#define SLAVE_ADDRESS 0x04
#define SLAVE_WRITE_ADDRESS (SLAVE_ADDRESS<<1)|0x00
#define SLAVE_READ_ADDRESS (SLAVE_ADDRESS<<1)|0x01
#define I2C_SDA BIT3
#define I2C_SCL BIT4
#define I2C_PORT_IN P6IN
#define I2C_PORT_OUT P6OUT
#define I2C_PORT_DIR P6DIR
#define SDA_IN (I2C_PORT_IN & I2C_SDA)
#define SCL_IN (I2C_PORT_IN & I2C_SCL)
#define S_SDA I2C_PORT_DIR &= ~I2C_SDA
#define C_SDA I2C_PORT_DIR |= I2C_SDA;I2C_PORT_OUT &= ~I2C_SDA
#define S_SCL I2C_PORT_DIR &= ~I2C_SCL
#define C_SCL I2C_PORT_DIR |= I2C_SCL;I2C_PORT_OUT &= ~I2C_SCL
void I2C_init(void)
I2C_PORT_DIR &= ~(I2C_SDA|I2C_SCL);
I2C_PORT_OUT |= (I2C_SDA|I2C_SCL);
void I2C_DELAY(void)
asm("nop");asm("nop");
void I2C_Start(void)
S_SDA;
S_SCL;
I2C_DELAY();
C_SDA;
I2C_DELAY();
C_SCL;
void I2C_Stop(void)
C_SDA;
I2C_DELAY();
S_SCL;
I2C_DELAY();
S_SDA;
I2C_DELAY();
void I2C_Send_Ack(void)
C_SDA;
I2C_DELAY();
S_SCL;
I2C_DELAY();
C_SCL;
I2C_DELAY();
void I2C_Send_NoAck(void)
S_SDA;
I2C_DELAY();
S_SCL;
I2C_DELAY();
C_SCL;
I2C_DELAY();
void I2C_Read_Ack(void)
unsigned char i = 0;
S_SCL;
S_SDA;
I2C_DELAY();
for(i=0; i<100; i++)
if(SDA_IN == 0)
I2C_DELAY(); break;
I2C_DELAY();
C_SCL;
I2C_DELAY();
void I2C_WriteByte(unsigned char one_byte)
S_SDA;
for (i=0; i<8; i++)
if (one_byte&0x80)
S_SDA;
else
C_SDA;
one_byte<<=1;
I2C_DELAY();
S_SCL;
I2C_DELAY();
C_SCL;
I2C_DELAY();
unsigned char I2C_ReadByte(void)
unsigned char read_byte=0;
S_SDA;
//C_SCL;
I2C_DELAY();
for (i=0; i<8; i++)
S_SCL;
I2C_DELAY();
read_byte<<=1;
if (SDA_IN != 0)
read_byte |= 0x01;
//I2C_DELAY;
C_SCL;
I2C_DELAY();
return read_byte;
void I2C_write_Nbyte(unsigned char *pbuf, unsigned char cnt)
I2C_Start();
I2C_WriteByte(SLAVE_WRITE_ADDRESS);
I2C_Read_Ack();
for (i=0; i
I2C_DELAY();I2C_DELAY();
I2C_WriteByte(*pbuf);
pbuf++;
I2C_Read_Ack();
I2C_Stop();
void I2C_read_Nbyte(unsigned char *pbuf, unsigned char cnt)
I2C_Start();
I2C_WriteByte(SLAVE_READ_ADDRESS);
I2C_Read_Ack();
for (i=1; i
*pbuf = I2C_ReadByte();
pbuf++;
I2C_Send_Ack();
I2C_Stop();
上一篇:STC不断电的下载方法
下一篇:Msp430时钟设计与寄存器说明
推荐阅读最新更新时间:2024-03-16 15:05
