凌阳61单片机使用7段数码管显示数字时钟的程序
发布者:Huayu8888最新更新时间:2016-09-20 来源: eefocus关键字:凌阳61单片机  7段数码管  显示数字时钟 手机看文章 扫描二维码
随时随地手机看文章
#include
#include
//中断函数定义
void IRQ1(void) __attribute__((ISR));
void IRQ5(void) __attribute__((ISR));
void IRQ6(void) __attribute__((ISR));
enum { RUN, CHGSECOND, CHGMINUTE, CHGHOUR } clock_status;   //时钟的状态
unsigned int hour,minute,second;
unsigned int show_hour, show_minute, show_second;
enum { NOKEY, PRESSING, PRESSED } key_status;           //键盘按下与否的状态
unsigned key_code;
// 7段LED数码管的字形码,采用高八位输出,决定显示的字形,如: '0'、'1'等
const unsigned int zhixingma[] = {  0x3f00, 0x0600, 0x5b00, 0x4f00,
                                    0x6600, 0x6d00, 0x7c00, 0x0700,
                                    0x7f00,0x6f00 };
// 数码管选择的"位段码",决定哪一位数码管显示
const unsigned int weiduanma[] = {0x0002, 0x0004, 0x0008, 0x0010, 0x0020, 0x0040};
//数码管的两个DD引脚, 为时,中间的冒号亮
const unsigned int wei_DD = 0x0081;
void display(unsigned int wei, unsigned int number)
    *P_IOA_Data = zhixingma[number];
    //设置位段码时,不能改变冒号的状态
    *P_IOB_Data = weiduanma[wei] | (*P_IOB_Buffer & wei_DD);
//取反数码管中间的冒号
void opposite_dots()
*P_IOB_Data = wei_DD ^ (*P_IOB_Buffer);
void delay(unsigned int howlong)
    while(howlong--){
        unsigned int temp = 0x00ff;
        *P_Watchdog_Clear = 1;
        while(temp--);
void init()
INT_OFF();
    *P_IOA_Dir = 0xff00;
    *P_IOA_Attrib = 0xff00;
    *P_IOB_Dir = 0x00ff;
    *P_IOB_Attrib = 0x00ff;
    *P_TimerA_Data = 0xffff - 256;
    *P_TimerA_Ctrl = C_SourceA_1 | C_SourceB_256Hz;
    *P_INT_Ctrl = C_IRQ1_TMA | C_IRQ6_TMB2 | C_IRQ5_2Hz;
    INT_IRQ();
void change_clock()
unsigned int key_code = get_key();
    static unsigned int max;
    switch(key_code){   // key_code == 0 will do nothing
        case 1:
            switch( clock_status ){
            case CHGSECOND:
                if(++second == 60) second = 0;
                break;
            case CHGMINUTE:
                if(++minute == 60) minute = 0;
                break;
            case CHGHOUR:
                if(++hour == 24) hour =0;
                break;
            default:
                break;
            break;
        case 2:
            case CHGSECOND:
                if(--second == 0) second = 59;
                break;
            case CHGMINUTE:
                if(--minute == 0) minute = 59;
                break;
            case CHGHOUR:
                if(--hour == 0) hour = 23;
                break;
            default:
                break;
            break;
        case 3:
            case RUN:
                clock_status = CHGSECOND;
                break;
            case CHGSECOND:
                clock_status = CHGMINUTE;
                break;
            case CHGMINUTE:
                clock_status = CHGHOUR;
                break;
            case CHGHOUR:
                clock_status = RUN;
                break;
            break;
        default:
            break;
int main()
init();
    while(1){
        change_clock();
        if(show_second){
            display(5, second % 10);
            delay(1);
            display(4, second / 10);
            delay(1);
        if(show_minute){
            display(3, minute % 10);
            delay(1);
            display(2, minute / 10);
            delay(1);
        if(show_hour){
            display(1, hour % 10);
            delay(1);
            display(0, hour / 10);
            delay(1);
void IRQ1()
    //时钟计数中断
    if( (C_IRQ1_TMA & *P_INT_Ctrl) != 0 )
    {   if( clock_status == RUN )
        {   second++;
            if(second >= 60 ) second=0, minute++;
            if(minute >= 60 ) minute=0, hour++;
            if(hour >= 24 ) hour=0;
        *P_INT_Clear = C_IRQ1_TMA;
void IRQ5()
{// 数码管闪烁
    if( (C_IRQ5_2Hz & *P_INT_Ctrl) != 0)
switch(clock_status){
        case RUN:
            opposite_dots();
            show_hour = show_minute = show_second = 0xffff;
            break;
        case CHGSECOND:
            show_second ^= 0xffff;
            show_minute = show_hour = 0xffff;
            break;
        case CHGMINUTE:
            show_minute ^= 0xffff;
            show_second = show_hour = 0xffff;
            break;
        case CHGHOUR:
            show_hour ^= 0xffff;
            show_second = show_minute = 0xffff;
            break;
        *P_INT_Clear = C_IRQ5_2Hz;
void IRQ6()
{   // 每10ms扫描一次键盘
    static unsigned int old_key = 0;
    static unsigned int key_count = 0;
    unsigned int current_key;
    if( (C_IRQ6_TMB2 & *P_INT_Ctrl) != 0)
    {   current_key = *P_IOA_Data & 0x0007;
        if( current_key != 0)
        {           //有按键
            if( key_status == NOKEY )
            {   old_key = current_key;
                key_count++;
                key_status = PRESSING;
            }else{
                if( current_key == old_key) //不相等,抖动
                    if( ++key_count >= 5)
//有>5次扫描的值相等,说明不是抖动,判断按键值
                    {   if(current_key == 0x0001) key_code = 1;
                        if(current_key == 0x0002) key_code = 2;
                        if(current_key == 0x0004) key_code = 3;
                }else{
                    // 抖动
                    old_key = 0;
                    key_count = 0;
                    key_status = NOKEY;
        }else{          //无按键
            old_key = 0;
            key_count = 0;
            if( key_status == PRESSING ) key_status = PRESSED;  //按键释放了
        *P_INT_Clear = C_IRQ6_TMB2;
关键字:凌阳61单片机  7段数码管  显示数字时钟 引用地址:凌阳61单片机使用7段数码管显示数字时钟的程序
上一篇:一种基于RFID的便携式智能语音播放器设计
下一篇:智能数字化开关电源设计方案
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
热门活动
换一批
更多
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
更多精选电路图
换一换 更多 相关热搜器件
更多每日新闻
随便看看
