STM32f103-实例睡眠模式的唤醒
发布者:温暖阳光最新更新时间:2016-09-26 来源: eefocus关键字:STM32f103  睡眠模式  唤醒 手机看文章 扫描二维码
随时随地手机看文章
main.c
 // environment           : writ by Chen maolin in 2010/9/23  on Kiel 4.0
 // finktion              : about a projiect  to  setup  EXTI
 // hardware optimization :
 // update                : 2010/9/26    陈茂林
#include "stm32f10x_lib.h"
#include "platform_config.h"
#include
extern  vu32 TimingDelay ;
ErrorStatus HSEStartUpStatus;
void SYSCLKconfig_STOP(void);
void RCC_Configuration(void);
void EXTI_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void RTC_Configuration (void);
void SysTick_Configuration(void);
void Delay(vu32 nCount);
int main(void)
#ifdef DEBUG
  debug();
#endif
  RCC_Configuration();
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR|RCC_APB1Periph_BKP,ENABLE );
  GPIO_Configuration();
  EXTI_Configuration();
  RTC_Configuration ();
  NVIC_Configuration();
  SysTick_Configuration();
  while (1)
     Delay(200) ;/*延时2s*/
  RTC_ClearFlag(RTC_FLAG_SEC); /*清秒中断标志位*/
  while(RTC_GetFlagStatus(RTC_FLAG_SEC)==RESET); /*等待秒中断*/ /*意思是要等1s才有反应*/
  RTC_SetAlarm(RTC_GetCounter()+3);/*设置秒报警中断*/
  RTC_WaitForLastTask();  /*等待最后一条写命令*/
  GPIO_SetBits(GPIOB,GPIO_Pin_6);
  GPIO_ResetBits(GPIOB,GPIO_Pin_7);
  PWR_EnterSTOPMode( PWR_Regulator_ON, PWR_STOPEntry_WFI ); /*这条是睡眠;PLL时钟停止,
  PC指令停止执行,一但有中断服务程序触发会使得PC指令向下执行但我们还需要通过一个函数恢复
  他的PLL时钟**/
  GPIO_ResetBits(GPIOB,GPIO_Pin_6);
  SYSCLKconfig_STOP();
  GPIO_SetBits(GPIOB,GPIO_Pin_7);
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
void RCC_Configuration(void)  /*初始时钟*/
       RCC_DeInit();                                              /* RCC system reset(for debug purpose) */
       RCC_HSEConfig(RCC_HSE_ON);                            /* Enable HSE */
       HSEStartUpStatus = RCC_WaitForHSEStartUp();            /* Wait till HSE is ready */
  if(HSEStartUpStatus == SUCCESS)
     FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);            /* Enable Prefetch Buffer */
     FLASH_SetLatency(FLASH_Latency_2);             /* Flash 2 wait state */
     RCC_HCLKConfig(RCC_SYSCLK_Div1);             /* HCLK = SYSCLK */
     RCC_PCLK2Config(RCC_HCLK_Div1);         /* PCLK2 = HCLK */
     RCC_PCLK1Config(RCC_HCLK_Div2);                                /* PCLK1 = HCLK/2 */
     RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);          /* PLLCLK = 8MHz * 9 = 72 MHz */
     RCC_PLLCmd(ENABLE);                                          /* Enable PLL */
  RCC_APB2PeriphClockCmd(  RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB|    /*总线APB2周围时钟设置*/
                                 RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO ,
            ENABLE
     while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)                     /* Wait till PLL is ready */
     RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);                           /* Select PLL as system clock source */
     while(RCC_GetSYSCLKSource() != 0x08)                                /* Wait till PLL is used as system clock source */
* Function Name  : 从停机模式下唤醒之后: 配置系统时钟允许HSE,和 pll 作为系统时钟。
* Description    : Inserts a delay time.
* Input          : None
* Output         : None
* Return         : None
    RCC_HSEConfig(RCC_HSE_ON); /*HSES使能*/
    HSEStartUpStatus = RCC_WaitForHSEStartUp(); /*等待*/
      RCC_PLLCmd(ENABLE);/*使能*/
         while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)== RESET); /*等待PLL有效*/
   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);/*将PLL作为系统时钟*/
   while(RCC_GetSYSCLKSource() != 0x08);/*等待*/
* Function Name  : GPIO_Configuration();
* Description    : GPIO SET
* Input          : nCount: None
* Output         : None
* Return         : None
  GPIO_InitTypeDef GPIO_InitStructure;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_10 | GPIO_Pin_11|GPIO_Pin_12 | GPIO_Pin_12 | GPIO_Pin_13| GPIO_Pin_14|GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOB, &GPIO_InitStructure);//GPIO_InitStructure指向了GPIO_InitTypeDef ,GPIO_InitTypeDef结构体包含了基本信息
    /* Configure Key Button GPIO Pin as input floating (Key Button EXTI Line) */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
* Output         : None
* Return         : None
  EXTI_InitTypeDef EXTI_InitStructure;
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource5);
  /* Configure Key Button EXTI Line to generate an interrupt on falling edge */
  EXTI_InitStructure.EXTI_Line = EXTI_Line5;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /*配置EXTI_Line17(RTC_Alarm)为上升沿触发*/
  EXTI_ClearITPendingBit(EXTI_Line17);
  EXTI_InitStructure.EXTI_Line = EXTI_Line17 ;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
* Function Name  : RTC_Configuration
* Description    : PTC_clclk
* Input          : None
* Output         : None
* Return         : None
  /*配置RTC时钟源*/
  /* 允许访问BKP*/
 PWR_BackupAccessCmd(ENABLE);
 /*复位备份域*/
 BKP_DeInit();
 /*允许LSE*/
 RCC_LSEConfig(RCC_LSE_ON);
 /*等待LSE有效*/
 while (RCC_GetFlagStatus(RCC_FLAG_LSERDY)==RESET) ;
 /*选择LSE做为RTC时钟 */
 RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
 /*允许RTC时钟*/
 RCC_RTCCLKCmd(ENABLE);
 /*配置RTC*/
 /*等待RTC APB同步*/
 RTC_WaitForSynchro();
 /*预分频值为1s*/
 RTC_SetPrescaler(32767);
 /*等待最后一条写指令完成*/
 /*允许RTC报警中断*/
 RTC_ITConfig(RTC_IT_ALR, ENABLE);
 /*等待最后一条写指令完成*/
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
       NVIC_InitTypeDef NVIC_InitStruct;
    /*设置中断向量基址为0x8000000*/
    NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
    NVIC_InitStruct.NVIC_IRQChannel= RTCAlarm_IRQChannel ;
    NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority= 0;
    NVIC_InitStruct.NVIC_IRQChannelSubPriority= 0;
    NVIC_InitStruct.NVIC_IRQChannelCmd= ENABLE;
    NVIC_Init(&NVIC_InitStruct);
    NVIC_InitStruct.NVIC_IRQChannel= EXTI9_5_IRQChannel ;
* Function Name  : SysTick_Configuration
* Description    : 配置1ms时钟
* Input          : None
* Output         : None
* Return         : None
    /*选择HCLK做为SysTick时钟源 */
   SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);
    /*_SysTick设置为优先级3 */
   NVIC_SystemHandlerPriorityConfig (SystemHandler_SysTick, 3,0 );
   /*1ms发生1次SysTick中断对应HCLK为72MHZ */
   SysTick_SetReload(72000) ;
   /* 允许SysTick中断*/
   SysTick_ITConfig(ENABLE);
* Function Name  : Delay
* Input          : nCount: specifies the delay time length.
* Output         : None
* Return         : None
void Delay(vu32 nTime)
   /*允许SysTick计数器*/
   SysTick_CounterCmd(SysTick_Counter_Enable);
   TimingDelay = nTime ;  /*TimingDelay是在定义it.c的一个
                          变量用来在SysTick服务程序中自减*/
   while(TimingDelay!=0);
   SysTick_CounterCmd( SysTick_Counter_Disable);
   SysTick_CounterCmd ( SysTick_Counter_Clear);
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
   /* User can add his own implementation to report the file name and line number,
   ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
   /* Infinite loop */
   while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
it.c
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name          : stm32f10x_it.c
* Author             : MCD Application Team
* Version            : V2.0.1
* Date               : 06/13/2008
* Description        : Main Interrupt Service Routines.
*                      This file provides template for all exceptions handler
*                      and peripherals interrupt service routine.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_it.h"
vu32 TimingDelay =0 ;
extern void Delay(vu32 nTime);
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name  : NMIException
* Description    : This function handles NMI exception.
* Input          : None
* Output         : None
* Return         : None
void NMIException(void)
* Function Name  : HardFaultException
* Description    : This function handles Hard Fault exception.
* Input          : None
* Output         : None
* Return         : None
void HardFaultException(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
* Function Name  : MemManageException
* Description    : This function handles Memory Manage exception.
* Input          : None
* Output         : None
* Return         : None
void MemManageException(void)
  /* Go to infinite loop when Memory Manage exception occurs */
  while (1)
* Function Name  : BusFaultException
* Description    : This function handles Bus Fault exception.
* Input          : None
* Output         : None
* Return         : None
void BusFaultException(void)
  /* Go to infinite loop when Bus Fault exception occurs */
  while (1)
* Function Name  : UsageFaultException
* Description    : This function handles Usage Fault exception.
* Input          : None
* Output         : None
* Return         : None
void UsageFaultException(void)
  /* Go to infinite loop when Usage Fault exception occurs */
  while (1)
* Function Name  : DebugMonitor
* Description    : This function handles Debug Monitor exception.
* Input          : None
* Output         : None
* Return         : None
void DebugMonitor(void)
* Function Name  : SVCHandler
* Description    : This function handles SVCall exception.
* Input          : None
* Output         : None
* Return         : None
void SVCHandler(void)
* Function Name  : PendSVC
* Description    : This function handles PendSVC exception.
* Input          : None
* Output         : None
* Return         : None
void PendSVC(void)
* Function Name  : SysTickHandler
* Description    : This function handles SysTick Handler.
* Input          : None
* Output         : None
* Return         : None
void SysTickHandler(void)
    TimingDelay --;
* Function Name  : WWDG_IRQHandler
* Description    : This function handles WWDG interrupt request.
* Input          : None
* Output         : None
* Return         : None
void WWDG_IRQHandler(void)
* Function Name  : PVD_IRQHandler
* Description    : This function handles PVD interrupt request.
* Input          : None
* Output         : None
* Return         : None
void PVD_IRQHandler(void)
* Function Name  : TAMPER_IRQHandler
* Description    : This function handles Tamper interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TAMPER_IRQHandler(void)
* Function Name  : RTC_IRQHandler
* Description    : This function handles RTC global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void RTC_IRQHandler(void)
* Function Name  : FLASH_IRQHandler
* Description    : This function handles Flash interrupt request.
* Input          : None
* Output         : None
* Return         : None
void FLASH_IRQHandler(void)
* Function Name  : RCC_IRQHandler
* Description    : This function handles RCC interrupt request.
* Input          : None
* Output         : None
* Return         : None
void RCC_IRQHandler(void)
* Function Name  : EXTI0_IRQHandler
* Description    : This function handles External interrupt Line 0 request.
* Input          : None
* Output         : None
* Return         : None
void EXTI0_IRQHandler(void)
* Function Name  : EXTI1_IRQHandler
* Description    : This function handles External interrupt Line 1 request.
* Input          : None
* Output         : None
* Return         : None
void EXTI1_IRQHandler(void)
* Function Name  : EXTI2_IRQHandler
* Description    : This function handles External interrupt Line 2 request.
* Input          : None
* Output         : None
* Return         : None
void EXTI2_IRQHandler(void)
* Function Name  : EXTI3_IRQHandler
* Description    : This function handles External interrupt Line 3 request.
* Input          : None
* Output         : None
* Return         : None
void EXTI3_IRQHandler(void)
* Function Name  : EXTI4_IRQHandler
* Description    : This function handles External interrupt Line 4 request.
* Input          : None
* Output         : None
* Return         : None
void EXTI4_IRQHandler(void)
* Function Name  : DMA1_Channel1_IRQHandler
* Description    : This function handles DMA1 Channel 1 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMA1_Channel1_IRQHandler(void)
* Function Name  : DMA1_Channel2_IRQHandler
* Description    : This function handles DMA1 Channel 2 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMA1_Channel2_IRQHandler(void)
* Function Name  : DMA1_Channel3_IRQHandler
* Description    : This function handles DMA1 Channel 3 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMA1_Channel3_IRQHandler(void)
* Function Name  : DMA1_Channel4_IRQHandler
* Description    : This function handles DMA1 Channel 4 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMA1_Channel4_IRQHandler(void)
* Function Name  : DMA1_Channel5_IRQHandler
* Description    : This function handles DMA1 Channel 5 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMA1_Channel5_IRQHandler(void)
* Function Name  : DMA1_Channel6_IRQHandler
* Description    : This function handles DMA1 Channel 6 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMA1_Channel6_IRQHandler(void)
* Function Name  : DMA1_Channel7_IRQHandler
* Description    : This function handles DMA1 Channel 7 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMA1_Channel7_IRQHandler(void)
* Function Name  : ADC1_2_IRQHandler
* Description    : This function handles ADC1 and ADC2 global interrupts requests.
* Input          : None
* Output         : None
* Return         : None
void ADC1_2_IRQHandler(void)
* Function Name  : USB_HP_CAN_TX_IRQHandler
* Description    : This function handles USB High Priority or CAN TX interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void USB_HP_CAN_TX_IRQHandler(void)
* Function Name  : USB_LP_CAN_RX0_IRQHandler
* Description    : This function handles USB Low Priority or CAN RX0 interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void USB_LP_CAN_RX0_IRQHandler(void)
* Function Name  : CAN_RX1_IRQHandler
* Description    : This function handles CAN RX1 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void CAN_RX1_IRQHandler(void)
* Function Name  : CAN_SCE_IRQHandler
* Description    : This function handles CAN SCE interrupt request.
* Input          : None
* Output         : None
* Return         : None
void CAN_SCE_IRQHandler(void)
* Function Name  : EXTI9_5_IRQHandler
* Description    : This function handles External lines 9 to 5 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void EXTI9_5_IRQHandler(void)
    if(EXTI_GetITStatus(EXTI_Line5)!=RESET)
    GPIOB->ODR=0XFFFF;
    //GPIO_WriteBit(GPIOB,GPIO_Pin_6,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOB,GPIO_Pin_6)));
    EXTI_ClearITPendingBit(EXTI_Line5);
* Function Name  : TIM1_BRK_IRQHandler
* Description    : This function handles TIM1 Break interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM1_BRK_IRQHandler(void)
* Function Name  : TIM1_UP_IRQHandler
* Description    : This function handles TIM1 overflow and update interrupt
*                  request.
* Input          : None
* Output         : None
* Return         : None
void TIM1_UP_IRQHandler(void)
* Function Name  : TIM1_TRG_COM_IRQHandler
* Description    : This function handles TIM1 Trigger and commutation interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void TIM1_TRG_COM_IRQHandler(void)
* Function Name  : TIM1_CC_IRQHandler
* Description    : This function handles TIM1 capture compare interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM1_CC_IRQHandler(void)
* Function Name  : TIM2_IRQHandler
* Description    : This function handles TIM2 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM2_IRQHandler(void)
* Function Name  : TIM3_IRQHandler
* Description    : This function handles TIM3 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM3_IRQHandler(void)
* Function Name  : TIM4_IRQHandler
* Description    : This function handles TIM4 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM4_IRQHandler(void)
* Function Name  : I2C1_EV_IRQHandler
* Description    : This function handles I2C1 Event interrupt request.
* Input          : None
* Output         : None
* Return         : None
void I2C1_EV_IRQHandler(void)
* Function Name  : I2C1_ER_IRQHandler
* Description    : This function handles I2C1 Error interrupt request.
* Input          : None
* Output         : None
* Return         : None
void I2C1_ER_IRQHandler(void)
* Function Name  : I2C2_EV_IRQHandler
* Description    : This function handles I2C2 Event interrupt request.
* Input          : None
* Output         : None
* Return         : None
void I2C2_EV_IRQHandler(void)
* Function Name  : I2C2_ER_IRQHandler
* Description    : This function handles I2C2 Error interrupt request.
* Input          : None
* Output         : None
* Return         : None
void I2C2_ER_IRQHandler(void)
* Function Name  : SPI1_IRQHandler
* Description    : This function handles SPI1 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void SPI1_IRQHandler(void)
* Function Name  : SPI2_IRQHandler
* Description    : This function handles SPI2 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void SPI2_IRQHandler(void)
* Function Name  : USART1_IRQHandler
* Description    : This function handles USART1 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void USART1_IRQHandler(void)
* Function Name  : USART2_IRQHandler
* Description    : This function handles USART2 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void USART2_IRQHandler(void)
* Function Name  : USART3_IRQHandler
* Description    : This function handles USART3 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void USART3_IRQHandler(void)
* Function Name  : EXTI15_10_IRQHandler
* Description    : This function handles External lines 15 to 10 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void EXTI15_10_IRQHandler(void)
* Function Name  : RTCAlarm_IRQHandler
* Description    : This function handles RTC Alarm interrupt request.
* Input          : None
* Output         : None
* Return         : None
void RTCAlarm_IRQHandler(void)
   if(RTC_GetITStatus(RTC_IT_ALR)!=RESET)
 GPIOB->ODR=0Xfff;
 if(PWR_GetFlagStatus(PWR_FLAG_WU)!=RESET)
    PWR_ClearFlag(PWR_FLAG_WU);
  /*等待最后一条命令写完成*/
  /*清楚RTC报警挂起*/
  EXTI_ClearITPendingBit(RTC_IT_ALR);
* Function Name  : USBWakeUp_IRQHandler
* Description    : This function handles USB WakeUp interrupt request.
* Input          : None
* Output         : None
* Return         : None
void USBWakeUp_IRQHandler(void)
* Function Name  : TIM8_BRK_IRQHandler
* Description    : This function handles TIM8 Break interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM8_BRK_IRQHandler(void)
* Function Name  : TIM8_UP_IRQHandler
* Description    : This function handles TIM8 overflow and update interrupt
*                  request.
* Input          : None
* Output         : None
* Return         : None
void TIM8_UP_IRQHandler(void)
* Function Name  : TIM8_TRG_COM_IRQHandler
* Description    : This function handles TIM8 Trigger and commutation interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void TIM8_TRG_COM_IRQHandler(void)
* Function Name  : TIM8_CC_IRQHandler
* Description    : This function handles TIM8 capture compare interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM8_CC_IRQHandler(void)
* Function Name  : ADC3_IRQHandler
* Description    : This function handles ADC3 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void ADC3_IRQHandler(void)
* Function Name  : FSMC_IRQHandler
* Description    : This function handles FSMC global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void FSMC_IRQHandler(void)
* Function Name  : SDIO_IRQHandler
* Description    : This function handles SDIO global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void SDIO_IRQHandler(void)
* Function Name  : TIM5_IRQHandler
* Description    : This function handles TIM5 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM5_IRQHandler(void)
* Function Name  : SPI3_IRQHandler
* Description    : This function handles SPI3 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void SPI3_IRQHandler(void)
* Function Name  : UART4_IRQHandler
* Description    : This function handles UART4 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void UART4_IRQHandler(void)
* Function Name  : UART5_IRQHandler
* Description    : This function handles UART5 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void UART5_IRQHandler(void)
* Function Name  : TIM6_IRQHandler
* Description    : This function handles TIM6 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM6_IRQHandler(void)
* Function Name  : TIM7_IRQHandler
* Description    : This function handles TIM7 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM7_IRQHandler(void)
* Function Name  : DMA2_Channel1_IRQHandler
* Description    : This function handles DMA2 Channel 1 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMA2_Channel1_IRQHandler(void)
* Function Name  : DMA2_Channel2_IRQHandler
* Description    : This function handles DMA2 Channel 2 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMA2_Channel2_IRQHandler(void)
* Function Name  : DMA2_Channel3_IRQHandler
* Description    : This function handles DMA2 Channel 3 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMA2_Channel3_IRQHandler(void)
* Function Name  : DMA2_Channel4_5_IRQHandler
* Description    : This function handles DMA2 Channel 4 and DMA2 Channel 5
*                  interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMA2_Channel4_5_IRQHandler(void)
关键字:STM32f103  睡眠模式  唤醒 引用地址:STM32f103-实例睡眠模式的唤醒
上一篇:stm32快速学习1——环境的建立
下一篇:FreeRTOS 在STM32上的移植 V1.0
推荐阅读最新更新时间:2024-03-16 15:12
STM32F103利用模拟I2C驱动ADS1115
ADS1115通过模拟I2C驱动:(部分代码借鉴了网络上的几个,并且根据引脚进行了配置,都没有运行成功,今天调了一天,终于在晚上调了出来) 注意:本部分代码需要只是ADS1115的部分程序(一些用到的数组在此没有写),模拟II2C的各程序并未给出,大家根据需要进行裁剪,代码完全开源,希望能帮到大家,也希望大家乐于分享。 调试时需特别注意I2C的通信问题,特别是应答信号的使用需要特别关注,本人的程序之前出错全是因为从机的应答信号的未使用造成。 如有其它问题,欢迎指正批评,第一次写博客,感谢! 收获:对于I2C通信协议的理解更加深刻,对ADS1115也能进行单通道的使用。I2C的开始、发送/读写、应答、结束等一定要
[单片机]
STM32F103 - ADC采集电压
在使用STM32F103的ADC采集外部电压时,发现配置不同的采样周期ADC_SampleTime,外部输入阻抗的电压值不同,也就是影响了外部总电压分给ADC口的电压(电阻电压分配不对),但ADC能正常采集; 所以要根据STM32F103手册中的ADC采样周期与外部输入阻抗的关系表来确定软件设定的采样周期Ts和采样电阻RAIN大小。关系表如下所示:
[单片机]
<font color='red'>STM32F103</font> - ADC采集电压
一文详解STM32F103单片机中断架构
3.1 STM32F103中断概述 Cortex-M3内核支持256个中断,其中包含了16个内核中断和240个外部中断,并且具有256级的可编程中断设置。但STM32并没有使用Cortex-M3内核的全部东西,而是只用了它的一部分。STM32有84个中断,包括16个内核中断和68个可屏蔽中断,具有16级可编程的中断优先级。而我们常用的就是这68个可屏蔽中断,但是STM32的68个可屏蔽中断,在STM32F103ZET6中只有60个。 3.2 STM32F103中断优先级 3.2.1 优先级结构 STM32F103的中断分为抢占优先级和响应优先级两种,这两种优先级的顺序是抢占优先级高于响应优先级,假设存在两个事件,那就会存在以
[单片机]
一文详解<font color='red'>STM32F103</font>单片机中断架构
STM32F103C8T6 SPI主从通讯问题及待解决方案
1.我是用两块STM32F103C8T6进行SPI通讯,一块做主机,一块作为从机; 主机部分代码: void SPI2_Config(void)//SPI2的传输配置 { SPI_InitTypeDef SPI_InitStructure; SPI_Cmd(SPI2, DISABLE); SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; S
[单片机]
<font color='red'>STM32F103</font>C8T6 SPI主从通讯问题及待解决方案
STM32F103ZET6 时钟(2)—— 代码篇
基于特定的开发板上的时钟策略: 倍频/分频系数需要在使能 PLL 之前进行配置,所以需要在 Open PLL 之前将所有系统的时钟分频器系数以及PLL的倍频系数配置好。整个时钟的配置流程如下所示: (1) 开启HSE,等待HSE稳定 (2) 设置APB2、APB1、AHB分频系数 (3) 设置PLL的时钟来源和PLL的倍频系数 (4) 开启PLL,等待PLL稳定 (5) 设置SYSCLK源为 PLL 的输出,读取时钟切换状态,确保PLLCLK被选为系统时钟 (1) OSC_IN/OSC_OUT 上外接 8M 晶振。要使用外接晶振,上电后(默认使用 8M 的HSI),首先需要使能 HSE,位于RCC_CR寄存器的 bi
[单片机]
Syntiant推出面向TWS语音唤醒的超低功耗参考设计
数据训练和建模支持多语言自定义唤醒词和语音命令,为边缘AI处理提供完整的端到端解决方案。 深度学习解决方案提供商 Syntiant日前宣布了一种新的参考设计,该设计将使 ODM 和 OEM 能够轻松快速地将低功耗边缘AI语音处理部署至TWS中。 Syntiant Core 1 NDP100 通过高度耦合的计算和内存实现了突破性的性能,内部集成了深度学习和计算功能。 超低功耗TWS参考设计采用小巧封装 (1.4 毫米 x 1.8 毫米),以低于 140 μW的功率实现始终在线的 AI 语音处理,与传统 MCU 相比,效率提高 100 倍,吞吐量提高了 10 倍。凭借包括“Hey Google”和“Alexa”在内的自定义
[手机便携]
STM32F103F103与电阻触摸屏接口电路图
本文为你介绍一款STM32F103F103与四线电阻触摸屏直接通过自身的I/O口连接,实现触摸屏控制器功能;主要电路如下图所示:
[单片机]
<font color='red'>STM32F103</font>F103与电阻触摸屏接口电路图
STM32F103基于DMA接收不定帧长USART数据
DMA是一种不使用CPU而将数据从一片地址空间复制到另一片地址空间的总线,这样就减少了CPU的负担,使其能够更加专注于数据运算。为了能够减少CPU的负担,DMA应该采取中断方式而非查询模式。但是非常不幸的是,STM32F103只为DMA提供了三种中断:半步中断、完成中断和错误中断。如果UART接收的是定帧长的数据,则可以开启DMA半步中断,并且目标地址长度为帧长两倍。这样每接收完一帧进一次中断,进行某些操作,是很理想的。然而当遇到如同GPS一样不定帧长的数据时,如果仍用半步中断则难以确定目标地址的长度。所以在此放弃使用DMA的中断,转而使用的是另一种比较特别的中断:UART空闲中断。 先来介绍一下UART空闲中断。UART常用的接
[单片机]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
