPHA = USART_CPHA_2Edge;//数据在第二个时钟沿捕捉
USART_InitStructure.USART_LastBit = USART_LastBit_Disable;
//最后数据位的时钟脉冲不输出到SCLK引脚
USART_Init(USART2, &USART_InitStructure);//初始化串口2
USART_Cmd(USART2, ENABLE);//串口2使能
while(*p)
USART_SendData(USART2, *p++);
while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET)
for(; nCount != 0; nCount--);
PUTCHAR_PROTOTYPE
USART_SendData(USART2, (u8) ch);//发送一字节数据
}//等待发送完成
return ch;
void ADC_Configuration(void)
ADC_InitStructure.ADC_ScanConvMode = DISABLE;
ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1, ADC_SampleTime_13Cycles5);
ADCVal = ADC_GetConversionValue(ADC1); //查询方式
