1.systick时钟来源
2.SysTick库函数
3.源码
/** @defgroup SysTick_clock_source
#define SysTick_CLKSource_HCLK_Div8 ((uint32_t)0xFFFFFFFB)
#define SysTick_CLKSource_HCLK ((uint32_t)0x00000004)
#define IS_SYSTICK_CLK_SOURCE(SOURCE) (((SOURCE) == SysTick_CLKSource_HCLK) || \
((SOURCE) == SysTick_CLKSource_HCLK_Div8))
*@brief Configures the SysTick clocksource.
*@param SysTick_CLKSource: specifies theSysTick clock source.
* This parameter can be one ofthe following values:
* @argSysTick_CLKSource_HCLK_Div8: AHB clock divided by 8 selected as SysTick clocksource.
* @arg SysTick_CLKSource_HCLK:AHB clock selected as SysTick clock source.
*@retval None
void SysTick_CLKSourceConfig(uint32_t SysTick_CLKSource)
/* Check the parameters */
assert_param(IS_SYSTICK_CLK_SOURCE(SysTick_CLKSource));
if (SysTick_CLKSource == SysTick_CLKSource_HCLK)
SysTick->CTRL |= SysTick_CLKSource_HCLK;
else
SysTick->CTRL &= SysTick_CLKSource_HCLK_Div8;
/*################################## SysTick function ############################################ */
#if (!defined (__Vendor_SysTickConfig)) || (__Vendor_SysTickConfig == 0)
*@brief Initialize and start the SysTickcounter and its interrupt.
*@param ticks number of ticks between two interrupts
*@return 1 = failed, 0 = successful
*Initialise the system tick timer and its interrupt and start the
*system tick timer / counter in free running mode to generate
*periodical interrupts.
static __INLINE uint32_t SysTick_Config(uint32_t ticks)
if (ticks > SysTick_LOAD_RELOAD_Msk) return (1); /* Reload value impossible */
SysTick->LOAD = (ticks & SysTick_LOAD_RELOAD_Msk) - 1; /* set reload register */
NVIC_SetPriority (SysTick_IRQn, (1<<__NVIC_PRIO_BITS) - 1); /* set Priority forCortex-M0 System Interrupts */
SysTick->VAL = 0; /* Load the SysTick Counter Value */
SysTick->CTRL = SysTick_CTRL_CLKSOURCE_Msk |
SysTick_CTRL_TICKINT_Msk |
SysTick_CTRL_ENABLE_Msk; /* Enable SysTick IRQ and SysTick Timer*/
return (0); /* Function successful */
#endif
#ifdefSYSCLK_FREQ_HSE
uint32_t SystemCoreClock = SYSCLK_FREQ_HSE; /*! #elif defined SYSCLK_FREQ_24MHz uint32_t SystemCoreClock = SYSCLK_FREQ_24MHz; /*!< System Clock Frequency (Core Clock) */ #elif defined SYSCLK_FREQ_36MHz uint32_t SystemCoreClock = SYSCLK_FREQ_36MHz; /*! #elif defined SYSCLK_FREQ_48MHz uint32_t SystemCoreClock = SYSCLK_FREQ_48MHz; /*! #elif defined SYSCLK_FREQ_56MHz uint32_t SystemCoreClock = SYSCLK_FREQ_56MHz; /*! #elif defined SYSCLK_FREQ_72MHz uint32_t SystemCoreClock = SYSCLK_FREQ_72MHz; /*! #else /*!< HSI Selected as System Clock source */ uint32_t SystemCoreClock = HSI_VALUE; /*!< System Clock Frequency (Core Clock) */ #endif /////////////////////////////// /* Configure the SysTick */ SysTick_Config(SystemCoreClock / RT_TICK_PER_SECOND);//8000000/1000=>1ms /** *This is the timer interrupt service routine. * */ void SysTick_Handler(void) { /* enter interrupt */ rt_interrupt_enter(); rt_tick_increase(); /* leave interrupt */ rt_interrupt_leave(); }
上一篇:stm32F407的Systick的问题
下一篇:STM32—SysTick使用方法
推荐阅读最新更新时间:2024-03-16 16:21
