硬件中断方式I2C(CVAVR)
发布者:chaxue1987最新更新时间:2016-09-07 来源: eefocus关键字:硬件  中断方式  I2C  CVAVR 手机看文章 扫描二维码
随时随地手机看文章
//i2c.h
#define TWPS0 0
#define TWPS1 1
#define TWEN  2
#define TWIE  0
#define TWEA  6
#define TWINT 7
#define TWSTA 5
#define TWSTO 4
// TWSR values (not bits)
// Master
#define TW_START                                        0x08
#define TW_REP_START                                0x10
// Master Transmitter
#define TW_MT_SLA_ACK                                0x18
#define TW_MT_SLA_NACK                                0x20
#define TW_MT_DATA_ACK                                0x28
#define TW_MT_DATA_NACK                                0x30
#define TW_MT_ARB_LOST                                0x38
// Master Receiver
#define TW_MR_ARB_LOST                                0x38
#define TW_MR_SLA_ACK                                0x40
#define TW_MR_SLA_NACK                                0x48
#define TW_MR_DATA_ACK                                0x50
#define TW_MR_DATA_NACK                                0x58
// Slave Transmitter
#define TW_ST_SLA_ACK                                0xA8
#define TW_ST_ARB_LOST_SLA_ACK                           0xB0
#define TW_ST_DATA_ACK                                0xB8
#define TW_ST_DATA_NACK                                0xC0
#define TW_ST_LAST_DATA                                0xC8
// Slave Receiver
#define TW_SR_SLA_ACK                                0x60
#define TW_SR_ARB_LOST_SLA_ACK                          0x68
#define TW_SR_GCALL_ACK                                0x70
#define TW_SR_ARB_LOST_GCALL_ACK                            0x78
#define TW_SR_DATA_ACK                                0x80
#define TW_SR_DATA_NACK                                0x88
#define TW_SR_GCALL_DATA_ACK                                    0x90
#define TW_SR_GCALL_DATA_NACK                                    0x98
#define TW_SR_STOP                                        0xA0
// Misc
#define TW_NO_INFO                                        0xF8
#define TW_BUS_ERROR                                0x00
// defines and constants
#define TWCR_CMD_MASK                                       0x0F
#define TWSR_STATUS_MASK                                  0xF8
// return values
#define I2C_OK                                                0x00
#define I2C_ERROR_NODEV                                        0x01
#define I2C_SEND_DATA_BUFFER_SIZE                          0x20
#define I2C_RECEIVE_DATA_BUFFER_SIZE                      0x20
#define F_CPU 8000000
#define TRUE  1
#define FALSE 0
// types
typedef enum
        I2C_IDLE = 0, I2C_BUSY = 1,
        I2C_MASTER_TX = 2, I2C_MASTER_RX = 3,
        I2C_SLAVE_TX = 4, I2C_SLAVE_RX = 5
} eI2cStateType;
//i2c.c
#include
#include "i2c.h"
// I2C标准波特率:
// 低速 100KHz
// 高速 400KHz
// I2C 状态和地址变量
static volatile eI2cStateType I2cState;
static unsigned char I2cDeviceAddrRW;
// 发送缓冲区
static unsigned char I2cSendData[I2C_SEND_DATA_BUFFER_SIZE];
static unsigned char I2cSendDataIndex;
static unsigned char I2cSendDataLength;
// 接收缓冲区
static unsigned char I2cReceiveData[I2C_RECEIVE_DATA_BUFFER_SIZE];
static unsigned char I2cReceiveDataIndex;
static unsigned char I2cReceiveDataLength;
unsigned char localBuffer[] = "!!";
unsigned char localBufferLength = 0x20;
// 指向接收处理函数的指针,当本机被选中从接收时调用函数:I2cSlaveReceive
static void (*i2cSlaveReceive)(unsigned char receiveDataLength, unsigned char* recieveData);
// 指向发送处理函数的指针,当本机被选中从发送时调用函数:II2cSlaveTransmit
static unsigned char (*i2cSlaveTransmit)(unsigned char transmitDataLengthMax, unsigned char* transmitData);
//设置总线速率
void i2cSetBitrate(unsigned int  bitrateKHz)
        unsigned char bitrate_div;
        // SCL freq = F_CPU/(16+2*TWBR))
        #ifdef TWPS0
                // 对于用速率分频的AVR (mega128)
                // SCL freq = F_CPU/(16+2*TWBR*4^TWPS)
                // set TWPS to zero
                  TWSR&=~(1<                 TWSR&=~(1<         #endif
        // 计算分频
        bitrate_div = ((F_CPU/1000l)/bitrateKHz);
        if(bitrate_div >= 16)
                bitrate_div = (bitrate_div-16)/2;
          TWBR = bitrate_div;
//总线初始化
void i2cInit(void)
        //设置总线上拉
        #ifdef _MEGA128_INCLUDED_
        //#ifdef _MEGA64_INCLUDED_
        PORTD.0=1;        // i2c SCL on ATmega128,64
        PORTD.1=1;        // i2c SDA on ATmega128,64
  #else
  PORTC.0=1;        // i2c SCL on ATmega163,323,16,32,等
  PORTC.1=1;        // i2c SDA on ATmega163,323,16,32,等
  #endif
        // 清空从发送和从接受
        i2cSlaveReceive = 0;
        i2cSlaveTransmit = 0;
        // 设置 i2c 波特率为 100KHz
        i2cSetBitrate(100);
        // I2C总线使能
        TWCR|=1<         // 状态设置
        I2cState = I2C_IDLE;
        // 开I2C中断和回应
          TWCR|=1<           TWCR|=1<
        #asm("sei");
void i2cSetLocalDeviceAddr(unsigned char deviceAddr, unsigned char genCallEn)
 // 设置本机从地址 (从方式时)
        TWAR=(deviceAddr&0xFE)|(genCallEn?1:0);
void i2cSetSlaveReceiveHandler(void (*i2cSlaveRx_func)(unsigned char receiveDataLength, unsigned char* recieveData))
        i2cSlaveReceive = i2cSlaveRx_func;
void i2cSetSlaveTransmitHandler(unsigned char (*i2cSlaveTx_func)(unsigned char transmitDataLengthMax, unsigned char* transmitData))
        i2cSlaveTransmit = i2cSlaveTx_func;
inline void i2cSendStart(void)
  TWCR=TWCR&TWCR_CMD_MASK|(1<
inline void i2cSendStop(void)
        // 发送停止条件,保持TWEA以便从接收
inline void i2cWaitForComplete(void)
        // 等待i2c 总线操作完成
        while( !(TWCR&(1<
inline void i2cSendByte(unsigned char data)
        // 装载数据到 TWDR
          TWDR=data;
        // 发送开始
inline void i2cReceiveByte(unsigned char ackFlag)
        //开始通过 i2c 接收
        if( ackFlag )
                // ackFlag = TRUE: 数据接收后回应ACK
            TWCR=TWCR&TWCR_CMD_MASK|(1<         }
        else
                // ackFlag = FALSE: 数据接收后无回应
inline unsigned char i2cGetReceivedByte(void)
        // 返回接收到的数据
        return( TWDR );
inline unsigned char i2cGetStatus(void)
        // 返回总线状态
        return(TWSR);
void i2cMasterSend(unsigned char deviceAddr, unsigned char length, unsigned char* data)
        unsigned char i;
        // 等待总线准备完成
        while(I2cState);
        // 设置状态
        I2cState = I2C_MASTER_TX;
        // 准备数据
        I2cDeviceAddrRW = (deviceAddr & 0xFE);        // RW 为0: 写操作
        for(i=0; i                 I2cSendData[i] = *data++;
        I2cSendDataIndex = 0;
        I2cSendDataLength = length;
        // 发送开始条件
        i2cSendStart();
void i2cMasterReceive(unsigned char deviceAddr, unsigned char length, unsigned char* data)
        unsigned char i;
        // 等待总线准备完成
        while(I2cState);
        // 设置状态
        I2cState = I2C_MASTER_RX;
        // 保存数据
        I2cDeviceAddrRW = (deviceAddr|0x01);        // RW 为1 : 读操作
        I2cReceiveDataIndex = 0;
        I2cReceiveDataLength = length;
        // 发送开始条件
        i2cSendStart();
        //等待数据准备好
        while(I2cState);
        // 取数据
        for(i=0; i                 *data++ = I2cReceiveData[i];
unsigned char i2cMasterSendNI(unsigned char deviceAddr, unsigned char length, unsigned char* data)
        unsigned char retval = I2C_OK;
        // 关I2C中断
        TWCR&=~(1<
        // 发送开始条件
        i2cSendStart();
        i2cWaitForComplete();
        // 发送器件写地址
        i2cSendByte( deviceAddr & 0xFE );
        // 检查器件是否可用
        if( TWSR == TW_MT_SLA_ACK)
                // 发送数据
                while(length)
                        i2cSendByte( *data++ );
                        length--;
        else
                // 如未回应器件地址,停止发送,返回错误
                retval = I2C_ERROR_NODEV;
        i2cSendStop();
        while( !(TWCR&(1<
        // 开I2C中断
        TWCR|=(1<
        return retval;
unsigned char i2cMasterReceiveNI(unsigned char deviceAddr, unsigned char length, unsigned char *data)
        // 关I2C中断
          TWCR&=~(1<
        //发送开始条件
        i2cSendStart();
        // 发送器件读地址
        i2cSendByte( deviceAddr | 0x01 );
        // 检查器件是否可用
        if( TWSR == TW_MR_SLA_ACK)
                // 接收数据并回应
                while(length > 1)
                        i2cReceiveByte(TRUE);
                        *data++ = i2cGetReceivedByte();
                        length--;
                //  接收数据无回应 (末位信号)
                i2cReceiveByte(FALSE);
        else
        i2cSendStop();
        // 开I2C中断
          TWCR|=TWIE;
        return retval;
eI2cStateType i2cGetState(void)
        return I2cState;
// I2C (TWI) 中断服务程序
interrupt [TWI] void twi_isr(void)
        //读状态位
        unsigned char status;
          status = TWSR & TWSR_STATUS_MASK;
        switch(status)
        // 主方式
        case TW_START:                                            // 0x08: START 已发送
        case TW_REP_START:                                        // 0x10: 重复START 已发送
          // 发送器件地址
                i2cSendByte(I2cDeviceAddrRW);
                break;
        // 主发送,主接收状态码
        case TW_MT_SLA_ACK:                                        // 0x18: SLA+W 已发送;接收到ACK
        case TW_MT_DATA_ACK:                                // 0x28: 数据已发送;接收到ACK
                if(I2cSendDataIndex < I2cSendDataLength)
                        // 发送数据
                        i2cSendByte( I2cSendData[I2cSendDataIndex++] );
                else
                        i2cSendStop();
                        // 设置状态
                break;
        case TW_MR_DATA_NACK:                                // 0x58: 接收到数据;NOT ACK 已返回
                // 保存最终数据
                I2cReceiveData[I2cReceiveDataIndex++] = TWDR;
                //继续发送条件
        case TW_MR_SLA_NACK:                                // 0x48: SLA+R 已发送,接收到NOT ACK
        case TW_MT_SLA_NACK:                                // 0x20: SLA+W 已发送,接收到NOT ACK
        case TW_MT_DATA_NACK:                                // 0x30: 数据已发送,接收到NOT ACK
                i2cSendStop();
                // 设置状态
                break;
        case TW_MT_ARB_LOST:                                // 0x38: SLA+W 或数据的仲裁失败
                // 释放总线
                  TWCR=TWCR&TWCR_CMD_MASK|(1<                 // 设置状态
                break;
        case TW_MR_DATA_ACK:                                // 0x50: 接收到数据,ACK 已返回
                // 保存接收到的数据位
                // 检查是否接收完
        case TW_MR_SLA_ACK:                                        // 0x40: SLA+R 已发送,接收到ACK
                if(I2cReceiveDataIndex < (I2cReceiveDataLength-1))
                        // 数据位将接收 , 回复 ACK (传送更多字节)
                else
                        // 数据位将接收 , 回复 NACK (传送最后字节)
                break;
        // 从接收状态码
        case TW_SR_SLA_ACK:                                        // 0x60: 自己的SLA+W 已经被接收,ACK 已返回
        case TW_SR_ARB_LOST_SLA_ACK:// 0x68: SLA+R/W 作为主机的仲裁失败;自己的SLA+W 已经被接收,ACK 已返回
        case TW_SR_GCALL_ACK:                                // 0x70: 接收到广播地址,ACK 已返回
        case TW_SR_ARB_LOST_GCALL_ACK: // 0x78: SLA+R/W 作为主机的仲裁失败;接收到广播地址,ACK 已返回
                // 被选中为从写入 (数据将从主机接收)
                // 设置状态
                I2cState = I2C_SLAVE_RX;
                // 缓冲准备
                // 接收数据,回应 ACK
                TWCR=TWCR&TWCR_CMD_MASK|(1<                 break;
        case TW_SR_DATA_ACK:                                // 0x80: 以前以自己的 SLA+W 被寻址;数据已经被接收,ACK 已返回
        case TW_SR_GCALL_DATA_ACK:        // 0x90: 以前以广播方式被寻址;数据已经被接收,ACK 已返回
                //检查接收缓冲区状态
                if(I2cReceiveDataIndex < I2C_RECEIVE_DATA_BUFFER_SIZE)
                        // 接收数据,回应 ACK
                else
                        // 接收数据,回应 NACK
                break;
        case TW_SR_DATA_NACK:                                // 0x88: 以前以自己的 SLA+W 被寻址;数据已经被接收,NOT ACK 已返回
        case TW_SR_GCALL_DATA_NACK:        // 0x98: 以前以广播方式被寻址;数据已经被接收,NOT ACK 已返回
                // 接收数据,回应 NACK
                break;
        case TW_SR_STOP:                                        // 0xA0: 在以从机工作时接收到STOP或重复START
    TWCR=TWCR&TWCR_CMD_MASK|(1<                 // i2c 接收完成
                if(i2cSlaveReceive)
                         i2cSlaveReceive(I2cReceiveDataIndex, I2cReceiveData);
                // 设置状态
                break;
        // 从发送
        case TW_ST_SLA_ACK:                                        // 0xA8: 自己的SLA+R 已经被接收,ACK 已返回
        case TW_ST_ARB_LOST_SLA_ACK:// 0xB0: SLA+R/W 作为主机的仲裁失败;自己的SLA+R 已经被接收,ACK 已返回
                // 被选中为从读出 (数据将从传回主机)
                // 设置状态
                I2cState = I2C_SLAVE_TX;
                // 数据请求
                if(i2cSlaveTransmit) I2cSendDataLength = i2cSlaveTransmit(I2C_SEND_DATA_BUFFER_SIZE, I2cSendData);
        case TW_ST_DATA_ACK:                                // 0xB8: TWDR 里数据已经发送,接收到ACK
                // 发送数据位
                  TWDR=I2cSendData[I2cSendDataIndex++];
                        // 回应 ACK
                          TWCR=TWCR&TWCR_CMD_MASK|(1<                 else
                        // 回应 NACK
        case TW_ST_DATA_NACK:                                // 0xC0: TWDR 里数据已经发送接收到NOT ACK
        case TW_ST_LAST_DATA:                                // 0xC8: TWDR 的一字节数据已经发送(TWAE = “0”);接收到ACK
                // 全部完成
                // 从方式开放
                break;
        case TW_NO_INFO:                                          // 0xF8: 没有相关的状态信息;TWINT = “0”
                // 无操作
                break;
        case TW_BUS_ERROR:                                        // 0x00: 由于非法的START 或STOP 引起的总线错误
                // 内部硬件复位,释放总线
                break;
// 从操作
void i2cSlaveReceiveService(unsigned char receiveDataLength, unsigned char* receiveData)
        unsigned char i;
  //此函数在本机被选中为从写入时运行
        // 接收到的数据存入本地缓冲区
        for(i=0; i         {
                localBuffer[i] = *receiveData++;
        localBufferLength = receiveDataLength;
unsigned char i2cSlaveTransmitService(unsigned char transmitDataLengthMax, unsigned char* transmitData)
        unsigned char i;
        //此函数在本机被选中为从读出时运行
        //要发送的数据存入发送缓冲区
        for(i=0; i         {
                *transmitData++ = localBuffer[i];
        localBuffer[0]++;
        return localBufferLength;
#define TARGET_ADDR        0xA0
//测试 (24xxyy 器件)
void testI2cMemory(void)
        unsigned char i;
        unsigned char txdata[66];
        unsigned char rxdata[66];
        txdata[0] = 0;
        txdata[1] = 0;
        for(i=0; i<16; i++)
           txdata[2+i] = localBuffer[i];
        // 发送地址和数据
        i2cMasterSendNI(TARGET_ADDR, 18, txdata);
        txdata[18] = 0;
        // 发送地址
        i2cMasterSendNI(TARGET_ADDR, 2, txdata);
        // 接收数据
        i2cMasterReceiveNI(TARGET_ADDR, 16, rxdata);
        rxdata[16] = 0;
void main(void)
 i2cInit();
 //设置从接收函数句柄(此函数在被选中为从接收时执行)
 i2cSetSlaveReceiveHandler( i2cSlaveReceiveService );
 //设置从发送函数句柄(此函数在被选中为从发送时执行)
 i2cSetSlaveTransmitHandler( i2cSlaveTransmitService );
 testI2cMemory();
关键字:硬件  中断方式  I2C  CVAVR 引用地址:硬件中断方式I2C(CVAVR)
上一篇:AVR简单的串口通信程序
下一篇:使用AVR定时/计数器的PWM功能设计要点
推荐阅读最新更新时间:2024-03-16 15:08
SPI、I2C、UART三种串行总线协议的区别
SPI、I2C、UART三种串行总线协议的区别      SPI(Serial Peripheral Interface:串行外设接口)      I2C(INTER IC BUS)      UART(Universal Asynchronous Receiver Transmitter:通用异步收发器) SPI The SPI includes these distinctive features: • Master mode and slave mode • Bi-directional mode • Slave select output • Mode fault error flag
[嵌入式]
智能硬件与物联网时代格局解析
  移动互联产业已经席卷全球,受益于该产业,中国的电子硬件产业得到了蓬勃的发展,这从我国A股上市公司就可以看出来,诞生了一批移动相关的上市公司,包括芯片公司、零部件公司、方案公司等。我们安创的股东中科创达和ARM也受益于此,在过去几年中发展迅速。下面就随网络通信小编一起来了了解一下相关内容吧。 智能硬件与物联网时代格局解析   但是移动产业已经成熟,作为国家和企业来讲也亟需寻求新的增长点。现在大家都把目光聚焦于 智能硬件 与 物联网 产业,但是该产业存在着碎片化、项目化,不能像PC和移动时代,能够在较短时间里面有量的增长,产生千亿甚至万亿的市场。同时,如何去分析、判断在 智能硬件 和 物联网 领域的创业和投资机会,是一直困
[网络通信]
2010年度硬件十大新闻 iPad一枝独秀
  12月24日消息,据国外媒体报道,2010年硬件产业主要特点是伙伴关系和技术创新。以下是2010年度硬件十大新闻事件:   苹果iPad一枝独秀   苹果iPad无疑是本年度最引人瞩目的产品,无论是成人还是孩子都想拥有它。iPad已经获得太多的殊荣,当之无愧地成为2010最火爆的产品。苹果公司因为iPad的出色表现,一个季度的收入就达200亿美元,成功挤入全球财富500强企业。专家们预测iPad未来的销量更为乐观。   惠普推出忆阻器技术   惠普公司于两年前发明忆阻器技术(Memristor),通过不断的研发,今年八月与与韩国半导体厂商海力士半导体(Hynix Semiconductor)合作以电阻式内存(ReRAM
[嵌入式]
STM32之I2C_FLAG_BUSY置位解决办法
stm32f429-disco上的触摸屏IC是STMPE811,使用I2C通信,该ic的使用还不算难,里面包括8通道12bit AD,8个GPIO口,加128set FIFO以及几个寄存器。 问题是出在STM32 的I2C IP核上,网上大家也吐槽了不少,最主要的就是各种当机,当当当当,哈哈。 我第一次出现当机的地方是在 if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_BUSY) == SET) { return HAL_BUSY; } 返回的BUSY值是一直置H的,这就奇怪了,用的是官方的STM32CubeMX生成的初始化代码,刚初始完就BUSY,太坑了吧。 查看dat
[单片机]
基于ATmega128和CH374的USB接口的软硬件设计
随着嵌入式系统的发展,嵌入式MCU需要增加USB接口,以便实现与PC机等USB主机系统的通信。针对这样的需求,解决方案比较多,均有一个共同点,都采用PHILIPS公司的PDIUSBD12芯片,该芯片为并行总线接口,占用过多的MCU端口资源,且与MCU的软件接口编写复杂,同时芯片价格也不便宜。为此,采用南京沁恒电子有限公司的USB芯片CH374设计了一款USB接口,以解决嵌入式MCU与PC机通信问题。CH374不仅价格有优势,该公司还提供了完善的USB驱动程序,且在芯片内部集成了数据缓冲区、被动并行接口、串行接口、命令解释器、通用的固件程序等,这样,以CH374设计的USB设备,不需要详细了解USB通讯协议,开发编程非常方便。
[单片机]
基于ATmega128和CH374的USB接口的软<font color='red'>硬件</font>设计
基于PXI和cRIO的ESP硬件在环仿真平台
在ESP研发过程中,需要大量实车试验。该试验有两大困难:一是试验具有相当的危险性,二是试验对场地要求很苛刻。所以,开发硬件在环仿真平台就成为一种迫切需求。 该仿真平台对加速ESP控制器的算法开发有重大作用。本文采用了NI公司的PXI作为下位机来搭建系统。   项目背景   本方案通过深入调研,主要考虑性能、价格、易实现性等方面之后,最终选择了NI的PXI和cRIO方案来进行系统搭建。主要调研了XPC方式、PXI系统、dSpace系统。XPC方式费用较低,但是使用不够方便,dSpace系统价格远远高于PXI系统,然而两者性能差别不是很大。   系统构架   ESP硬件在环仿真平台从硬件上看由上位机、下位机、控制器、执行器
[测试测量]
基于PXI和cRIO的ESP<font color='red'>硬件</font>在环仿真平台
定时器计数 数码管显示0到99 (中断和查询两种方式
定时器中断方式计数 #include reg51.h #define uchar unsigned char #define uint unsigned int uchar tab ={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8, 0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E}; uchar data_L, data_H; uchar data_0, b; void delay(uchar time) { uchar m; for(m=0;m time;m++) ; } void T0_init() { TMOD = 0x
[单片机]
定时器计数 数码管显示0到99 (<font color='red'>中断</font>和查询两种<font color='red'>方式</font>)
USB-GPIB控制器的硬件电路设计
引 言   USB是PC体系中一套全新的工业标准,通用可编程接口GPIB(General Programmable Interface BUS),是Cy-press公司在其EZ-USB FX以及FX2系列单片机里设计的一个可由用户编程的接口,具有快速、灵活等特点;可使用多种协议完成与外围器件的无缝连接,如EIDE/ATAPI、IEEE1284、Utopia等。对其可以根据需要进行编程,且运行中不需要CPU的干预,仅通过一些CPU标志和中断与增强型8051内核通信。作为自动化测试仪器的互联标准历史悠久,使用广泛,组建费用低廉且操作方便,特别是连接台式机的时候尤其显得灵活高效。在很多对测试速度要求不高以及对测试仪器体积不作要求的情况下
[工业控制]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
热门活动
换一批
更多
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
更多精选电路图
换一换 更多 相关热搜器件
更多每日新闻
随便看看
