使用cube开发工具进行开发,使用HAL库,有一个问题就是当我们在cube界面配置完成后“以为完全配置好了”,结果在实际代码编写的时候回发现常见以下问题:
1:中断没配置
2:优先级没配置
这里简单分析以下手动开启中断的配置 取两个例子
example1:如何在无法改动cube工程的情况下 使能外部中断
step1
gpio.c 中
GPIO_InitStruct.Pin = MotoFG_Pin;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
GPIO_InitStruct.Pull = GPIO_PULLUP;
HAL_GPIO_Init(MotoFG_GPIO_Port, &GPIO_InitStruct);
HAL_NVIC_SetPriority(EXTI3_IRQn, 5, 0); //改为外部中断9
HAL_NVIC_EnableIRQ(EXTI3_IRQn); //手动修改外部中断设置
step2
it.c中
void EXTI3_IRQHandler(void)
HAL_GPIO_EXTI_IRQHandler(GPIO_PIN_3); //增加中断句柄
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin) //添加中断相应函数处理
switch(GPIO_Pin)
case GPIO_PIN_3:
PulseCome++;
break;
default:
break;
example2:如何在无法改动cube工程的情况下 利用timer2 ch4 开启PWM输出
这里有个坑,在103c8中timer2 ch4恰好是SWD口,PB3所以开启时需要开启复用时钟
/* TIM2 init function */
void MX_TIM2_Init(void)//117
TIM_ClockConfigTypeDef sClockSourceConfig;
TIM_MasterConfigTypeDef sMasterConfig;
TIM_OC_InitTypeDef sConfigOC;
htim2.Instance = TIM2;
htim2.Init.Prescaler = 71;
htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
htim2.Init.Period = 3600;
htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
if (HAL_TIM_PWM_Init(&htim2) != HAL_OK)
sMasterConfig.MasterOutputTrigger = TIM_TRGO_UPDATE;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
sConfigOC.OCMode = TIM_OCMODE_PWM1;
sConfigOC.Pulse = 1234;
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_ENABLE;
if (HAL_TIM_PWM_ConfigChannel(&htim2, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
HAL_TIM_MspPostInit(&htim2);
继续追进去
void HAL_TIM_MspPostInit(TIM_HandleTypeDef* timHandle)
GPIO_InitTypeDef GPIO_InitStruct;
if(timHandle->Instance==TIM2) //117
GPIO_InitStruct.Pin = timer2Pwm;
GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(timerpwm_GPIO_Port, &GPIO_InitStruct);
__HAL_AFIO_REMAP_TIM2_PARTIAL_2(); // 开AFIO时钟
最后,别忘了在it.c中加入句柄
void TIM2_IRQHandler(void) //117
/* USER CODE BEGIN TIM4_IRQn 0 */
/* USER CODE END TIM4_IRQn 0 */
HAL_TIM_IRQHandler(&htim2);
/* USER CODE BEGIN TIM4_IRQn 1 */
/* USER CODE END TIM4_IRQn 1 */
上一篇:STM32CubeMX串口接收中断
下一篇:STM32CubeMX:EXTI操作
推荐阅读最新更新时间:2024-03-16 16:26
