#define uchar unsigned char
#define uint unsigned int
sbit DQ = P3^3 ; //定义DS18B20端口DQ
sbit BEEP=P3^6 ; //蜂鸣器驱动线
bit presence ; //检测18b20是否插好
sbit LCD_RS = P2^0 ;
sbit LCD_RW = P2^1 ;
sbit LCD_EN = P2^2 ;
uchar code cdis1[ ] = {" 牛牛智能科技 "} ;
uchar code cdis2[ ] = {" WENDU: . C "} ;
uchar code cdis3[ ] = {" DS18B20 ERR0R "} ;
uchar code cdis4[ ] = {" PLEASE CHECK "} ;
unsigned char data temp_data[2] = {0x00,0x00} ;
unsigned char data display[5] = {0x00,0x00,0x00,0x00,0x00} ;
unsigned char code ditab[16] = {0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x04,
0x05,0x06,0x06,0x07,0x08,0x08,0x09,0x09} ;
void beep() ;
unsigned char code mytab[8] = {0x0C,0x12,0x12,0x0C,0x00,0x00,0x00,0x00} ;
#define delayNOP() ; {_nop_() ;_nop_() ;_nop_() ;_nop_() ;} ;
void delay1(int ms)
unsigned char y ;
while(ms--)
for(y = 0 ; y<250 ; y++)
_nop_() ;
_nop_() ;
_nop_() ;
_nop_() ;
/*检查LCD忙状态 */
/*lcd_busy为1时,忙,等待。lcd-busy为0时,闲,可写指令与数据。 */
bit lcd_busy()
bit result ;
LCD_RS = 0 ;
LCD_RW = 1 ;
LCD_EN = 1 ;
delayNOP() ;
result = (bit)(P0&0x80) ;
LCD_EN = 0 ;
return(result) ;
/*写指令数据到LCD */
/*RS=L,RW=L,E=高脉冲,D0-D7=指令码。 */
void lcd_wcmd(uchar cmd)
while(lcd_busy()) ;
LCD_RS = 0 ;
LCD_RW = 0 ;
LCD_EN = 0 ;
_nop_() ;
_nop_() ;
P0 = cmd ;
delayNOP() ;
LCD_EN = 1 ;
delayNOP() ;
LCD_EN = 0 ;
/*写显示数据到LCD */
/*RS=H,RW=L,E=高脉冲,D0-D7=数据。 */
void lcd_wdat(uchar dat)
while(lcd_busy()) ;
LCD_RS = 1 ;
LCD_RW = 0 ;
LCD_EN = 0 ;
P0 = dat ;
delayNOP() ;
LCD_EN = 1 ;
delayNOP() ;
LCD_EN = 0 ;
/* LCD初始化设定 */
void lcd_init()
delay1(15) ;
lcd_wcmd(0x01) ; //清除LCD的显示内容
lcd_wcmd(0x38) ; //16*2显示,5*7点阵,8位数据
delay1(5) ;
lcd_wcmd(0x38) ;
delay1(5) ;
lcd_wcmd(0x38) ;
delay1(5) ;
lcd_wcmd(0x0c) ; //显示开,关光标
delay1(5) ;
lcd_wcmd(0x06) ; //移动光标
delay1(5) ;
delay1(5) ;
/* 设定显示位置 */
void lcd_pos(uchar pos)
lcd_wcmd(pos | 0x80) ; //数据指针=80+地址变量
/*自定义字符写入CGRAM */
void writetab()
unsigned char i ;
lcd_wcmd(0x40) ; //写CGRAM
for (i = 0 ; i< 8 ; i++)
lcd_wdat(mytab[ i ]) ;
/*us级延时函数 */
void Delay(unsigned int num)
while( --num ) ;
/*初始化ds1820 */
Init_DS18B20(void)
DQ = 1 ; //DQ复位
Delay(8) ; //稍做延时
DQ = 0 ; //单片机将DQ拉低
Delay(90) ; //精确延时 大于 480us
DQ = 1 ; //拉高总线
Delay(8) ;
presence = DQ ; //如果=0则初始化成功 =1则初始化失败
Delay(100) ;
DQ = 1 ;
return(presence) ; //返回信号,0=presence,1= no presence
/* 读一个字节 */
ReadOneChar(void)
unsigned char i = 0 ;
unsigned char dat = 0 ;
for (i = 8 ; i > 0 ; i--)
DQ = 0 ; // 给脉冲信号
dat >>= 1 ;
DQ = 1 ; // 给脉冲信号
if(DQ)
dat |= 0x80 ;
Delay(4) ;
return (dat) ;
/* 写一个字节 */
WriteOneChar(unsigned char dat)
DQ = 0 ;
DQ = dat&0x01 ;
Delay(5) ;
DQ = 1 ;
dat>>=1 ;
/* 读取温度 */
Read_Temperature(void)
Init_DS18B20() ;
WriteOneChar(0xCC) ; // 跳过读序号列号的操作
WriteOneChar(0x44) ; // 启动温度转换
Init_DS18B20() ;
WriteOneChar(0xCC) ; //跳过读序号列号的操作
WriteOneChar(0xBE) ; //读取温度寄存器
temp_data[0] = ReadOneChar() ; //温度低8位
temp_data[1] = ReadOneChar() ; //温度高8位
/* 数据转换与温度显示 */
Disp_Temperature()
display[4]=temp_data[0]&0x0f ;
display[0]=ditab[display[4]]+0x30 ;//查表得小数位的值
display[4]=((temp_data[0]&0xf0)>>4)|((temp_data[1]&0x0f)<<4) ;
display[3]=display[4]/100+0x30 ;
display[1]=display[4]%100 ;
display[2]=display[1]/10+0x30 ;
display[1]=display[1]%10+0x30 ;
if(display[3]==0x30) //高位为0,不显示
display[3]=0x20 ;
if(display[2]==0x30) //次高位为0,不显示
display[2]=0x20 ;
lcd_pos(0x48) ;
lcd_wdat(display[3]) ; //百位数显示
lcd_pos(0x49) ;
lcd_wdat(display[2]) ; //十位数显示
lcd_pos(0x4a) ;
lcd_wdat(display[1]) ; //个位数显示
lcd_pos(0x4c) ;
lcd_wdat(display[0]) ; //小数位数显示
/* 蜂鸣器响一声 */
void beep()
unsigned char y ;
for (y=0 ;y<100 ;y++)
Delay(60) ;
BEEP=!BEEP ; //BEEP取反
BEEP=1 ; //关闭蜂鸣器
Delay(40000) ;
/* DS18B20 OK 显示菜单 */
void Ok_Menu ()
uchar m ;
lcd_init() ; //初始化LCD
lcd_pos(0) ; //设置显示位置为第一行的第1个字符
m = 0 ;
while(cdis1[m] != '\0')
{ //显示字符
lcd_wdat(cdis1[m]) ;
m++ ;
lcd_pos(0x40) ; //设置显示位置为第二行第1个字符
m = 0 ;
while(cdis2[m] != '\0')
lcd_wdat(cdis2[m]) ; //显示字符
m++ ;
writetab() ; //自定义字符写入CGRAM
delay1(5) ;
lcd_pos(0x4d) ;
lcd_wdat(0x00) ; //显示自定义字符
/* DS18B20 ERROR 显示菜单 */
void Error_Menu ()
uchar m ;
m = 0 ;
while(cdis3[m] != '\0')
{ //显示字符
lcd_wdat(cdis3[m]) ;
m++ ;
m = 0 ;
while(cdis4[m] != '\0')
lcd_wdat(cdis4[m]) ; //显示字符
m++ ;
/* 主函数 */
void main()
Ok_Menu () ;
do
Read_Temperature() ; //读取温度
Disp_Temperature() ; //显示温度
while(!presence) ;
Error_Menu () ;
do
Init_DS18B20() ;
beep() ;
while(presence) ;
上一篇:单片机控制多个步进电机C语言程序设计
下一篇:1602液晶显示红外遥控解码C语言程序设计
推荐阅读最新更新时间:2024-03-16 15:17
设计资源 培训 开发板 精华推荐
- “集齐五友”参与KW41Z创意征集活动,赢100元京东卡!
- TE 智能电表特训营,产品、技术、市场全解锁!
- 了解ADI电网管理、能源计量方案,答题赢Kindle、《新概念模拟电路》【世健的ADI之路主题游 能源站】
- 世健30周年,寄语世健享好礼!
- 理想中的开发板、万用表,好用不贵? e络盟11.11抢购,给你机会!
- 借助 Microchip 生态系统中的 PIC® 和 AVR® 单片机开启嵌入式到云端之旅 系列在线研讨会
- 【XILINX 主题分享月】 设计工具资料大搜集!!!
- 学习有礼,分享也有礼!跟着小梅哥,一起intel SoC FPGA走起!
- 悦读 TI 工业应用精选方案,闯关赢好礼喽!
