STM32ADC单次转换实例
发布者:码字奇才最新更新时间:2018-10-06 来源: eefocus关键字:STM32  ADC  单次转换 手机看文章 扫描二维码
随时随地手机看文章
    ADC的初始化步骤:
1.初始化ADC所用的通道IO
2.开启ADC的时钟并初始化ADC的结构体
3.调用ADC_Cmd函数进行使能ADC,目的是可以进行读写ADC的寄存器
4.校准ADC(这一步不是必须的,校准ADC时ADC硬件会生成一个校准码,来减小测量误差,校准过的ADC比不校准的准确)
5.调用ADC_RegularChannelConfig写入规则通道的信息(包括写入SQR寄存器的值,采样时间等)
6.调用ADC_SoftwareStartConvCmd函数开启ADC采样
7.等待采样完成,并读取ADC数据
ADC部分代码如下:
#include "adc.h"
static void ADC_GPIO_Config(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //ʹÄÜPB,PE¶Ë¿ÚʱÖÓ
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN;
GPIO_Init(GPIOA, &GPIO_InitStructure);
void ADC_Mode_Config(void)
  ADC_InitTypeDef ADC_InitStructure;
ADC_GPIO_Config();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
ADC_DeInit(ADC1);
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
ADC_InitStructure.ADC_ScanConvMode=DISABLE;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel=ADC_Channel_1;
ADC_Init(ADC1,&ADC_InitStructure);
  ADC_Cmd(ADC1,ENABLE);
ADC_ResetCalibration(ADC1);
while(ADC_GetResetCalibrationStatus(ADC1)==SET);
ADC_StartCalibration(ADC1);
while(ADC_GetCalibrationStatus(ADC1)==SET);
u16 ADC_STARTConver(void)
u16 adcconverdata;
ADC_RegularChannelConfig(ADC1,ADC_Channel_1,1,ADC_SampleTime_239Cycles5);
ADC_SoftwareStartConvCmd(ADC1,ENABLE);
while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));
adcconverdata=ADC_GetConversionValue(ADC1);
return adcconverdata;
main函数中执行如下循环
    AdcConverValue=ADC_STARTConver();
printf("AdcConverValue=%d \r\n",AdcConverValue);
接下来就是执行结果了:
STM32ADC单次转换实例
上面是我引脚悬空时候的结果,下图是测量0V时的图片:
STM32ADC单次转换实例
值得注意的是ADC_Cmd这个命令,当把上面程序的ADC_SoftwareStartConvCmd(ADC1,ENABLE);命令更换为ADC_Cmd(ADC1,ENABLE);命令时程序仍然正常运行,原因如下:
void ADC_Cmd(ADC_TypeDef* ADCx, FunctionalState NewState)
  assert_param(IS_ADC_ALL_PERIPH(ADCx));
  assert_param(IS_FUNCTIONAL_STATE(NewState));
  if (NewState != DISABLE)
    ADCx->CR2 |= CR2_ADON_Set;
  else
    ADCx->CR2 &= CR2_ADON_Reset;
从上面的函数原型可以看出ADC_CMD函数设置的是CR2寄存器的ADON位
打开参考手册,找到这个位,解释如下:
STM32ADC单次转换实例
从上图中我们可以看到,当该位为1时,再写入1的话则是启动ADC转换,而不是无效命令,我们程序在ADC初始化的时候已经调用过一次ADC_CMD函数,所以该位为1,所以当我们将ADC_SoftwareStartConvCmd(ADC1,ENABLE);函数更换为ADC_Cmd(ADC1,ENABLE)时,程序一点影响都没有,照常运行。
关键字:STM32  ADC  单次转换 引用地址:STM32ADC单次转换实例
上一篇:STM32ADC转换中断读取
下一篇:Stm32f103rct6ADC电压采集简介及注意点
推荐阅读最新更新时间:2024-03-16 16:15
STM32不止于芯”: 2023年STM32中国峰会暨粉丝狂欢节重磅回归深圳
2023年5月12日,中国深圳 – 服务多重电子应用领域、全球排名前列的半导体公司意法半导体(STMicroelectronics,简称ST;)将于5月12-13日在深圳蛇口希尔顿酒店举行2023年STM32中国峰会暨粉丝狂欢节。 STM32中国峰会是展示STM32产品技术和解决方案的行业盛会,2023年,我们迎来了第六届STM32中国峰会。本届峰会以“STM32不止于芯”为主题,将专注于边缘AI、网络连接、信息安全、生态系统与开发者优先计划,重点展示STM32创新产品技术如何赋能各种应用。 本届峰会将举办50多场专题会议,其中包括高管主题演讲、技术研讨会,以及ST和生态系统合作伙伴的demo演示。此外,新品展区将是本届
[单片机]
基于STM32的心电采集设计
如今,心血管类疾病已经成为威胁人类身体健康的重要疾病之一,而清晰有效的心电图为诊断这类疾病提供了依据,心电采集电路是心电采集仪的 关键部分,心电信号属于微弱信号,其频率范围在0.03~100 Hz之间,幅度在0~5 mV之间,同时心电信号还掺杂有大量的干扰信号,因此,设计良好的滤波电路和选择合适的控制器是得到有效心电信号的关键。基于此,本文设计了以STM32 为控制核心,AD620和OP07为模拟前端的心电采集仪,本设计简单实用,噪声干扰得到了有效抑制。 1 总体设计方案 心电采集包括模拟采集和数字处理两部分,本设计通过AgCl电极和三导联线心电采集线采集人体心电信号,通过前置放大电路,带通滤波电路,50 Hz双T陷波后再经主放大
[单片机]
基于<font color='red'>STM32</font>的心电采集设计
STM32基本系统主要几个部分
STM32基本系统主要有下面几个部分: 电源 无论是否使用模拟部分和AD部分,MCU外围出去VCC和GND,VDDA、VSSA、Vref(如果封装有该引脚)都必需要连接,不可悬空。 对于每组对应的VDD和GND都应至少放置一个104的陶瓷电容用于滤波,并接该电容应放置尽量靠近MCU。 用万用表测试供电电压是否正确,调试时最好用数字电源供电,以便过压或过流烧坏板子,电压最好一步一步从进线端测试到芯片供电端。 复位、启动选择 Boot引脚与JTAG无关。其仅是用于MCU启动后,判断执行代码的起始地址 在电路设计上可能Boot引脚不会使用,但要求一定要外部连接电阻到地或电源,切不可悬空;STM32三种启动模式对应的存储介质均
[单片机]
<font color='red'>STM32</font>基本系统主要几个部分
STM32的基本知识
首先,在学习Cortex-M3时,我们必须要知道必要的缩略语。 整理如下: AMBA:先进单片机总线架构 ADK:AMBA设计套件 AHB:先进高性能总线 AHB-AP:AHB访问端口 APB:先进外设总线 ARM ARM:ARM架构参考手册 ASIC:行业领域专用集成电路 ATB :先进跟踪总线 BE8:字节不变式大端模式 CPI:每条指令的周期数 DAP:调试访问端口 DSP:数字信号处理(器) DWT:数据观察点及跟踪 ETM:嵌入式跟踪宏单元 FPB:闪存地址重载及断点 FSR:fault状态寄存器 HTM:Core Sight AHB跟踪宏单元 ICE:在线仿真器 IDE:集成开发环境 IRQ:中断请求(通常是外中断
[单片机]
<font color='red'>STM32</font>的基本知识
STM32 固件库
CMSIS 标准中最主要的为 CMSIS 核心层,它包括了: 内核函数层:其中包含用于访问内核寄存器的名称、地址定义; 设备外设访问层:提供了片上的核外外设的地址和中断定义。 库目录,文件简介 在STM32F4xx_DSP_StdPeriph_Lib_V1.8.0 文件中: Libraries:文件夹下是驱动库的源代码及启动文件。 Project :文件夹下是用驱动库写的例子和工程模板。 Utilities:包含了基于 ST 官方实验板的例程,以及第三方软件库,如 emwin 图形软件 库、fatfs 文件系统。 MCD-ST Liberty…:库文件的 License 说明。 Release_Note.html::
[单片机]
<font color='red'>STM32</font> 固件库
stm32 ssD1306 OLED驱动架构
#include oled.h #include stdlib.h #include oledfont.h #include delay.h //OLED的显存 //存放格式如下. // 0 1 2 3 ... 127 // 0 1 2 3 ... 127 // 0 1 2 3 ... 127 // 0 1 2 3 ... 127 // 0 1 2 3 ... 127 // 0 1 2 3 ... 127 // 0 1 2 3 ... 127 // 0 1 2 3 ... 127 u8 OLED_GRAM ; //更新显存到LCD void OLED_Re
[单片机]
STM32的窗口看门狗(WWDG)
一、窗口看门狗由从APB1时钟分频后得到时钟驱动。 通过可配置的时间窗口来检测应用程序非正常的过迟或过早操作。 窗口看门狗最适合那些要求看门狗在精确计时窗口起作用的程序。 二、什么是窗口看门狗? 窗口就是因为其喂狗时间是一个有上下限的范围内(窗口),你可以通过设定相关寄存器,设定其上限时间(下限固定)。喂狗的时间不能过早也不能过晚。 而独立看门狗限制喂狗时间在0-x内,x由相关寄存器决定。喂狗的时间不能过晚 三、窗口看门狗的好处 对于一般的看门狗,因为是在复位前的任意时刻刷新看门狗,但有可能程序跑乱了又跑回到正常的地方,或跑乱的程序正好执行了刷新看门狗操作,这样的情况下就检测不
[单片机]
<font color='red'>STM32</font>的窗口看门狗(WWDG)
STM32学习笔记之电容触摸2
(4)在led.c文件中添加以下代码 (5)在tpad.c文件内添加以下代码 #include tpad.h #include delay.h /*************************************************** Name :TPAD_Get_Value Function :触摸按键值获取 Paramater :None Return :获取的充电时间 ***************************************************/ u16 TPAD_Get_Value() { //电容放电 GPIOA- CRL &= 0xFFF
[单片机]
<font color='red'>STM32</font>学习笔记之电容触摸2
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
