//ICC-AVR application builder : 2006-7-7 11:30:51
// Target : M8
// Crystal: 8.0000Mhz 20k for G4PC50U
#include
#include
#define INT0 6
//=====================周期为20ms,spwm频率为20k===========================//
short list[]={1,4,7,10,13,16,19,22,25,28,31,34,37,39,42,45,48,51,54,57,60,62,
65,68,71,74,76,79,82,84,87,90,92,95,97,100,103,105,108,110,112,115,117,119,
122,124,126,128,131,133,135,137,139,141,143,145,147,149,151,152,154,156,157,
159,161,162,164,165,167,168,169,171,172,173,174,176,177,178,179,180,181,182,
182,183,184,185,185,186,186,187,187,188,188,189,189,189,189,189,189,189,189,
189,189,189,189,189,189,188,188,187,187,186,186,185,185,184,183,182,182,181,
180,179,178,177,176,174,173,172,171,169,168,167,165,164,162,161,159,157,156,
154,152,151,149,147,145,143,141,139,137,135,133,131,128,126,124,122,119,117,
115,112,110,108,105,103,100,97,95,92,90,87,84,82,79,76,74,71,68,65,62,60,57,
54,51,48,45,42,39,37,34,31,28,25,22,19,16,13,10,7,4,1};
int count,zf=0;
void port_init(void)
PORTB = 0x00;
DDRB = 0xFF;//06;b口输出
PORTC = 0x00;
DDRC = 0xFF;//c口输出
PORTD = 0x00;
DDRD = 0x00;//d口输入
//TIMER1 initialize - prescale:1
// WGM13:0=10) PWM phz correct, TOP= ICR1
// desired value: 10KHz
// actual value: 10.000KHz (0.0%)
void timer1_init(void)
TCCR1B = 0x00; //stop
TCNT1H = 0xFF; //setup
TCNT1L = 0x38;
OCR1AH = 0x00;
OCR1AL = 0xC8;
OCR1BH = 0x00;
OCR1BL = 0xC8;
ICR1H = 0x00;
ICR1L = 200;// 载波周期为50us
TCCR1A = 0xA2; //10100010 top时更新OCR1A OCR1B,向上计数比较匹配清零,反之置位
TCCR1B = 0x11; //start Timer 00010001 clk无分频,相位修正PWM
TIMSK |= 0x20; //timer interrupt sources使能捕捉中断
#pragma interrupt_handler timer1_capt_isr:6
void timer1_capt_isr(void)
OCR1A=500;
OCR1B=500;
//PORTB ^=0x10;
// 2 1 .spwm
// 4 3 180
if(zf)
if(count<200)
if(count==1) //此时2#管子才关断
//PORTB &= ~BIT(3); //3#管子已经关断
PORTB |= BIT(4); //开通4#管子
OCR1A=list[count++]; //开通1#管子
else if((count>=200)&&(count<400))
if(count==200)
PORTB &= ~BIT(4); //关断4#管子
if(count==201) //此时1#管子才关断
PORTB |= BIT(3); //开通3#管子
OCR1B=list[count++-200]; //开通2#管子
else
count=0; //2#管子已经关断
PORTB &= ~BIT(3); //关断3#管子
//PORTB |= BIT(4); //开通4#管子
else;
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
timer1_init();
SEI(); //re-enable interrupts
//all peripherals are now initialized
void main(void)
init_devices();
//insert your functional code here...
zf = 1;
OCR1A=500;
OCR1B=500;
PORTB = 0;
while(1);
生成50hz正弦波
上一篇:关于用mega128输出任意频率脉冲的问题
下一篇:TC1的双路PWM输出实验
推荐阅读最新更新时间:2024-03-16 15:18
设计资源 培训 开发板 精华推荐
- PC产业驶入创新超车道,英特尔蓉城撬动AI新引擎
- 与产业聚力共赢,英特尔举行新质生产力技术生态大会
- “新”享5G-A万兆网络前沿体验 高通携手产业伙伴亮相第二届链博会
- 英飞凌推出符合ASIL-D标准的新型汽车制动系统和电动助力转向系统三相栅极驱动器 IC
- 南芯科技推出80V升降压转换器,持续深耕工业储能市场
- 法雷奥与罗姆联合开发新一代功率电子领域
- 贸泽电子开售能为电动汽车牵引逆变器提供可扩展性能的 英飞凌HybridPACK Drive G2模块
- 德州仪器新型 MCU 可实现边缘 AI 和先进的实时控制, 提高系统效率、安全性和可持续性
- 瑞萨推出高性能四核应用处理器, 增强工业以太网与多轴电机控制解决方案阵容
- 研华全新模块化电脑SOM-6833助力5G路测设备升级
