官方提供的库文件中,HSE(外部高速时钟)默认为8MHz,最高主频为8*9=72MHz,如果将HSE变为12MHz,不修改库文件的话,最高主频则变为12*9=108MHz,最典型的问题就是USART可以通信,但是接收到的数据与发送的不一致,并且找不到啥原因,害的我瞎折腾了一整天,下面列举需要修改的地方。
1、修改stm32f10x.h中的HSE_VALUE,原本的代码如下:
#if !defined HSE_VALUE
#ifdef STM32F10X_CL
#define HSE_VALUE ((uint32_t)25000000)
#else
#define HSE_VALUE ((uint32_t)8000000)
#endif
#endif
修改后的如下:
#ifdef STM32F10X_CL
#else
#define HSE_VALUE ((uint32_t)12000000)
#endif
#endif
2、修改system_stm32f10x.c中的时钟配置,先找到void SystemInit(void)---》SetSysClock()---》SetSysClockTo72(),将9倍频改为6倍频,12*6=72MHz,原本代码如下:
#ifdef STM32F10X_CL
RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
RCC->CR |= RCC_CR_PLL2ON;
while((RCC->CR & RCC_CR_PLL2RDY) == 0)
RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
RCC_CFGR_PLLMULL9);
#else
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
RCC_CFGR_PLLMULL));
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
#endif
修改后的如下:
#ifdef STM32F10X_CL
RCC_CFGR_PLLMULL9);
#else
RCC_CFGR_PLLMULL));
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6);
#endif
上一篇:STM32将PA13/PA14/PA15当做普通的IO口使用
下一篇:测试系统数字稳压电源设计方案
推荐阅读最新更新时间:2024-03-16 15:35
