Tiny210驱动之按键异步通知
发布者:DazzlingSpirit最新更新时间:2018-10-12 来源: eefocus关键字:Tiny210驱动  按键异步 手机看文章 扫描二维码
随时随地手机看文章
fifth_drv.c驱动源码:
#include "linux/device.h"
#include "linux/interrupt.h"
#include "linux/module.h"
#include "linux/kernel.h"
#include "linux/fs.h"
#include "linux/init.h"
#include "linux/delay.h"
#include "linux/irq.h"
#include "asm/uaccess.h"
#include "asm/irq.h"
#include "asm/io.h"
#include "mach/gpio.h"
#include "linux/poll.h"
static struct class *fifthdrv_class;
volatile unsigned long *gph2con;
volatile unsigned long *gph2dat;
volatile unsigned long *gph3con;
volatile unsigned long *gph3dat;
static DECLARE_WAIT_QUEUE_HEAD(button_waitq);
// 中断事件标志, 中断服务程序将它置1,fifth_drv_read将它清0
static volatile int ev_press = 0;
static struct fasync_struct *button_async;
struct pin_desc{
    unsigned int pin;
    unsigned int key_val;
// 键值: 按下时, 0x01, 0x02, 0x03, 0x04, 0x05
// 键值: 松开时, 0x81, 0x82, 0x83, 0x84, 0x85
static unsigned char key_val;
struct pin_desc pins_desc[5] = {
    {S5PV210_GPH2(3), 0x01},
    {S5PV210_GPH3(0), 0x02},
    {S5PV210_GPH3(1), 0x03},
    {S5PV210_GPH3(2), 0x04},
    {S5PV210_GPH3(3), 0x05},
// 确定按键值
static irqreturn_t buttons_irq(int irq, void *dev_id)
    struct pin_desc * pindesc = (struct pin_desc *)dev_id;
    unsigned int pinval;
    pinval = gpio_get_value(pindesc->pin);
    if (pinval)
        // 松开
        key_val = 0x80 | pindesc->key_val;
    else
        // 按下
        key_val = pindesc->key_val;
    ev_press = 1;                                                // 表示中断发生了
    wake_up_interruptible(&button_waitq);   // 唤醒休眠的进程
    kill_fasync (&button_async, SIGIO, POLL_IN);
    return IRQ_RETVAL(IRQ_HANDLED);
static int fifth_drv_open(struct inode *inode, struct file *file)
    // 注册中断
    request_irq(IRQ_EINT(19),  buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                        "K4", &pins_desc[0]);
    request_irq(IRQ_EINT(24),  buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                        "K5", &pins_desc[1]);
    request_irq(IRQ_EINT(25), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                        "K6", &pins_desc[2]);
    request_irq(IRQ_EINT(26), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                        "K7", &pins_desc[3]);
    request_irq(IRQ_EINT(27), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                        "K8", &pins_desc[4]);
    return 0;
ssize_t fifth_drv_read(struct file *file, char __user *buf, size_t size, loff_t *ppos)
    if (size != 1)
        return -EINVAL;
    // 如果没有按键动作, 休眠
    wait_event_interruptible(button_waitq, ev_press);
    // 如果有按键动作, 返回键值
    copy_to_user(buf, &key_val, 1);
    ev_press = 0;
    return 1;
int fifth_drv_close(struct inode *inode, struct file *file)
    free_irq(IRQ_EINT(19), &pins_desc[0]);
    free_irq(IRQ_EINT(24), &pins_desc[1]);
    free_irq(IRQ_EINT(25), &pins_desc[2]);
    free_irq(IRQ_EINT(26), &pins_desc[3]);
    free_irq(IRQ_EINT(27), &pins_desc[4]);
    return 0;
static unsigned fifth_drv_poll(struct file *file, poll_table *wait)
    unsigned int mask = 0;
    poll_wait(file, &button_waitq, wait); // 不会立即休眠
    if (ev_press)
        mask |= POLLIN | POLLRDNORM;
    return mask;
static int fifth_drv_fasync (int fd, struct file *filp, int on)
    printk("driver: fifth_drv_fasync\n");
    return fasync_helper (fd, filp, on, &button_async);
static struct file_operations sencod_drv_fops = {
    .owner   =  THIS_MODULE,    // 这是一个宏,推向编译模块时自动创建的__this_module变量
    .open    =  fifth_drv_open,
    .read    =  fifth_drv_read,
    .release =  fifth_drv_close,
    .poll    =  fifth_drv_poll,
    .fasync  =  fifth_drv_fasync,
int major;
static int fifth_drv_init(void)
    major = register_chrdev(0, "fifth_drv", &sencod_drv_fops);
    fifthdrv_class = class_create(THIS_MODULE, "fifth_drv");
    device_create(fifthdrv_class, NULL, MKDEV(major, 0), NULL, "buttons"); // /dev/buttons
    gph2con = (volatile unsigned long *)ioremap(0xe0200c40, 16);
    gph2dat = gph2con + 1;
    gph3con = (volatile unsigned long *)ioremap(0xE0200C60, 16);
    gph3dat = gph3con + 1;
    return 0;
static void fifth_drv_exit(void)
    unregister_chrdev(major, "fifth_drv");
    device_destroy(fifthdrv_class, MKDEV(major, 0));
    class_destroy(fifthdrv_class);
    iounmap(gph2con);
    iounmap(gph3con);
    return 0;
module_init(fifth_drv_init);
module_exit(fifth_drv_exit);
MODULE_LICENSE("GPL");
fifthdrvtest.c测试程序:
#include "sys/types.h"
#include "sys/stat.h"
#include "fcntl.h"
#include "stdio.h"
#include "poll.h"
#include "signal.h"
#include "unistd.h"
#include "fcntl.h"
// fifthdrvtest
int fd;
void my_signal_fun(int signum)
    read(fd, &key_val, 1);
    printf("key_val: 0x%x\n", key_val);
int main(int argc, char **argv)
    int ret;
    int Oflags;
    signal(SIGIO, my_signal_fun);
    fd = open("/dev/buttons", O_RDWR);
    if (fd < 0)
        printf("can't open!\n");
    fcntl(fd, F_SETOWN, getpid());
    Oflags = fcntl(fd, F_GETFL);
    fcntl(fd, F_SETFL, Oflags | FASYNC);
    while (1)
        sleep(1000);
    return 0;
关键字:Tiny210驱动  按键异步 引用地址:Tiny210驱动之按键异步通知
上一篇:Tiny210按键互斥锁、原子变量驱动
下一篇:Tiny210驱动之按键poll机制
推荐阅读最新更新时间:2024-03-16 16:16
Tiny210驱动之KEY测试
second_drv.c驱动源码: #include linux/device.h #include linux/module.h #include linux/kernel.h #include linux/fs.h #include linux/init.h #include linux/delay.h #include asm/uaccess.h #include asm/irq.h #include asm/io.h static struct class *seconddrv_class; volatile unsigned long *gph2con; volatile unsigned long *
[单片机]
Tiny210按键分层分离(总线-驱动-设备模型)
led_dev.c驱动源码: #include linux/module.h #include linux/version.h #include linux/init.h #include linux/kernel.h #include linux/types.h #include linux/interrupt.h #include linux/list.h #include linux/timer.h #include linux/init.h #include linux/serial_core.h #include linux/platform_device.h // 分配/设置/注册一个platfo
[单片机]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
