stm32F103VB使用uGfx驱动sh1106
发布者:平安宁静最新更新时间:2017-09-27 来源: eefocus关键字:stm32F103VB  uGfx  驱动sh1106 手机看文章 扫描二维码
随时随地手机看文章
IAR7.4+STM32CUBEMX调试通过。
显示部分,作为麦知智能小车的一部分。显示屏是OLED 1.3寸,控制器是sh1106,但像素是128*64,价格达到惊人的45元/片。
只提供代码,而不同时说明硬件电路图,是导致情景不能复现的主要原因。
这个是委托方提供的原理图和硬件,他每条线都有上拉电阻,显然是打算用模拟SPI。
我在代码里,将cs,dc,res配置为开漏输出,或者推挽输出,都可以正常显示图像。
不知道cs,dc,res在推挽模式下,会不会有问题,所以使用cube配置为OD,低速,而SCLK,SDA默认为PP(配置SPI的默认设置)
与ugfx接口的底层驱动:
  1. /*
  2.  * This file is subject to the terms of the GFX License. If a copy of
  3.  * the license was not distributed with this file, you can obtain one at:
  4.  *
  5.  *              http://ugfx.org/license.html
  6.  * file: board_SSD1306.h
  7.  * author: yu
  8.  * date: 2015.12.14
  9.  * site: www.mazclub.com
  10. */
  11.
  12. /**
  13.  * @file    boards/addons/gdisp/board_SSD1306_spi.h
  14.  * @brief   GDISP Graphic Driver subsystem board interface for the SSD1306 display.
  15.  *
  16.  * @note    This file contains a mix of hardware specific and operating system specific
  17.  *          code. You will need to change it for your CPU and/or operating system.
  18.  */
  19.
  20. #ifndef _GDISP_LLD_BOARD_H
  21. #define _GDISP_LLD_BOARD_H
  22. #include "stm32f1xx_hal.h"
  23. #include "cmsis_os.h"
  24. // The command byte to put on the front of each page line
  25. //#define SSD1306_PAGE_PREFIX       0x40                    // Co = 0, D/C = 1
  26.
  27. // For a multiple display configuration we would put all this in a structure and then
  28. //  set g->board to that structure.
  29.
  30. #define OLED_DC_Port  (GPIOC)
  31. #define OLED_DC_Pin  (GPIO_PIN_15)
  32. #define OLED_CS_Port  (GPIOA)
  33. #define OLED_CS_Pin  (GPIO_PIN_8)
  34. #define OLED_RES_Port  (GPIOC)
  35. #define OLED_RES_Pin  (GPIO_PIN_14)
  36.
  37. #define OLED_RES(a) if (a) \
  38.                       HAL_GPIO_WritePin(OLED_RES_Port,OLED_RES_Pin, GPIO_PIN_SET);\
  39.                       else \
  40.                       HAL_GPIO_WritePin(OLED_RES_Port,OLED_RES_Pin, GPIO_PIN_RESET)
  41.
  42. #define OLED_DC(a) if (a) \
  43.                       HAL_GPIO_WritePin(OLED_DC_Port,OLED_DC_Pin, GPIO_PIN_SET);\
  44.                       else \
  45.                       HAL_GPIO_WritePin(OLED_DC_Port,OLED_DC_Pin, GPIO_PIN_RESET)
  46.
  47. #define OLED_CS(a) if (a) \
  48.                       HAL_GPIO_WritePin(OLED_CS_Port,OLED_CS_Pin, GPIO_PIN_SET);\
  49.                       else \
  50.                       HAL_GPIO_WritePin(OLED_CS_Port,OLED_CS_Pin, GPIO_PIN_RESET)
  51.
  52. #define SET_RST HAL_GPIO_WritePin(OLED_RES_Port, OLED_RES_Pin, GPIO_PIN_SET);
  53. #define CLR_RST HAL_GPIO_WritePin(OLED_RES_Port, OLED_RES_Pin, GPIO_PIN_RESET);
  54.
  55. extern SPI_HandleTypeDef hspi1;
  56.
  57. static void init_board(GDisplay *g) {
  58.     // As we are not using multiple displays we set g->board to NULL as we don't use it.
  59.     g->board = 0;
  60. }
  61.
  62. static void post_init_board(GDisplay *g) {
  63.     (void) g;
  64. }
  65.
  66. static void setpin_reset(GDisplay *g, bool_t state) {
  67.     (void) g;
  68.     if(state)
  69.         CLR_RST
  70.     else
  71.         SET_RST
  72. }
  73.
  74. static void acquire_bus(GDisplay *g) {
  75.     (void) g;
  76. }
  77.
  78. static void release_bus(GDisplay *g) {
  79.     (void) g;
  80. }
  81.
  82. static void write_cmd(GDisplay *g, uint8_t cmd) {
  83.     (void)  g;
  84.         OLED_DC(0);
  85.         OLED_CS(0);
  86.
  87.         HAL_SPI_Transmit(&hspi1, &cmd, 1, 1);
  88.
  89.         OLED_CS(1);
  90. }
  91.
  92. static void write_data(GDisplay *g, uint8_t* data, uint16_t length) {
  93.     (void) g;
  94.         OLED_DC(1);
  95.         OLED_CS(0);
  96.
  97.         HAL_StatusTypeDef status = HAL_SPI_Transmit(&hspi1, data, length, 20);
  98.
  99.         if (status != HAL_OK) {
  100.           HAL_GPIO_WritePin(GPIOC, GPIO_PIN_9, GPIO_PIN_SET);
  101.           HAL_Delay(200);
  102.           HAL_GPIO_WritePin(GPIOC, GPIO_PIN_9, GPIO_PIN_RESET);
  103.
  104.         }
  105.         OLED_CS(1);
  106.
  107. }
ugfx默认支持chibios,是其一部分,使用IAR编译,会有警告,只能忽略,还没看到什么不良影响。
外设初始化代码,由CUBE生成,在此不需列出。
使用demo里面的代码,画一个矩形。
关键字:stm32F103VB  uGfx  驱动sh1106 引用地址:stm32F103VB使用uGfx驱动sh1106
上一篇:理解stm32开漏输出与推挽输出
下一篇:STM32F103利用模拟I2C驱动ADS1115
推荐阅读最新更新时间:2024-03-16 15:38
STC89C52驱动SH1106芯片点亮OLED问题点总结
主芯片:STC89C52 OLED驱动芯片:SH1106 OLED屏大小为1.3寸,像素点是128X64(8页X8),通信方式有IIC和SPI两种方式。 烧录软件:STC-ISP 文字图片取模软件:PCtoLCD2002 选择阳码:屏黑字白(使用这个) 选择阴码:屏白字黑 阳码亮点为0,阴码亮点为1,代码中0XFF为白,0x00为黑。 一个简单的延时毫秒代码: void delay_ms(unsigned int ms) { unsigned int a; while(ms) { a=100; while(a--); ms--; } retu
[单片机]
STC89C52<font color='red'>驱动</font><font color='red'>SH1106</font>芯片点亮OLED问题点总结
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
热门活动
换一批
更多
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
更多精选电路图
换一换 更多 相关热搜器件
更多每日新闻
随便看看
