/****************引脚定义*********************************
接口:硬件SPI
PB.1(SCK) SCLK 方向:1
PB.2(MOSI) DIN 方向:1
PB.3(MISO) DOUT 方向:0
PB.4 CS 方向:1
PB.5 EOC 方向:0 DRRB="0x06"
MCU:ATmage128
AD:MAX1168(16bit)
晶振:11.0592M
编写:Jesse Rei
#include
#include
#include"lcd.c"
#define uchar unsigned char
#define uint unsigned int
#define Command_H 0x01 //000 00 00 1 通道0,单通道转换,无节电模式,内部时钟
#define Command_L 0x00 //命令低八位为任意数
#define CS_L PORTB&=~(1<<4) //PB.4
#define CS_H PORTB|=(1<<4)
#define READY PINB&0x20 //PB.5
uchar tab[10]={'0','1','2','3','4','5','6','7','8','9'};
/**************全局变量*****************************/
uchar buffer[5]={1,1,1,1,1};
uchar count="0";
uint sum="0";
/******************端口初始化***********************/
void port_init(void)
PORTA = 0xff;
DDRA = 0xff;
PORTB = 0x06;
DDRB = 0xff;
PORTC = 0x00; //m103 output on
DDRC = 0x00;
PORTD = 0xff;
DDRD = 0xff;
PORTE = 0x00;
DDRE = 0x00;
PORTF = 0x00;
DDRF = 0x00;
PORTG = 0x00;
DDRG = 0x00;
/*********************SPI初始化***************************/
void spi_init(void)
SPCR="0x5d"; //SPI允许,主机模式,高字节在前,工作模式3,Fck/128
//SPIE SPE DORD MSTR CPOL CPHA SPR1 SPR0
// 0 1 0 1 1 0 1 1
SPSR = 0x00; //setup SPI,主机倍频
/*********************启动AD转换***************************/
void start(uchar Com_H,uchar Com_L)
CS_L;
SPDR="Com"_H;
while(!(SPSR&(1<
while(!(SPSR&(1<
/******************拆数,用以显示*************************/
void da
uchar i;
for(i=0;i<=4;i++)
buffer[i]=a%10;
a=a/10;
void getdata(void)
uchar da
uint ad_da
uint ad_dat=0;
SPDR = 0xff; //发送数据,给max1168提供脉冲
while (!(SPSR &(1<
while (!(SPSR &(1<
ad_da
ad_dat=ad_da
sum+=ad_dat; //十六次采样结果累加和
count++;
if(count>15)
count="0";
ad_da
ad_da
da
sum=0;
CS_H;
/*************************延时1ms**************************
void delay1ms(uint t)
uint i;
for(;t>0;t--)
for(i=0;i<1106;i++)
/*************************主程序***************************/
void main()
port_init();
init_lcd();
lat_disp (0x00,0x00);
chn_disp (tab1);
delay1ms(5500);
chn_disp (tab2);
spi_init();
start(Command_H,Command_L);
while(1)
while(READY); //等待转换结束
getdata();
disp_two_char(0x8a,tab[buffer[4]],tab[buffer[3]]);
disp_two_char(0x8b,tab[buffer[2]],tab[buffer[1]]);
disp_two_char(0x8c,tab[buffer[0]],'V');
上一篇:ATmega128型号标识说明
下一篇:avr内部EEPROM实验
推荐阅读最新更新时间:2024-03-16 15:02
设计资源 培训 开发板 精华推荐
- 非常见问题解答第223期:如何在没有软启动方程的情况下测量和确定软启动时序?
- 兆易创新GD25/55全系列车规级SPI NOR Flash荣获ISO 26262 ASIL D功能安全认证证书
- 新型IsoVu™ 隔离电流探头:为电流测量带来全新维度
- 英飞凌推出简化电机控制开发的ModusToolbox™电机套件
- 意法半导体IO-Link执行器电路板为工业监控和设备厂商带来一站式参考设计
- Melexis采用无磁芯技术缩小电流感测装置尺寸
- 千丘智能侍淳博:用数字疗法,点亮“孤独症”儿童的光
- 数药智能冯尚:ADHD数字疗法正为儿童“多动症”提供更有效便捷服务
- Vicor高性能电源模块助力低空航空电子设备和 EVTOL的发展
- 创实技术electronica 2024首秀:加速国内分销商海外拓展之路
