#include
#include"intrins.h"
sbit CS=P3^0; //使能片选
sbit CLK=P3^1; //时钟
sbit Do=P3^2; //数据输出
sbit Di=P3^2; //数据输入
sbit Do2=P3^3; //数据输出
sbit Di2=P3^3; //数据输入
sbit Do3=P3^4; //数据输出
sbit Di3=P3^4; //数据输入
sbit Do4=P3^5; //数据输出
sbit Di4=P3^5; //数据输入
sbit Do5=P3^6; //数据输出
sbit Di5=P3^6; //数据输入
unsigned char data_f=0,data_c=0,data_f2=0,data_c2=0,data_f3=0,data_c3=0,data_f4=0,data_c4=0,data_f5=0,data_c5=0; //data_f正确顺序 data_c逆序
unsigned char last[5]; //记录上一时刻各AD转换得到的值
unsigned char current[5]; //记录此次AD转换得到的值
int left = 0; //记录0.1秒内电机向左转动的步数
int right = 0; //记录0.1秒内电机向右转动的步数
sbit RS = P2^4;//Pin4
sbit RW = P2^5; //Pin5
sbit E = P2^6;//Pin6
#define Data P0 //数据端口
char data TimeNum[]=" ";
char data Test1[]=" ";
/* 函数声明 */
void DelayUs(unsigned char us)//delay us
unsigned char uscnt;
uscnt=us>>1;/* Crystal frequency in 12MHz*/
while(--uscnt);
void DelayMs(unsigned int ms)//delay Ms
while(--ms)
DelayUs(250);
DelayUs(250);
DelayUs(250);
DelayUs(250);
void WriteCommand(unsigned char c)
DelayMs(5);//short delay before operation
E=0;
RS=0;
RW=0;
_nop_();
E=1;
Data=c;
E=0;
void WriteData(unsigned char c)
DelayMs(5); //short delay before operation
E=0;
RS=1;
RW=0;
_nop_();
E=1;
Data=c;
E=0;
RS=0;
void ShowChar(unsigned char pos,unsigned char c)
unsigned char p;
if (pos>=0x10)
p=pos+0xb0; //是第二行则命令代码高4位为0xc
else
p=pos+0x80; //是第二行则命令代码高4位为0x8
WriteCommand (p);//write command
WriteData (c); //write data
void ShowString (unsigned char line,char *ptr)
unsigned char l,i;
l=line<<4;
for (i=0;i<16;i++)
ShowChar (l++,*(ptr+i));//循环显示16个字符
void InitLcd()
DelayMs(15);
WriteCommand(0x38); //display mode
WriteCommand(0x06); //显示光标移动位置
WriteCommand(0x0c); //显示开及光标设置
WriteCommand(0x01); //显示清屏
//ADC转换函数========================================================
void ADconv()
unsigned char i;
//时能前初始化====================================================
Di=1;
Di2=1;
Di3=1;
Di4=1;
Di5=1;
CS=1;
_nop_();
CS=0;
Di=1;
Di2=1;
Di3=1;
Di4=1;
Di5=1;
//第一个下降沿===================================================
CLK=1;
_nop_();
_nop_();
CLK=0;
//确定通道方式,第二个下降沿===================================
_nop_();
_nop_();
CLK=1;
Di=1;
Di2=1;
Di3=1;
Di4=1;
Di5=1;
_nop_();
_nop_();
CLK=0;
//第三个下降沿===================================================
_nop_();
_nop_();
CLK=1;
Di=0;
Di2=1;
Di3=1;
Di4=1;
Di5=1;
_nop_();
_nop_();
CLK=0; //AD初始化完成
//读取数据========================================================
Di=1; //IO变为输入
Di2=1;
Di3=1;
Di4=1;
Di5=1;
CLK=1;
_nop_();
_nop_();
CLK=0;
CLK=1;
CLK=1;
_nop_();
_nop_();
CLK=0;
CLK=1;
//得到一个正常排序的8位数据
for(i=8;i>0;i--)
data_f<<=1;
data_f2<<=1;
data_f3<<=1;
data_f4<<=1;
data_f5<<=1;
data_f|=Do;
data_f2|=Do2;
data_f3|=Do3;
data_f4|=Do4;
data_f5|=Do5;
CLK=1;
_nop_();
_nop_();
CLK=0;
_nop_();
//得到一个反序排列的8位数据
for(i=8;i>0;i--)
data_c<<=1;
data_c2<<=1;
data_c3<<=1;
data_c4<<=1;
data_c5<<=1;
data_c|=Do;
data_c2|=Do2;
data_c3|=Do3;
data_c4|=Do4;
data_c5|=Do5;
_nop_();
CLK=1;
_nop_();
_nop_();
CLK=0;
_nop_();
CLK=0;
_nop_();
_nop_();
CLK=1;
_nop_();
_nop_();
CLK=0;
_nop_();
_nop_();
CLK=1;
_nop_();
CS=1;
_nop_();
_nop_();
//显示转换===========================================================
char huanhuan(unsigned char benben)
switch(benben)
case 0:
return '0';
break;
case 1:
return '1';
break;
case 2:
return '2';
break;
case 3:
return '3';
break;
case 4:
return '4';
break;
case 5:
return '5';
break;
case 6:
return '6';
break;
case 7:
return '7';
break;
case 8:
return '8';
break;
case 9:
return '9';
break;
default:
break;
void main()
unsigned xianshi=0;
InitLcd();
DelayMs(15);
sprintf(Test1," wo shi tiancai ");//the first line
ShowString(0,Test1);
sprintf(TimeNum,"AD value is ");//the first line
ShowString(1,TimeNum);
while(1)
DelayMs(800);
xianshi=data_f;
ADconv();
TimeNum[12]=huanhuan(xianshi/100);
TimeNum[13]=huanhuan(xianshi/10%10);
TimeNum[14]=huanhuan(xianshi%10);
上一篇:AT89C51ED2 的EEPROM 读写操作总结
下一篇:51单片机24c02的使用
推荐阅读最新更新时间:2024-03-16 15:06
