Tiny210按键分层分离(总线-驱动-设备模型)
发布者:二进制游侠最新更新时间:2018-10-12 来源: eefocus关键字:Tiny210  按键分层分离 手机看文章 扫描二维码
随时随地手机看文章
led_dev.c驱动源码:
#include "linux/module.h"
#include "linux/version.h"
#include "linux/init.h"
#include "linux/kernel.h"
#include "linux/types.h"
#include "linux/interrupt.h"
#include "linux/list.h"
#include "linux/timer.h"
#include "linux/serial_core.h"
#include "linux/platform_device.h"
// 分配/设置/注册一个platform_device
static struct resource led_resource[] = {
    [0] = {
        .start = 0xE0200280,
        .end   = 0xE0200280 + 8 - 1,
        .flags = IORESOURCE_MEM,
    [1] = {
        .start = 0,
        .end   = 0,
        .flags = IORESOURCE_IRQ,
static void led_release(struct device * dev)
static struct platform_device led_dev = {
    .name                  = "myled",
    .id                        = -1,
    .num_resources  = ARRAY_SIZE(led_resource),
    .resource             = led_resource,
    .dev = {
        .release            = led_release,
static int led_dev_init(void)
    platform_device_register(&led_dev);
    return 0;
static void led_dev_exit(void)
    platform_device_unregister(&led_dev);
module_init(led_dev_init);
module_exit(led_dev_exit);
MODULE_LICENSE("GPL");
led_drv.c驱动源码:
// 分配/设置/注册一个platform_driver
#include "linux/fs.h"
#include "linux/irq.h"
#include "linux/sched.h"
#include "linux/pm.h"
#include "linux/sysctl.h"
#include "linux/proc_fs.h"
#include "linux/delay.h"
#include "linux/input.h"
#include "asm/uaccess.h"
#include "asm/io.h"
static int major;
static struct class *cls;
static volatile unsigned long *gpio_con;
static volatile unsigned long *gpio_dat;
static int pin;
static int led_open(struct inode *inode, struct file *file)
    //printk("first_drv_open\n");
    // 配置为输出
    *gpio_con &= ~(0xf<<(pin*4));
    *gpio_con |= (0x1<<(pin*4));
    return 0;
static ssize_t led_write(struct file *file, const char __user *buf, size_t count, loff_t * ppos)
    int val;
    //printk("first_drv_write\n");
    copy_from_user(&val, buf, count); //    copy_to_user();
    if (val == 1)
        // 点灯
        *gpio_dat &= ~(1<
    else
        // 灭灯
        *gpio_dat |= (1<
    return 0;
static struct file_operations led_fops = {
    .owner  =   THIS_MODULE,    // 这是一个宏,推向编译模块时自动创建的__this_module变量
    .open   =   led_open,
    .write  =   led_write,
static int led_probe(struct platform_device *pdev)
    struct resource        *res;
    // 根据platform_device的资源进行ioremap
    res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
    gpio_con = ioremap(res->start, res->end - res->start + 1);
    gpio_dat = gpio_con + 1;
    res = platform_get_resource(pdev, IORESOURCE_IRQ, 0);
    pin = res->start;
    // 注册字符设备驱动程序
    printk("led_probe, found led\n");
    major = register_chrdev(0, "myled", &led_fops);
    cls = class_create(THIS_MODULE, "myled");
    device_create(cls, NULL, MKDEV(major, 0), NULL, "led"); // /dev/led
    return 0;
static int led_remove(struct platform_device *pdev)
    // 卸载字符设备驱动程序
    // iounmap
    printk("led_remove, remove led\n");
    device_destroy(cls, MKDEV(major, 0));
    class_destroy(cls);
    unregister_chrdev(major, "myled");
    iounmap(gpio_con);
    return 0;
struct platform_driver led_drv = {
    .probe    = led_probe,
    .remove  = led_remove,
    .driver     = {
        .name = "myled",
static int led_drv_init(void)
    platform_driver_register(&led_drv);
    return 0;
static void led_drv_exit(void)
    platform_driver_unregister(&led_drv);
module_init(led_drv_init);
module_exit(led_drv_exit);
led_test.c测试程序:
#include "sys/types.h"
#include "sys/stat.h"
#include "fcntl.h"
#include "stdio.h"
// led_test on
// led_test off
int main(int argc, char **argv)
    int fd;
    int val = 1;
    fd = open("/dev/led", O_RDWR);
    if (fd < 0)
        printf("can't open!\n");
    if (argc != 2)
        printf("Usage :\n");
        printf("%s 《on|off》\n", argv[0]); //实际为"<"
        return 0;
    if (strcmp(argv[1], "on") == 0)
        val  = 1;
    else
        val = 0;
    write(fd, &val, 4);
    return 0;
关键字:Tiny210  按键分层分离 引用地址:Tiny210按键分层分离(总线-驱动-设备模型)
上一篇:Tiny210驱动之LCD驱动程序
下一篇:Tiny210按键输入子系统
推荐阅读最新更新时间:2024-03-16 16:16
Tiny210触摸屏之一线触摸屏驱动
1wire_ts.c源码: #include linux/errno.h #include linux/kernel.h #include linux/module.h #include linux/slab.h #include linux/input.h #include linux/init.h #include linux/serio.h #include linux/delay.h #include linux/clk.h #include linux/miscdevice.h #include linux/platform_device.h #include linux/timer.h #inc
[单片机]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
