static int __devinit lcd_fb_probe(struct platform_device *pdev)
int i;
int ret;
struct resource *res;
struct fb_info *fbinfo;
struct s3c2410fb_mach_info *mach_info;
struct my2440fb_var *fbvar;
struct s3c2410fb_display *display;
mach_info = pdev->dev.platform_data;
if(mach_info == NULL)
dev_err(&pdev->dev, "no platform data for lcd\n");
return -EINVAL;
display = mach_info->displays + mach_info->default_display;
fbinfo = framebuffer_alloc(sizeof(struct my2440fb_var), &pdev->dev);
if(!fbinfo)
dev_err(&pdev->dev, "framebuffer alloc of registers failed\n");
ret = -ENOMEM;
goto err_noirq;
platform_set_drvdata(pdev, fbinfo);
fbvar = fbinfo->par;
fbvar->dev = &pdev->dev;
fbvar->lcd_irq_no = platform_get_irq(pdev, 0);
if(fbvar->lcd_irq_no < 0)
dev_err(&pdev->dev, "no lcd irq for platform\n");
return -ENOENT;
res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
if(res == NULL)
dev_err(&pdev->dev, "failed to get memory region resource\n");
return -ENOENT;
fbvar->lcd_mem = request_mem_region(res->start, res->end - res->start + 1,pdev->name);
if(fbvar->lcd_mem == NULL)
dev_err(&pdev->dev, "failed to reserve memory region\n");
return -ENOENT;
fbvar->lcd_base = ioremap(res->start, res->end - res->start + 1);
if(fbvar->lcd_base == NULL)
dev_err(&pdev->dev, "ioremap() of registers failed\n");
ret = -EINVAL;
goto err_nomem;
fbvar->lcd_clock = clk_get(NULL, "lcd");
if(!fbvar->lcd_clock)
dev_err(&pdev->dev, "failed to find lcd clock source\n");
ret = -ENOENT;
goto err_nomap;
clk_enable(fbvar->lcd_clock);
ret = request_irq(fbvar->lcd_irq_no, lcd_fb_irq, IRQF_DISABLED, pdev->name, fbvar);
if(ret)
dev_err(&pdev->dev, "IRQ%d error %d\n", fbvar->lcd_irq_no, ret);
ret = -EBUSY;
goto err_noclk;
strcpy(fbinfo->fix.id, driver_name);
fbinfo->fix.type = FB_TYPE_PACKED_PIXELS;
fbinfo->fix.type_aux = 0;
fbinfo->fix.xpanstep = 0;
fbinfo->fix.ypanstep = 0;
fbinfo->fix.ywrapstep= 0;
fbinfo->fix.accel = FB_ACCEL_NONE;
fbinfo->var.nonstd = 0;
fbinfo->var.activate = FB_ACTIVATE_NOW;
fbinfo->var.accel_flags = 0;
fbinfo->var.vmode = FB_VMODE_NONINTERLACED;
fbinfo->var.xres = display->xres;
fbinfo->var.yres = display->yres;
fbinfo->var.bits_per_pixel = display->bpp;
fbinfo->fbops = &my2440fb_ops;
fbinfo->flags = FBINFO_FLAG_DEFAULT;
fbinfo->pseudo_palette = &fbvar->pseudo_pal;
for(i = 0; i < 256; i++)
fbvar->palette_buffer[i] = PALETTE_BUFF_CLEAR;
for (i = 0; i < mach_info->num_displays; i++)
unsigned long smem_len = (mach_info->displays[i].xres *mach_info->displays[i].yres * mach_info->displays[i].bpp) >> 3;
if(fbinfo->fix.smem_len < smem_len)
fbinfo->fix.smem_len = smem_len;
msleep(1);
my2440fb_init_registers(fbinfo);
my2440fb_check_var(fbinfo);
ret = my2440fb_map_video_memory(fbinfo);
if (ret)
dev_err(&pdev->dev, "failed to allocate video RAM: %d\n", ret);
ret = -ENOMEM;
goto err_nofb;
ret = register_framebuffer(fbinfo);
if (ret < 0)
dev_err(&pdev->dev, "failed to register framebuffer device: %d\n", ret);
goto err_video_nomem;
ret = device_create_file(&pdev->dev, &dev_attr_debug);
if (ret)
dev_err(&pdev->dev, "failed to add debug attribute\n");
return 0;
err_nomem:
release_resource(fbvar->lcd_mem);
kfree(fbvar->lcd_mem);
err_nomap:
iounmap(fbvar->lcd_base);
err_noclk:
clk_disable(fbvar->lcd_clock);
clk_put(fbvar->lcd_clock);
err_noirq:
free_irq(fbvar->lcd_irq_no, fbvar);
err_nofb:
platform_set_drvdata(pdev, NULL);
framebuffer_release(fbinfo);
err_video_nomem:
my2440fb_unmap_video_memory(fbinfo);
return ret;
static irqreturn_t lcd_fb_irq(int irq, void *dev_id)
struct my2440fb_var *fbvar = dev_id;
void __iomem *lcd_irq_base;
unsigned long lcdirq;
lcd_irq_base = fbvar->lcd_base + S3C2410_LCDINTBASE;
lcdirq = readl(lcd_irq_base + S3C24XX_LCDINTPND);
if(lcdirq & S3C2410_LCDINT_FRSYNC)
if (fbvar->palette_ready)
my2440fb_write_palette(fbvar);
writel(S3C2410_LCDINT_FRSYNC, lcd_irq_base + S3C24XX_LCDINTPND);
writel(S3C2410_LCDINT_FRSYNC, lcd_irq_base + S3C24XX_LCDSRCPND);
return IRQ_HANDLED;
static void my2440fb_write_palette(struct my2440fb_var *fbvar)
unsigned int i;
void __iomem *regs = fbvar->lcd_base;
fbvar->palette_ready = 0;
for (i = 0; i < 256; i++)
unsigned long ent = fbvar->palette_buffer[i];
if (ent == PALETTE_BUFF_CLEAR)
continue;
writel(ent, regs + S3C2410_TFTPAL(i));
if (readw(regs + S3C2410_TFTPAL(i)) == ent)
else
fbvar->palette_ready = 1;
static int my2440fb_init_registers(struct fb_info *fbinfo)
unsigned long flags;
void __iomem *tpal;
void __iomem *lpcsel;
struct my2440fb_var *fbvar = fbinfo->par;
struct s3c2410fb_mach_info *mach_info = fbvar->dev->platform_data;
tpal = fbvar->lcd_base + S3C2410_TPAL;
lpcsel = fbvar->lcd_base + S3C2410_LPCSEL;
local_irq_save(flags);
modify_gpio(S3C2410_GPCUP, mach_info->gpcup, mach_info->gpcup_mask);
modify_gpio(S3C2410_GPCCON, mach_info->gpccon, mach_info->gpccon_mask);
modify_gpio(S3C2410_GPDUP, mach_info->gpdup, mach_info->gpdup_mask);
modify_gpio(S3C2410_GPDCON, mach_info->gpdcon, mach_info->gpdcon_mask);
local_irq_restore(flags);
writel(0x00, tpal);
writel(mach_info->lpcsel, lpcsel);
return 0;
static inline void modify_gpio(void __iomem *reg, unsigned long set, unsigned long mask)
unsigned long tmp;
tmp = readl(reg) & ~mask;
writel(tmp | set, reg);
static int my2440fb_check_var(struct fb_info *fbinfo)
unsigned i;
struct fb_var_screeninfo *var = &fbinfo->var;
struct s3c2410fb_display *display = NULL;
struct s3c2410fb_display *default_display = mach_info->displays +mach_info->default_display;
int type = default_display->type;
if (var->yres == default_display->yres &&
var->xres == default_display->xres &&
var->bits_per_pixel == default_display->bpp)
display = default_display;
else
if (type == mach_info->displays[i].type &&
var->yres == mach_info->displays[i].yres &&
var->xres == mach_info->displays[i].xres &&
var->bits_per_pixel == mach_info->displays[i].bpp)
display = mach_info->displays + i;
break;
if (!display)
return -EINVAL;
fbvar->regs.lcdcon1 = display->type;
fbvar->regs.lcdcon5 = display->lcdcon5;
var->xres_virtual = display->xres;
var->yres_virtual = display->yres;
var->height = display->height;
var->width = display->width;
var->pixclock = display->pixclock;
var->left_margin = display->left_margin;
var->right_margin = display->right_margin;
var->upper_margin = display->upper_margin;
var->lower_margin = display->lower_margin;
var->vsync_len = display->vsync_len;
var->hsync_len = display->hsync_len;
var->transp.offset = 0;
var->transp.length = 0;
switch (var->bits_per_pixel)
case 1:
case 2:
case 4:
var->red.offset = 0;
var->red.length = var->bits_per_pixel;
var->green = var->red;
var->blue = var->red;
break;
case 8:
if (display->type != S3C2410_LCDCON1_TFT)
var->red.length = 3;
var->red.offset = 5;
var->green.length = 3;
var->green.offset = 2;
var->blue.length = 2;
var->blue.offset = 0;
}else{
var->red.length = 8;
break;
case 12:
var->red.length = 4;
var->red.offset = 8;
var->green.length = 4;
var->green.offset = 4;
var->blue.length = 4;
break;
case 16:
if (display->lcdcon5 & S3C2410_LCDCON5_FRM565)
var->red.offset = 11;
var->green.offset = 5;
var->red.length = 5;
var->green.length = 6;
var->blue.length = 5;
} else {
var->green.offset = 6;
var->blue.offset = 1;
var->green.length = 5;
break;
case 32:
var->red.offset = 16;
var->green.length = 8;
var->green.offset = 8;
var->blue.length = 8;
break;
return 0;
static int __init my2440fb_map_video_memory(struct fb_info *fbinfo)
dma_addr_t map_dma;
unsigned map_size = PAGE_ALIGN(fbinfo->fix.smem_len);
fbinfo->screen_base = dma_alloc_writecombine(fbvar->dev, map_size, &map_dma,GFP_KERNEL);
if (fbinfo->screen_base)
memset(fbinfo->screen_base, 0x00, map_size);
fbinfo->fix.smem_start = map_dma;
return fbinfo->screen_base ? 0 : -ENOMEM;
static inline void my2440fb_unmap_video_memory(struct fb_info *fbinfo)
dma_free_writecombine(fbvar->dev, map_size, fbinfo->screen_base,fbinfo->fix.smem_start);
static int __devexit lcd_fb_remove(struct platform_device *pdev)
struct fb_info *fbinfo = platform_get_drvdata(pdev);
unregister_framebuffer(fbinfo);
my2440fb_lcd_enable(fbvar, 0);
msleep(1);
if (fbvar->lcd_clock)
fbvar->lcd_clock = NULL;
return 0;
static void my2440fb_lcd_enable(struct my2440fb_var *fbvar, int enable)
if (enable)
fbvar->regs.lcdcon1 |= S3C2410_LCDCON1_ENVID;
else
fbvar->regs.lcdcon1 &= ~S3C2410_LCDCON1_ENVID;
writel(fbvar->regs.lcdcon1, fbvar->lcd_base + S3C2410_LCDCON1);
#ifdef CONFIG_PM
static int lcd_fb_suspend(struct platform_device *pdev, pm_message_t state)
msleep(1);
return 0;
static int lcd_fb_resume(struct platform_device *pdev)
msleep(1);
my2440fb_activate_var(fbinfo);
my2440fb_blank(FB_BLANK_UNBLANK, fbinfo);
return 0;
#else
#define lcd_fb_suspend NULL
#define lcd_fb_resume NULL
#endif
