STM32 USB NAND FLASH 模拟U盘
发布者:LIGANG888最新更新时间:2016-12-20 来源: eefocus关键字:STM32  USB  NAND  FLASH  模拟U盘 手机看文章 扫描二维码
随时随地手机看文章
这次是做一个SD卡的USB读卡器的功能,我们就在上次NAND Flash模拟出的U盘的工程上修改了,这样的话只要修改一小部分了。
工程的绝大部分不需要修改,只要将fsmc_nand.c文件移除工程,添加上官方的关于SDIO的SD卡的驱动代码文件stm32_eval_sdio_sd.c,我讨厌出现eval,所以将该文件直接改为sdio_sdcard.c。同时,既然我们使用SDIO来驱动SD卡,所以在外设库文件组里要添加stm32_sdio.c文件,否则会出现很多未定错误。
STM32 USB SD读卡器(SDIO) - ziye334 - ziye334的博客
我们接下去修改的就只有mass_mal.c这个文件了。更NAND Flash工程一样,我们改成简洁点:
uint32_t Mass_Memory_Size[2];
uint32_t Mass_Block_Size[2];
uint32_t Mass_Block_Count[2];
__IO uint32_t Status = 0;
#ifdef USE_STM3210E_EVAL
SD_CardInfo SDCardInfo;
#endif
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name  : MAL_Init
* Description    : 初始化STM32的媒体设备
* Input          : lun
* Output         : None
* Return         : None
uint16_t MAL_Init(uint8_t lun)
  uint16_t status = MAL_OK;
  switch (lun)
    case 0:   //SD卡
      Status = SD_Init();  //调用SD初始化函数
      break;
    default:
      return MAL_FAIL;   //都不是
  return status;
uint16_t MAL_Write(uint8_t lun, uint32_t Memory_Offset, uint32_t *Writebuff, uint16_t Transfer_Length)
  switch (lun)
    case 0:
      Status = SD_WriteBlock((uint8_t*)Writebuff, Memory_Offset, Transfer_Length);
      SD_WaitWriteOperation();   //等待dma传输结束
      while(SD_GetStatus() != SD_TRANSFER_OK); //等待sdio到sd卡传输结束
      if ( Status != SD_OK )
        return MAL_FAIL;
      break;
    default:
      return MAL_FAIL;
  return MAL_OK;
uint16_t MAL_Read(uint8_t lun, uint32_t Memory_Offset, uint32_t *Readbuff, uint16_t Transfer_Length)
  switch (lun)
    case 0:
      Status = SD_ReadBlock((uint8_t*)Readbuff, Memory_Offset, Transfer_Length);
     SD_WaitReadOperation();  //循环查询dma传输是否结束
        return MAL_FAIL;
      break;
    default:
      return MAL_FAIL;
  return MAL_OK;
uint16_t MAL_GetStatus (uint8_t lun)
  uint32_t temp_block_mul = 0;
  uint32_t DeviceSizeMul = 0;
  if (lun == 0)
    if (SD_Init() == SD_OK)
      SD_GetCardInfo(&SDCardInfo);
      SD_SelectDeselect((uint32_t) (SDCardInfo.RCA << 16));
      DeviceSizeMul = (SDCardInfo.SD_csd.DeviceSizeMul + 2);
      if(SDCardInfo.CardType == SDIO_HIGH_CAPACITY_SD_CARD)
        Mass_Block_Count[0] = (SDCardInfo.SD_csd.DeviceSize + 1) * 1024;
      else
        NumberOfBlocks  = ((1 << (SDCardInfo.SD_csd.RdBlockLen)) / 512);
        Mass_Block_Count[0] = ((SDCardInfo.SD_csd.DeviceSize + 1) * (1 << DeviceSizeMul) << (NumberOfBlocks/2));
      Mass_Block_Size[0]  = 512;
      Status = SD_SelectDeselect((uint32_t) (SDCardInfo.RCA << 16));
      Status = SD_EnableWideBusOperation(SDIO_BusWide_4b);
        return MAL_FAIL;
      Mass_Memory_Size[0] = Mass_Block_Count[0] * Mass_Block_Size[0];
      LED2_ON();
      return MAL_OK;
    else
LED2_OFF();
  return MAL_FAIL;
这样SDIO接口的SD卡读卡器就修改完毕了。我使用8G的SD卡测试的,不知道为什么写这么慢,才60KB/秒左右,读的速度为230KB/秒左右。
STM32 USB SD读卡器(SDIO) - ziye334 - ziye334的博客STM32 USB SD读卡器(SDIO) - ziye334 - ziye334的博客
现在把成功后的截图贴上来看看:
 可以正常读写,也可以格式化,一切都OK,噢耶。
关键字:STM32  USB  NAND  FLASH  模拟U盘 引用地址:STM32 USB NAND FLASH 模拟U盘
上一篇:STM32 USB 大容量存储器Mass Storage工程的讲解
下一篇:STM32 CustomHID 的实现
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
