MSP430F149有三个时钟源:外部LF(XT1一般为32.768K),HF(XT2一般为8M),内部DCO。从时钟系统模块可得到三种时钟信号:MCLK,SMCLK,ACLK。
上电默认状况下MCLK,SMCLK信号来自DCO,ACLK来自LF。根据官方PDF说法默认状况下DCO模块配置为RSELX=4,DCO=3,因此DCO应为1M,但示波器实测MCLK/SMCLK为680K,测试温度约25摄氏度。
标注:MCLK主时钟、SMCLK子时钟、ACLK活动时钟。
P5.4,P5.5,P5.6的第二功能分别对应MCLK,SMCLK,ACLK时钟信号,可用示波器测量。测试时发现频率后两位一直在跳动,频率稳定度很差。
MSP430系列单片机选择晶振为时钟源时,时钟周期就是晶振周期。一个机器周期 =一个时钟周期,即430每个动作都能完成一个基本操作; 一个指令周期 = 1~6个机器周期,具体根据具体指令而定。 如果选择8M晶振,则一个机器周期为125ns。51单片机选择12M晶振,它的机器周期是时钟周期/12,一个机器周期为1us,可见 MSP430的的速度是51的8倍。
2、使用方法概述
2.1 程序架构
一般在系统初始化关闭看门狗后要配置系统时钟,配置步骤为:
1、打开晶振;
2、等待晶振起振。清除OFIFG,延时,判断OFIFG是否为0,为0则晶振正常起振,退出判断;
3、选择MCLK/SMCLK时钟源;
uchar iq0;
BCSCTL1&=~XT2OFF; //打开XT2振荡器
do
IFG1 &= ~OFIFG; // 清除振荡器失效标志
for (iq0 = 0xFF; iq0 > 0; iq0--); // 延时,等待XT2起振
while ((IFG1 & OFIFG) != 0); // 判断XT2是否起振
BCSCTL2 =SELM_2+SELS; //选择MCLK、SMCLK为XT2
2.2 细节描述
对于DCO可以通过配置电阻和DCO得到不同的频率。电阻可配置片内或片外(DCOR一般片内),片内电阻有8中选择(RSELX),DCO有8中选择(DCOX)。
3、相关寄存器
1、DCOCTL
DCOx Bits
7-5
DCO frequency select. These bits select which of the eight discrete DCO
frequencies of the RSELx setting is selected.
2、BCSCTL0
XT2OFF Bit 7 XT2 off. This bit turns off the XT2 oscillator
0 XT2 is on
1 XT2 is off if it is not used for MCLK or SMCLK.
RSELx Bits
2-0
Resistor Select. The internal resistor is selected in eight different steps.
The value of the resistor defines the nominal frequency. The lowest
nominal frequency is selected by setting RSELx=0.
3、BCSCTL0
SELMx Bits
7-6
Select MCLK. These bits select the MCLK source.
00 DCOCLK
01 DCOCLK
10 XT2CLK when XT2 oscillator present on-chip. LFXT1CLK when XT2
oscillator not present on-chip.
11 LFXT1CLK
SELS Bit 3 Select SMCLK. This bit selects the SMCLK source.
0 DCOCLK
1 XT2CLK when XT2 oscillator present on-chip. LFXT1CLK when XT2
DCOR Bit 0 DCO resistor select
0 Internal resistor
1 External resistor
4、实例
4.1 配置MCLK/SMCLK
见本节2.1。
4.2配置DCO
void main(void)
WDTCTL = WDTPW +WDTHOLD; // Stop Watchdog Timer
DCOCTL = DCO0 + DCO1 + DCO2; // Max DCO
BCSCTL1 = RSEL0 + RSEL1 + RSEL2; // XT2on, max RSEL
BCSCTL2 |= SELS; // SMCLK = XT2
P5DIR |= 0x70; // P5.6,5,4 outputs
P5SEL |= 0x70; // P5.6,5,5 options
while(1)
实测DCO最低128K,最高4.58M。
上一篇:MSP430F149的存储器结构及FLASH读写
下一篇:MSP430F149的ADC12模块
推荐阅读最新更新时间:2024-03-16 14:32
设计资源 培训 开发板 精华推荐
- 开启Altera SoC体验之旅,玩转Altera Cyclone V系列SoC
- 年终大冲关!第二期光荣榜活动震撼登场!
- 下载有礼|是德科技:测试设备如何影响产品质量调研报告
- 泰克示波器,朝第二个百万台销售纪录前进!
- TI 技术大咖带你领略独一无二的MCU世界 推荐、抢楼全有礼!
- 泰克完整LED驱动测试方案 领跑节能亮化新时代
- 下载有礼|终于找到秘籍,示波器探头的选择和使用就靠它了!
- “玄铁杯”第三届RISC-V应用创新大赛—国产高性能RISC-V Linux开发板LicheePi 4A报名专场,万元奖金,邀您奔赴开源设计盛宴
- Digi-key干货视频教程来袭,意见领袖讲解疑难设计问题,带你突破成长瓶颈~
