点击(此处)折叠或打开
* Function Name : SysTickHandler
* Description : This function handles SysTick Handler.
* Input : None
* Output : None
* Return : None
void SysTickHandler(void)
__SVC();
/* Toggle PC.04 pin */ LED4
GPIO_WriteBit(GPIOC, GPIO_Pin_4, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_4)));
* Function Name : SVCHandler
* Description : This function handles SVCall exception.
* Input : None
* Output : None
* Return : None
void SVCHandler(void)
/* Set the PSV system handler pending bit */
NVIC_SetSystemHandlerPendingBit(SystemHandler_PSV);
/* Toggle PC.05 pin */ LED3
GPIO_WriteBit(GPIOC, GPIO_Pin_5, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_5)));
* Function Name : PendSVC
* Description : This function handles PendSVC exception.
* Input : None
* Output : None
* Return : None
void PendSVC(void)
/* Set the NMI system handler pending bit */
NVIC_SetSystemHandlerPendingBit(SystemHandler_NMI);
/* Toggle PC.06 pin */ LED2
GPIO_WriteBit(GPIOC, GPIO_Pin_6, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_6)));
* Function Name : NMIException
* Description : This function handles NMI exception.
* Input : None
* Output : None
* Return : None
void NMIException(void)
/* Toggle PC.07 pin */ LED1
GPIO_WriteBit(GPIOC, GPIO_Pin_7, (BitAction)(1 - GPIO_ReadOutputDataBit(GPIOC, GPIO_Pin_7)));
本例展示了如何运用NVIC和系统Handler(system handler):
各个system handlers拥有如下的强制优先级(preemption priority):
- NMI preemption priority -2 固定优先级
- PSV preemption priority 0 可设置
- SVCall preemption priority 1 可设置
- SysTick preemption priority 2 可设置
首先把Systick定时器设定为每当其计数器为零,这里是1s产生一个Systick中断。
点击(此处)折叠或打开
/* SysTick interrupt each 1 Hz with Counter clock equal to 72MHz/8 = 9MHz */
SysTick_SetReload(9000000);
/* Enable the SysTick Interrupt */
SysTick_ITConfig(ENABLE);
/* Enable the SysTick Counter */
SysTick_CounterCmd(SysTick_Counter_Enable);
在Systick handler routine中,设置与PC.04相连的LED4以1秒为周期闪耀。随后执行_SVC(System Service Call)指令。这个指令在cortexm3_macro.h中
执行_SVC()会激活SVCall handler来打断当前的指令流。在SVCall handler routine中,设置与PC.05相连的LED3闪耀,同时设置PSV handler的pending比特。由于PSV(Pendable request for system service)的优先级更高,因此他又会打断SVCall handler。在PSV handler routine中,设置与PC.06相连的LED2闪耀,并设置NMI(Non maskable interrupt)pending比特,进一步由NMI handler打断当前handler。
最后,在NMI handler中设置与PC.07相连的LED1闪耀。
上一篇:stm32启动文件中heap与stack
下一篇:STM32 SVCall
推荐阅读最新更新时间:2024-03-16 16:21
