硬件调试通过
#include"reg52.h"
#include "intrins.h"
#include "string.h"
#include "key.h" //按键通码与ascii对照表
#define uchar unsigned char
#define uint unsigned int
#define BOOL bit
#define cmd_word 0xff //复位命令
sbit Clk_Line = P3^3; //时钟线
sbit Data_Line=P3^4; //键盘数据线
uchar key=0; //按键最终值
uint Key_Value=0;
uchar Int_Time=0;
uchar save=0;
uchar display[40];
uchar scancode[40];
uint num = 0;
uchar blank;
uchar flag;
uchar comf = 0x01;
void init(void);
void delay(uint us); //us=12大约100us
void command(uchar cmd);
void interrupt1_receive(void);
void getkey(void) ;////内部中断0 用来处理缓冲区里的数据
void keyprocess(void);
void lcdclr(void);
//Port Definitions**********************************************************
sbit rs = P2^0; //
sbit rw = P2^1;
sbit ep = P2^2;
#define LCDPORT P0
sbit LcdLight = LCDPORT^4;
void Delay1ms(unsigned int count)
unsigned int i,j;
for(i=0;i
//向LCD写入命令或数据************************************************************
#define LCD_COMMAND 0x00 // Command
#define LCD_DATA 0x01 // Data
#define LCD_CLEAR_SCREEN 0x01 // 清屏
#define LCD_HOMING 0x02 // 光标返回原点
//设置显示模式************************************************************
#define LCD_SHOW 0x04 //显示开
#define LCD_HIDE 0x00 //显示关
#define LCD_CURSOR 0x02 //显示光标
#define LCD_NO_CURSOR 0x00 //无光标
#define LCD_FLASH 0x01 //光标闪动
#define LCD_NO_FLASH 0x00 //光标不闪动
//设置输入模式************************************************************
#define LCD_AC_UP 0x02
#define LCD_AC_DOWN 0x00 // default
#define LCD_MOVE 0x01 // 画面可平移
#define LCD_NO_MOVE 0x00 //default
//移动光标或屏幕************************************************************
#define LCD_SCREEN 0x08
#define LCD_LEFT 0x00
#define LCD_RIGHT 0x04
delayms(uchar ms)
{ // 延时子程序
uchar i;
while(ms--)
for(i = 0; i< 250; i++)
_nop_();
_nop_();
_nop_();
_nop_();
uchar parity;
uchar i;
comf = 0x01;
parity=0;
Clk_Line=1;
Data_Line=1;
delay(100);
Clk_Line=0;
delay(20);
Data_Line=0;
Clk_Line = 1;
for(i=0;i<8;i++)
Clk_Line = 1;
while(Clk_Line);
Data_Line = 0;
if(cmd & (comf<<1))
Data_Line = 1;
parity++;
while(!Clk_Line) ;
while(Clk_Line) ;
if((parity&0x01))
Data_Line=0;
else Data_Line=1;
while(!Clk_Line) ;
while(Clk_Line) ;
Data_Line=1;
while(!Clk_Line);
while(Data_Line) ;
while(Clk_Line) ;
while(!Clk_Line) ;
while(!Data_Line);
BOOL lcd_bz()
{ // 测试LCD忙碌状态
BOOL result;
rs = 0;
rw = 1;
ep = 1;
_nop_();
_nop_();
_nop_();
_nop_();
result = (BOOL)(LCDPORT & 0x80);
ep = 0;
return result;
lcd_wcmd(uchar cmd)
{ // 写入指令数据到LCD
while(lcd_bz());
rs = 0;
rw = 0;
ep = 0;
_nop_();
_nop_();
LCDPORT = cmd;
_nop_();
_nop_();
_nop_();
_nop_();
ep = 1;
_nop_();
_nop_();
_nop_();
_nop_();
ep = 0;
lcd_pos(uchar pos)
{ //设定显示位置
lcd_wcmd(pos | 0x80);
lcd_wdat(uchar dat)
{ //写入字符显示数据到LCD
while(lcd_bz());
rs = 1;
rw = 0;
ep = 0;
LCDPORT = dat;
_nop_();
_nop_();
_nop_();
_nop_();
ep = 1;
_nop_();
_nop_();
_nop_();
_nop_();
ep = 0;
lcd_init()
{ //LCD初始化设定
lcd_wcmd(0x38); //
delayms(1);
lcd_wcmd(0x0c); //
delayms(1);
lcd_wcmd(0x06); //
delayms(1);
lcd_wcmd(0x01); //清除LCD的显示内容
delayms(1);
void init(void)
EA = 1;
IT1 = 1; //外部中断1是下降沿触发方式
void getkey(void)
uchar i=0;
//static uint num = 0;
save = Key_Value;
for(i=0;i<49;i++)
if(noshift[i][0] == save) //普按键的通码在缓冲区的第一位
key = noshift[i][1]; //搜索到字母后进行相应的处理
if(num == 32)
//num = 0;
while(num)
display[--num] = 0;
blank = 0;
lcdclr();
display[num++] = key;
flag = 0;
break;
void delay(uint us) //us=12大约100us
while(us--) ;
void interrupt1_receive(void) interrupt 2
_nop_();
if(Data_Line)
Key_Value|=0x8000;
Int_Time++;
if(Int_Time==11)
Key_Value>>=6;
Int_Time=0;
EX1=0;
Key_Value>>=1;
void main(void)
uchar i=0;
uchar thir=2;
init(); //初始化
lcd_init(); // 初始化LCD
delay(10);
command(cmd_word);
delay(150);
while(1)
EX1=1;
while(EX1) ;
getkey();
lcd_pos(0XC0);
lcd_wdat(key);
_nop_();
上一篇:c51 串口连接接收与发送
下一篇:51P0,P1左右移
推荐阅读最新更新时间:2024-03-16 15:22
