STM32F4 SPI通信自发自收使用经验
发布者:温柔心情最新更新时间:2019-01-14 来源: eefocus关键字:STM32F4  SPI通信  自发自收 手机看文章 扫描二维码
随时随地手机看文章
       SPI的配置函数如下
void SPI_Config(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
SPI_InitTypeDef  SPI_InitStructure;
  /* Peripheral Clock Enable -------------------------------------------------*/
  /* Enable the SPI clock */
  SPIx_CLK_INIT(SPIx_CLK, ENABLE);
  /* Enable GPIO clocks */
  RCC_AHB1PeriphClockCmd(SPIx_SCK_GPIO_CLK | SPIx_MISO_GPIO_CLK | SPIx_MOSI_GPIO_CLK, ENABLE);
  /* SPI GPIO Configuration --------------------------------------------------*/
  /* Connect SPI pins to AF5 */
  GPIO_PinAFConfig(SPIx_SCK_GPIO_PORT, SPIx_SCK_SOURCE, SPIx_SCK_AF);
  GPIO_PinAFConfig(SPIx_MOSI_GPIO_PORT, SPIx_MOSI_SOURCE, SPIx_MOSI_AF);
  GPIO_PinAFConfig(SPIx_MISO_GPIO_PORT, SPIx_MISO_SOURCE, SPIx_MISO_AF);
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
  /* SPI SCK pin configuration */
  GPIO_InitStructure.GPIO_Pin = SPIx_SCK_PIN;
  GPIO_Init(SPIx_SCK_GPIO_PORT, &GPIO_InitStructure);
  /* SPI  MOSI pin configuration */
  GPIO_InitStructure.GPIO_Pin =  SPIx_MOSI_PIN;
  GPIO_Init(SPIx_MOSI_GPIO_PORT, &GPIO_InitStructure);
  /* SPI  MISO pin configuration  */
  GPIO_InitStructure.GPIO_Pin =  SPIx_MISO_PIN;
  GPIO_Init(SPIx_MISO_GPIO_PORT,&GPIO_InitStructure);
  /* SPI configuration -------------------------------------------------------*/
  SPI_I2S_DeInit(SPIx);
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPIx,&SPI_InitStructure);
  SPI_Cmd(SPIx, ENABLE);
  /* Configure the Priority Group to 1 bit */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  /* Configure the SPI interrupt priority */
  NVIC_InitStructure.NVIC_IRQChannel = SPIx_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
SPI.H 的头文件的宏定义
/* SPIx Communication boards Interface */
#define SPIx                           SPI2
#define SPIx_CLK                       RCC_APB1Periph_SPI2
#define SPIx_CLK_INIT                  RCC_APB1PeriphClockCmd
#define SPIx_IRQn                      SPI2_IRQn
#define SPIx_IRQHANDLER                SPI2_IRQHandler
#define SPIx_SCK_PIN                   GPIO_Pin_1
#define SPIx_SCK_GPIO_PORT             GPIOI
#define SPIx_SCK_GPIO_CLK              RCC_AHB1Periph_GPIOI
#define SPIx_SCK_SOURCE                GPIO_PinSource1
#define SPIx_SCK_AF                    GPIO_AF_SPI2
#define SPIx_MISO_PIN                  GPIO_Pin_2
#define SPIx_MISO_GPIO_PORT            GPIOI
#define SPIx_MISO_GPIO_CLK             RCC_AHB1Periph_GPIOI
#define SPIx_MISO_SOURCE               GPIO_PinSource2
#define SPIx_MISO_AF                   GPIO_AF_SPI2
#define SPIx_MOSI_PIN                  GPIO_Pin_3
#define SPIx_MOSI_GPIO_PORT            GPIOI
#define SPIx_MOSI_GPIO_CLK             RCC_AHB1Periph_GPIOI
#define SPIx_MOSI_SOURCE               GPIO_PinSource3
#define SPIx_MOSI_AF                   GPIO_AF_SPI2
#define TXBUFFERSIZE   (countof(TxBuffer) - 1)
#define RXBUFFERSIZE   TXBUFFERSIZE
注意两个地方:
SPI2的引脚如果被其他引脚复用,应关闭其相关设备。
MISO和MOSI两个引脚要关闭。
不建议打开SPI的接收中断。
关键字:STM32F4  SPI通信  自发自收 引用地址:STM32F4 SPI通信自发自收使用经验
上一篇:STM32使用不同的晶振需修改的代码
下一篇:Stm32库函数里的断言机制解析
推荐阅读最新更新时间:2024-03-16 16:22
STM32F4驱动NEC协议的红外接收头
红外遥控是一种无线、非接触式控制技术,具有抗干扰能力强、传输可靠、价格便宜、功耗低、易实现等优点。被很多的家用电器所采用。目前常用的红外遥控器协议有NEC协议(PWM脉冲宽度调制)、Philips RC5协议(PPM脉冲位置调制)。红外遥控分为发射端与接收端,发射端是以调制的方式发射数据,就是把数据和一定频率的载波进行“与操作”。调制载波频率一般为30KHz到60KHz之间。 NEC协议的特点:8位地址和8位命令长度 为提高可靠性每次传输有地址码、地址码反码,键码、键码反码等用来检验 通过脉冲之间的时间间隔来实现信号的调制
[单片机]
<font color='red'>STM32F4</font>驱动NEC协议的红外接收头
第29章 STM32F429的系统bootloader之USB DFU方式固件升级
29.1 初学者重要提示 学习本章节前,务必优先学习第28章。 本章用到的相关软件和文档下载:http://www.armbbs.cn/forum.php?mod=viewthread&tid=96573 。 软件STM32CubeProg和DfuSe都支持USB DFU,但是两个软件不能都安装使用,因为这两个软件的USB驱动不同,导致工作在系统bootloader模式的板子通过USB线接到电脑端时,只有一个软件的驱动被识别。 DfuSe是老版的USB DFU软件,不推荐大家使用了。建议使用STM32CubeProg,此软件实现了之前的DfuSe,STLINK小软件和Flashloader三合一,并且支持外部EEPRO
[单片机]
第29章 <font color='red'>STM32F4</font>29的系统bootloader之USB DFU方式固件升级
STM32F4的CCM内存之一
我们知道STM32F4当中有个CCM内存,如图所示,这个内存是挂在D总线上直接和内核相连,因此除了内核之外谁都不能访问,那么我们怎么将其利用起来呢? 首先,我们可以使用Keil的设置选项,将IRAM2打勾,让编译器选择什么时候使用这个内存。显然,我们还可以将这两个地址修改一下,将IRAM1改为0x10000000,这样,编译器就会优先分配CCM内存。 我们来看看结果,在MAP文件中,表明确实使用了这段内存,但是因为我们使用的内存较少, 还没有用到CCM。 这种自动分配的方式有什么问题呢?这段内存是内核专有的,除了内核任何其它总线都不能访问,这就意味着,一旦编译器将数据分配到CCM中,而同时使用了DMA
[单片机]
<font color='red'>STM32F4</font>的CCM内存之一
STM32F407上移植emwin
环境: 主机:WIN8 开发环境:MDK5.13 emwin版本:STemWinLibrary522 mcu: stm32f407VGT6 开发板:安富莱STM32-X3 TFT型号:艾蓝2.8寸TFT,主控芯片:ILI9325 说明: 在STM32F407上移植emwin,驱动屏幕接口为FSMC 移植步骤: 1.MDK新建文件结构: 2.GUIConf.c文件修改 a)增加宏定义: #define GUI_NUMBYTES (1024 * 80) #define GUI_BLOCKSIZE 0x80 b)GUI_X_Config(void)函数中增加语句
[单片机]
<font color='red'>STM32F4</font>07上移植emwin
SPI总线在XF-S4240与MCS51通信中的应用
  SPI 总线技术是Motorola公司推出的一种同步串行接口。它可以使MCU与各种外围设备以串行方式进行通信以交换信息,并且硬件连接较少,编程方便。 SPI接口已经是一种标准外设接口,目前已有很多MCU及外设都带有SPI接口。MCS51虽然也有带SPI接口的单片机——AT89S8252,但价格相对较高。在开发基于RFID的自助语音导游系统中,由于RFID读卡模块带有SCI接口,XF-S4240语音合成模块带有SCI及SPI接口,如采用不带有SPI接口的AT89C51单片机,必然存在扩展接口的问题。 本文介绍的C51软件模拟实现SPI通信接口的方法,编程简单,有效降低了系统的成本。该方法已在项目开发中得到了验证。
[单片机]
<font color='red'>SPI</font>总线在XF-S4240与MCS51<font color='red'>通信</font>中的应用
STM32F407 单通道ADC采样,DMA传输
最近在研究STM32F4的ADC采样功能,中间遇到了一些问题,写下来以备后用。 F4和F1有很多库函数是不一样的,在参照F1的教程的时候,不能直接抄他的实验代码,否则会出错。 因为要用DMA将ADC转换得到的值快速传递到SRAM中,所以就需要对ADC相关的DMA进行设置,这一步很重要。在写ADC1的DMA初始化函数前,一定要查Reference Manual的DMA request mapping,搞清楚是某一个具体的peripheral对应的是DMA1还是DMA2,用到的是哪一个stream和channel。例如这次实验要用到的外设ADC1,可以查到,ADC1归DMA2 Stream0或者Stream4的Channel0管理,不
[单片机]
<font color='red'>STM32F4</font>07 单通道ADC采样,DMA传输
STM32F4学习笔记5——stm32串口发送数据最高位错误问题
最近,在做基于stm32f401串口的ModBus协议通信,遇到了stm32串口发送数据的问题。花了一整天去查找问题,从ModBus协议格式、调度算法到串口配置,最终终于把问题解决,记录下来。 问题描述: ModBus协议中配置stm32f401串口为奇校验,8位数据位,1位停止位,程序如下: void uart_init( u32 bound ) { //GPIO端口设置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitSt
[单片机]
通过SPI接口协议实现DSP与其它设备的通信
1 引言 随着信息技术革命的深入和计算机技术的飞速发展,DSP技术也正以极快的速度被应用到科技和国民经济的各信领域。在很多工程开发设计中,由于要求实现单片DSP与单片DSP、多片DSP芯片以及及其它处理芯片之间的通信,因此,怎样更高效、更便捷的实现这些通信,已成为广大DSP应用者首先要解决的一个问题。   本文根据笔者在工程应用和调试方面用TI的DSP TMS320C5402与NEC的μPD780308单片机进行通信的经验,介绍并讨论了将TMS320C5402 DSP的多通道缓冲串行口McBSP(Multi-channel Buffered Serial Port)配置为SPI模式(即时钟停止模式),从而实现DSP
[嵌入式]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
